Which wattmeter for 3 kW and 5 kW air-conditioning with graph in the app?
Asfaltudo 594 4
  • #1 21194787
    Asfaltudo
    Hello all, I have two air conditioners, one 3 kw and the other 5 kw. I would like to purchase a wattmeter that will tell me the current consumption of one and the other. They are plugged into separate sockets. It would be nice if it could be seen on a graph on the app. Are you able to help me?
  • #2 21197869
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    You have a lot of devices in the Tuya environment. You can also use meters from Zamel, e.g. LEW-01 etc. in the Supla environment.
    You can also do it your own way, e.g. by setting up a server on Debian, and save the data to the Influxdb database and display it in Grafana. However, you have to figure it all out yourself.
  • #3 21216461
    Asfaltudo
    Ok, I would be more interested in a meter where I can plug into a contact. All I've seen max 3600 watts, do you happen to have something that can handle a 5kW air conditioner?
  • #4 21216538
    Ture11
    Help: 573
    Rate: 1130
    Asfaltudo wrote:
    conditions 5 kW
    5 kW is the heat output or the power consumed? Mostly a 5.2kW air conditioner draws about 1.6 kW from the mains.
  • #5 21219446
    Asfaltudo
    Actual heat output, I hadn't come across that, do you have anything you can recommend?
