Halny 4GQV Router for 500Mb/s Fiber Optic Connection: User Experiences and Reviews
Jimi_Latex 23979 19
Is the Halny 4GQV router good enough for a 500 Mb/s fiber connection with several wired devices and Wi‑Fi at home, or should I buy my own router instead?
The Halny 4GQV should be enough for a standard user, but if you want full control, bridge mode, or stronger Wi‑Fi coverage upstairs, it is better to use your own router and possibly additional access points [#19424839][#19425032][#19425318] The operator’s device may be limited or locked down, so before deciding you should check whether you get full access to its configuration, whether bridge mode is available, and whether you have a public IP [#19425032] Halny routers were described as good, and one lower 300 Mbit model was said to handle 3 computers easily [#19423842] However, Wi‑Fi range depends much more on house layout and placement than on the router alone; a garage location is unfavorable, and if you want good coverage on both floors you may need 2–3 wired APs [#19424932][#19424839]
  • Asking whether Halny 4GQV is enough for 500 Mb/s fiber
    #1 19423795
    Jimi_Latex
    Rate: 15
    I wanted to ask if anyone heard anything about Halny routers?
    I connect the fiber to the 500Mb / s home and the supplier offers me such Halny 4GQV equipment
    The offer is good because I don't have to pay anything for it.
    At home, 2-3 computers on the cable plus a TV, plus a few wifi devices.
    Link to the router description
    https://halny.com/portfolio/gpon-ont-with-4x4...werful-wireless-voip-and-4-gigabit-lan-ports/
    I was going to buy a router in the range of PLN 300-450, if it would be much better, I will consider this option.
    Thanks
    Piasek80
    Help: 129
    Rate: 666
    Good routers. I have a lower model in the 300Mbit option and it easily covers 3 computers
  • #3 19423857
    KOCUREK1970
    Help: 3863
    Rate: 5493
    Just because you don't pay for it doesn't mean the offer is worth your attention.
    The operator's equipment is often neutered, cut off or blocked access to the terminal at all, you won't set anything, you won't change anything ...
  • Requesting router recommendations in the 300–450 budget
    #4 19423877
    Jimi_Latex
    Rate: 15
    I know that, and that's why I wonder. If it works fine, I'll stay with it.
    What would you suggest in a budget of 300-450?
  • Bridge mode or ONT needed for a second router
    #5 19424759
    IC_Current
    Help: 1499
    Rate: 2523
    Nothing, because you cannot install two routers in one network, because advanced network services will stop working, e.g. you will not play games on the console, VPN will have problems or VoIP will not work together.
    If you want your router, you need to get an ONT terminal or a router set to bridge mode from the operator.
    In addition, a router that fully supports the 500Mbps connection costs a minimum of PLN 500.
  • Requesting router models for 500 Mbps fiber under 500 PLN
    #6 19424774
    Jimi_Latex
    Rate: 15
    1. I was not going to assemble two routers
    2. I will test how it works, and maybe I'll make a decision to give it back and buy my own.
    3. How is it that the operator provides a 500Mbps link and gives equipment that does not use it? For me, it's a scam - but that's a separate topic.
    4. I am asking for specific models of routers for this connection speed at this price of PLN 500
  • Cheaper routers can handle 500 Mb/s with proper setup
    #7 19424783
    mick1
    Help: 47
    Rate: 118
    A very far-reaching simplification. Shouldn't - fact, but can't?!?
    What advanced network services will stop working? Why can't I play games on the console? VPN is flashing too, and even VoIP is stacking up. A matter of a bit more complicated configuration.
    I dare to say that now much cheaper routers with 500Mb will do.
    Even HEX from mikrotik for half of that PLN 500. Or, how should it be with Wifi, then hAP AC (or higher)
  • ONT required for fiber router replacement
    #8 19424795
    IC_Current
    Help: 1499
    Rate: 2523
    IPSec does not work without NAT-Traversal and no other VPN where authentication is made using an IP address.
    VoIP works depending on the operator and the possibility of forcing the client to send a periodic packet maintaining the open NAT session.
    Multiplayer games only work if you add the console to DMZ on both NAT routers. Unless the game uses a proxy.
    A colleague Erbit did microtik tests recently and it turned out that cheap devices do not cope at all, unless a simple speedtest with one or two sessions but not for smaller packages and several sessions.
    Jimi_Latex wrote:
    I will test how it works, and maybe I will make a decision to give it back and buy my own.
    You will not test anything, because with optical fiber the operator authorizes ONT terminals in your OLT and you will not install anything else. The operator's device must be. You want your router, you must immediately ask for an ONT terminal or the ability to convert the operator device to bridge mode.
    This is of course a fact, but a user who asks for a router and does not know that he must have an ONT can handle the configuration of multiple NAT so that everything works as it should?
  • Need ONT or bridge mode for router setup
    #9 19424823
    Jimi_Latex
    Rate: 15
    Could you have a look at the link of the operator's equipment that I pasted above and assess whether such something is enough for a standard user.
    The router will hang in the garage which is in the same building as the house. This is also where all cables from individual rooms come out. I want a good wifi signal on the upper floor.
    Bridge mode won’t improve upstairs Wi‑Fi coverage
    #10 19424839
    IC_Current
    Help: 1499
    Rate: 2523
    Jimi_Latex wrote:
    Suppose they agree to the bridge mode? What benefits will I get from this.
    If you do not know what the benefits of bridge mode and your own router are, it just means that the operator's equipment is completely sufficient for you.
    Even if you have equipment for tens of thousands, you will not have coverage (with high bandwidth) on the floor. Each WiFi's transmit power is legally prescribed and the same for all devices. The differences are cosmetic. If you want good coverage, you need to add additional access points in several places in your home and connect them with a cable to the main router.
  • NAT limitations affect IPsec, VoIP, and gaming
    #11 19424903
    mick1
    Help: 47
    Rate: 118
    In the sense, port forwarding and packet forwarding do not exist?
    As above
    DMZ in this case? I would be afraid. Works without, proven.
    They can handle bandwidth - and that's what we talked about. It's obvious that the more services (ports, packets, maybe encryption, maybe peering into frames due to L4-L7 operations), the less efficient EVERY router will be.
    Will a user operating this way use IPsec or VoIP?
    But you're right, it may have a configuration problem. Nevertheless, the sentence that you cannot - is still far from true.
  • Garage placement will likely require extra access points
    #12 19424932
    Keep the router and add a critical access point
    #13 19424982
    mick1
    Help: 47
    Rate: 118
    _cheetah_ wrote:
    It is possible that you would be lucky after all and you will set up WiFi connections all over your home on low-speed clients. But if you would like to have wifi really fast both on the ground and upstairs, you might need two or three additional APs ...
    I love it, someone wise will come and write the obviousness that I scratch my head and think why I didn't think about it myself - and by the way, probably the best solution in this situation.
    Leave the router that is there and put the AP in a critical place. No second router.
  • #14 19424994
    Jimi_Latex
    Rate: 15
    This is an example AP, please
    Verify terminal access, bridge mode, and public IP availability
    #15 19425032
    KOCUREK1970
    Help: 3863
    Rate: 5493
    Jimi_Latex wrote:
    I was not going to install two routers
    But the opa router has to stay, and there is nothing to configure there, because usually optical fiber operators do not give access to their terminals.
    You want any configurability for yourself, you have to buy your router and put the router into bridge mode.
    Jimi_Latex wrote:
    How is it that the operator provides a 500Mbps connection and gives equipment that does not use it? For me, it's a scam - but that's a separate topic.
    Internet works for you, www works, wp or other e-mail works, the link is supposed to have, so the equipment is perfect - this is what the operator is interested in, some settings for the client and who is interested in it.
    Therefore, to begin with, verification:
    - do you have full access to the optical terminal for configuration at all,
    - does this equipment have a bridge operation at all,
    - do you have any public IP available there?
    Your further journey with the next equipment depends on these answers.
  • Clarifying whether AP choice affects performance
    #16 19425203
    Jimi_Latex
    Rate: 15
    S cool. So, for the time being it is holding back so to speak. I am starting to use it in a few weeks, I ordered the connection faster so that I would not wait in line.
    I will investigate, check what and how and then I will keep asking and asking what to do to make it good.
    Does all that you mentioned also depend on the possible AP?
  • #17 19425263
    IC_Current
    Help: 1499
    Rate: 2523
    And your friend knows that some VPN and VoIP dynamically sets up incoming connections on random ports, even sets up two or three sessions for other traffic, so how would you like to redirect these ports?
    Just because it works for you and you use the most basic functionalities doesn't mean that everything else works.
    Bridge mode enables separate router and AP setup
    #18 19425318
    KOCUREK1970
    Help: 3863
    Rate: 5493
    By all means, because depending on "what comes out in the wash", you will buy either a router with wif, which is also an AP, or a typical AP without routing.
    The best option if: the opa terminal could be switched to the bridge mode (then the op can block access to its device), was a public IP - all this has its own router and possibly also an AP, as there is not enough wifi signal somewhere. In such a system, you decide what, how, where and how you create your own network at home.
  • Unifi stable recommended for easy configuration
    #19 19425364
    mick1
    Help: 47
    Rate: 118
    I don't know if you are trying to defend your mind now, if you don't know how opening sessions on "random" ports works and what the handshake does, but let's establish that you are right, and I am just checking one of the systems for double NAT (because otherwise there is no way) via vpn ;)
    To the author:
    Anything from the unifi stable (because it's easy to configure and nice)
  • Multiple NAT works for gaming, VoIP, and VPN
    #20 19639349
    batot
    Rate: 68
    crap - everything works.
    Even more crap - Multiple NAT works on all routers.
    You don't need a DMZ.
    Of course, there are exceptions, such as PS3 if I remember correctly Sony "badly implemented" NAT support in the device and did not work with some routers without additional redirections.
    Everything behind multiple NAT works by default.
    Another load of rubbish - in my 25-year career I have not encountered a router with a network router that would not cope with multiple nat.
    Every ONT router I had in my hands also dealt with multiple NAT - it's not a network freak, but normal operation.
    Of course, each operator can impose restrictions within its network causing the above-mentioned inactivity, however, without restrictions in the network ALL the above-mentioned services work properly.
    Buddy @IC_Current, please, if you have such nonsense to write out, delete the description of an IT network specialist in your nobody, because it stuns the eyes with ignorance.
    I'm sorry but I had to react sharply if someone thinks he is a specialist and writes such nonsense.
    Network specialist / administrator with 25 years of experience.
    Regards in peace.
    Added after 5 [hours] 26 [minutes]:
    Managed to?
    I don't see any obstacles for it not to work.
    Dynamic? What a problem, after all, NAT does a dynamic translation "imperceptible" to the recipient.
The discussion revolves around the Halny 4GQV router offered by an internet service provider for a 500Mb/s fiber optic connection. Users share their experiences, with some noting that the router performs adequately for basic tasks, while others express concerns about potential limitations due to the operator's equipment being "neutered" or lacking configurability. The importance of bridge mode for advanced networking and the need for additional access points for better WiFi coverage are emphasized. Recommendations for alternative routers within a budget of PLN 300-450 are also provided, with suggestions including MikroTik and UniFi devices. The conversation highlights the necessity of understanding the operator's equipment capabilities and the implications for home networking.
TL;DR: Halny 4GQV can serve typical fiber homes, but placement is critical; "its location in the garage is unfavorable" and Wi‑Fi emission can vary by >20 dB. Add wired access points for fast upstairs coverage. This FAQ distills user-tested tips on bridge mode and double NAT. [Elektroda, Anonymous, post #19424932]
Why it matters: It helps you decide between keeping the free ISP router, asking for bridge mode, and adding wired access points.
Is the Halny 4GQV good enough for a 500 Mb/s fiber plan?
Yes for wired devices. The 4GQV provides four Gigabit LAN ports, eliminating 500 Mb/s bottlenecks on Ethernet. It also integrates 4x4 5 GHz and 2x2 2.4 GHz radios for higher local throughput. Wireless speed still depends on client capability and placement. “GPON ONT with 4x4 5GHz and 2x2 2.4GHz”
Will my ISP lock the Halny router, and what does that limit?
Many ISPs lock or limit customer access to their fiber terminals. You may find features disabled or hidden, with no admin privileges. In that case, you cannot change Wi‑Fi or routing parameters. The device still delivers basic internet and VoIP. [Elektroda, KOCUREK1970, post #19423857]
How can I use my own router with fiber?
Ask the ISP for a standalone ONT or bridge mode on their device. The ISP authorizes ONTs on the OLT, so unapproved hardware will not register. In routed mode, you cannot fully replace the ISP box. Bridge mode lets your router handle NAT and features. [Elektroda, IC_Current, post #19424795]
Can I run two routers (double NAT) without breaking things?
Yes, it can work. “Multiple NAT works on all routers.” You usually do not need DMZ. Operator restrictions can still break specific services. Keep configurations simple if you stack routers. [Elektroda, batot, post #19639349]
Why is the garage a bad place for the router?
Garage placement wastes RF energy. Only a smaller part of the signal can reach the house, even as low as one quarter. Emission power at the receiver can vary by more than 20 dB. You may need two or three wired APs for fast rooms. Place Wi‑Fi closer to where you use it. [Elektroda, Anonymous, post #19424932]
How do I extend Wi‑Fi upstairs the right way?
How‑To: Add a wired AP upstairs
  1. Run an Ethernet cable from the ISP router to the upstairs AP location.
  2. Set the new device to Access Point mode and connect via Ethernet uplink.
  3. Place it in the critical area to fill coverage gaps; no second router. [Elektroda, mick1, post #19424982]
Which affordable routers handle 500 Mb/s well around PLN 300–450?
User‑suggested picks exist. For wired routing near 500 Mb/s, consider MikroTik hEX. If you also need Wi‑Fi, consider MikroTik hAP ac or higher. Their value is strong below PLN 500. Keep firmware current during setup. [Elektroda, mick1, post #19424783]
What should I verify with the ISP before adding my own gear?
Check three items. Do you have full admin access to the optical terminal? Does the device support bridge mode, and will they enable it? Do you receive a public IP? Your choices depend on these answers. [Elektroda, KOCUREK1970, post #19425032]
Will gaming consoles and VoIP work behind double NAT?
They can. DMZ is not required in typical cases. “Of course, each operator can impose restrictions” that block some services. Edge case: some older PlayStations had NAT issues with certain routers. Test and adjust port rules if needed. [Elektroda, batot, post #19639349]
Can one Halny 4GQV cover two floors at high speed?
Do not expect strong multi‑floor throughput from one router. Transmit power is legally fixed for all devices; differences are cosmetic. For high bandwidth upstairs and in rooms, add cabled access points. Expensive routers cannot overcome these limits. [Elektroda, IC_Current, post #19424839]
Is the free ISP router good enough for a typical user?
Often, yes. “The operator's equipment is completely sufficient for you” if you do not need advanced features. Keep it, then add APs for coverage as needed. Upgrade later if your requirements grow. [Elektroda, IC_Current, post #19424839]
Any real user reports on Halny performance?
Yes. One report says a lower Halny model on a 300 Mb/s plan handled three computers easily. That suggests solid baseline performance for similar wired loads. Actual Wi‑Fi reach still depends on your building and placement. [Elektroda, Piasek80, post #19423842]
