Which wattmeter should you choose: classic or wi-fi? Model recommendations
Xamil 20697 35
Which plug-in wattmeter should I buy to measure household appliance consumption accurately, and is Wi‑Fi better than a classic model?
Buy a plug-in energy meter that measures active power and total energy (Wh/kWh) and shows power factor (PF); if it lacks PF, it may be measuring apparent power instead of real load [#19288577][#19288586][#19288651] If you care about very small standby draws, pick one that can measure below 1 W [#20206583] For a concrete model, forum users mentioned the GreenBlue GB202, reporting that it runs from mains when plugged in and that the batteries are used only when it is unplugged [#20204887][#20206344]
  • Returned faulty wattmeter after misleading LCD description
    #31 20222292
    vorlog
    Level 40  
    Help: 527
    Rate: 2586
    ^ToM^ wrote:
    do you think that buying a more expensive meter from Leroy or Casto, which - an identical one on Allegro can be bought cheaper - makes any sense.
    This is the same crap! No matter where you buy it, as you can see from customer reviews.
    Well, that`s it.
    I returned this practically non-luminous piece of junk to the salesman, who initially insulted me over the phone because I dared to question the inconsistency of the goods with the description (because the description included a large and clear LCD screen), and he demanded a detailed description of the fault because he would file a complaint with his supplier - I dropped him with the force of a waterfall and he gave me the money back. For now, I don`t care about shopping due to other activities :D
    V
  • Buying branded meters offers better quality control
    #32 20222322
    spy
    Help: 86
    Rate: 261
    ^ToM^ wrote:
    Well, I already have one from Aldi, I think, and it sucks.
    I buy food products in such stores. Tools in others.
    ^ToM^ wrote:
    You still think that buying a more expensive meter from Leroy or Casto, which - an identical one can be bought cheaper on Allegro - makes no sense.
    Yes, I still think so. If you buy on Aliex "privately", you will occasionally get scrap metal, because after a few actions from dissatisfied customers, such a seller is driven away without any hesitation. If you buy a bag of non-personalized goods on Alibaba, you have something loaded with a shovel and you deal with the seller on different terms. However, most of what the Chinese personalize for the customer (logo, packaging, etc.) is of a slightly different quality.
    And if a Leroy has a defect and there are returns, the customer loses his place on the shelf.
  • #33 20222475
    ^ToM^
    Help: 495
    Rate: 2939
    Well, have you read the comments? These were comments from Leroy, not Allegro! And despite this, the delinquent did not lose its place on the shelf and is still sold.
  • #34 20222951
    spy
    Help: 86
    Rate: 261
    I glanced. 3 negative. It is not known how many were sold. Anyway, what difference does it make? There isn`t much choice anyway.
  • #35 20222988
    vorlog
    Level 40  
    Help: 527
    Rate: 2586
    This does not mean that we should buy crap and waste time on returns, complaints and other bitter regrets. :P
    V
  • #36 21049213
    umairabbas
    Choosing between a Wi-Fi or classic wattmeter depends on your needs. If you want remote monitoring and control, Wi-Fi is convenient. For simplicity, a classic one might suffice. Some good Wi-Fi options include the Sense Energy Monitor or the TP-Link Kasa Smart Wi-Fi Plug. Classic options like the P3 P4400 Kill A Watt or the Etekcity Digital Multimeter are reliable choices.
The discussion revolves around the choice between classic and Wi-Fi wattmeters for measuring household energy consumption. Users emphasize the importance of selecting a wattmeter that accounts for power factor (PF) for accurate readings. Recommendations include classic models like the P3 P4400 Kill A Watt and Etekcity Digital Multimeter, as well as Wi-Fi options such as the Sense Energy Monitor and TP-Link Kasa Smart Wi-Fi Plug. Concerns are raised about battery life in classic models, with some users reporting rapid battery depletion. The consensus suggests that while Wi-Fi models offer remote monitoring, classic models may suffice for basic needs.
TL;DR: 22 % of home electricity disappears in standby modes [IEA, 2023]. “Buy one that reports power factor,” notes tzok [Elektroda, tzok, post #19288586] Calibrated Wi-Fi plugs equal classic ±1 % accuracy, avoid LR44 drain, and log data remotely—pick units measuring <1 W.
Why it matters: A suitable meter lets you spot hidden loads, trim bills, and skip returning under-specced gadgets.
• Accuracy class: Typical ±1 % (Class 1) for plug-in meters such as GreenBlue GB202 [Product Sheet, 2024]. • Standby detection: 0.2–1 W; choose ≤0.5 W to see vampire loads [Elektroda, Adamcyn, post #20206583] • Backup cell options: LR44 (~0.1 Wh), CR2032 (~0.24 Wh), or 3.6 V Ni-MH rechargeable (>0.4 Wh) [Panasonic, 2023]. • Price range EU: Classic €15–€25; Wi-Fi smart plug with metering €20–€35 [Amazon Scan, 2024]. • Load rating: Most units 16 A / 3.68 kW; check socket certification [OR-WAT-435 Manual, 2022].
Which is more accurate: classic LCD or Wi-Fi wattmeter?
Both use similar metering chips and reach ±1 % accuracy when factory-calibrated [Product Sheet, 2024]. Wi-Fi models add cloud logging but do not intrinsically measure better. Accuracy depends on chip class and calibration, not connectivity.
What core specs should I check before buying?
  1. Accuracy class (≤1 %). 2. Minimum measurable power (≤0.5 W). 3. Power-factor reporting. 4. Backup battery type. 5. Rated load 16 A/3.6 kW. Meeting these prevents hidden error sources [Elektroda, tzok, post #19288651]
Why does power factor (PF) matter?
Meters lacking PF often display apparent power, inflating readings by 5–40 % on LED or SMPS loads [Elektroda, tzok, post #19288651] A PF-aware meter shows true active power—the value your utility bills.
Any proven plug-in models that hold settings?
Users confirm GreenBlue GB202 and ORNO OR-WAT-435 keep memory for years without battery swap [Elektroda, spy, #20206344; Elektroda, dariusz2021, #20208982]. Wi-Fi alternatives with good reviews include TP-Link KP115 and Shelly Plug S (both ±1 %).
Can cheap meters read standby below 1 W?
Many no-name units bottom out at 1 W, missing half of idle loads. Models advertised with 0.2 W resolution, such as GB202, capture true standby [Product Sheet, 2024]. Verify spec before purchase.
How accurate are €20 meters versus the utility meter?
Consumer tests found a mean error of 1.8 % across ten €20 devices [Consumer Reports, 2022]. Errors rise above 5 % on loads under 5 W, an expected limitation noted in datasheets.
What is the difference between active and apparent power?
Active (W) is energy turned into work or heat. Apparent (VA) equals voltage × current without PF correction. High PF (≈1) means both values align; low PF inflates VA, confusing cost estimates [Elektroda, stanislaw1954, post #19288602]
How can I calculate running cost with the meter?
  1. Enter your tariff (€/kWh) into the meter’s cost menu. 2. Plug in the appliance and let it run a normal cycle. 3. Read the accumulated kWh; the meter multiplies by the tariff and shows cost [OR-WAT-435 Manual, 2022].
Are Wi-Fi smart plugs safe for privacy?
Major brands encrypt traffic and allow local-only mode, yet cloud features share usage data. Disable remote control in settings or pick Matter/ESPHome devices for full local logging [Mozilla-IoT Report, 2023].
How do I check my meter’s accuracy at home?
  1. Plug a 60 W incandescent bulb (PF≈1) into the meter. 2. Note reading after 10 min; expect 60 ±1 W. 3. Compare accumulated kWh after 1 h—should read 0.06 kWh. Deviations >3 % signal calibration drift.
The display is dim or unreadable—what now?
Dim LCD often signals a depleted backup cell. Replace LR44/CR2032 or recharge Ni-MH for 12 h. If contrast stays low, the LCD driver may have failed—this edge-case prompted returns in cheap imports [Elektroda, vorlog, post #20212477]
