[Solved] Title: ZTE NETBOX MF-258K Kat. 15 vs B535 in Szczepanek, Masovian Voivodeship: User Advice
drops9999 24264 6
  • #1 19169452
    drops9999
    Rate: 18
    Hello, does anyone have this set from Playa? And can anyone advise whether it will be of use in my location in Szczepanek, Masovian Voivodeship, I am currently using the B535 and the Signaflex typhoon antenna is not a revelation.
    Requesting LTE band and BTS signal measurements
    #2 19169472
    matek451
    Help: 4352
    Rate: 5808
    And why did you choose this operator, this router and, oh, horror, it's gh ... pretending to be an antenna from Signaflex? Did you set up at BTS Playa in Franciszków or at Jasienica? What are the signal parameters on the B535 on the individual LTE2100, LTE1800, LTE800 and LTE2600 bands, if Jasienica, what speeds? Ultimately, in Play with FraNciszków, LTE2100 + 1800 aggregation is used, and in the case of JaSienica with LTE2600 + 1800/2100 as you have B535 or LTE2600 + 2100 + 1800 + 800 aggregation in QAM256 on equipment with 4 LTE aggregation.
    Jasienica is a 5GR 4CC CA station on optical fiber, so it is assumed to have much higher speeds than from a typical rural BTS, such as Franciszków without LTE2600, with a free radio link from BTS in Tluszcz.
    Of course, I know how MF258k works because I have had the WF860 for a year and a half, which is the first model of this equipment. In your case, the signal tests first and then the next steps.
    And how is the brother-in-law with this Plus, which equipment he chose because the signal parameters like LTE900 from Rokitnica station were weak but you did not let him advise him or he was fast himself?
  • Operator change improved speeds, but antenna limits remain
    #3 19169504
    drops9999
    Rate: 18
    I chose this operator and this router because you recommended me a year ago :) But after a year, I want to switch from monthly card packages to permanent packages. And in fact, after switching from orange to the beach, the statistics improved, plus I have no chance. As for the antenna, it was bought much earlier, I know that crap. Antenna set to the jassienice currently set to 1800 + 2100 to 800 weakly to 2600 also maybe if a better antenna would be better in my area a lot of forests then maybe and that's why. But I do not want to push the costs anymore, only take it from the operator. And for my brother we have installed my signa flex antenna, but I do not remember what the router has and after connecting and extending the 2600, it has 40/50 mb / s rude, which is quite enough for him, unfortunately, I do not achieve such speeds for me, although I live closer to the city during the day until 10 mb / s in the evening up to 20 mb / s when using 2 devices sometimes it is terrible on any network at my home there is no coverage on the phone except play and it even catches lte but do you think that this set will work in my area? as a reminder, https://www.elektroda.pl/rtvforum/topic3644234.html
  • #4 19169585
    matek451
    Help: 4352
    Rate: 5808
    I do not know, do tests of LTE2600, LTE2100, LTE1800, LTE800 bands with this kind of antenna and then with the B535 router outside and show screenshots from Hmanager and speedtest, the Franciszkowo station is nearby, it may work well.
  • #5 19169692
    drops9999
    Rate: 18
    So what location to do with the antenna on Franciszków or on the jassienice? Because these are completely opposite directions
  • #7 19175925
    drops9999
    Rate: 18
    ZTE NETBOX MF-258K cat. 15 after buying this equipment, a revelation, the speed jumped up with an antenna that is only at home at 40.50 mb / s I recommend
The discussion revolves around the performance of the ZTE NETBOX MF-258K (Cat. 15) compared to the B535 router in Szczepanek, Masovian Voivodeship. Users share experiences regarding signal strength and internet speeds, particularly in relation to the Signaflex Typhoon antenna. One user reports improved speeds after switching to the MF-258K, achieving 40-50 Mbps with the antenna, while another user struggles with lower speeds (10-20 Mbps) despite being closer to urban areas. Recommendations include testing various LTE bands (LTE2600, LTE2100, LTE1800, LTE800) and positioning the antenna strategically between nearby BTS stations in Jasienica and Franciszków for optimal performance.
