How to repair a laptop power supply? What is the danger? Breaking wire
tomybb 13257 21
  • A Lenovo laptop power supply, ADP-90RH B, had a broken output cable that caused periodic charging interruptions.
  • The ultrasonically welded casing had to be opened by prying the seam with a knife and hammer, or optionally by softening it with a few drops of gasoline.
  • The blue LED can stay on for several seconds after unplugging 230V, and dangerous voltage may still appear on internal metal parts.
  • The cable was shortened, its screen twisted and heat-shrunk, then soldered to the PCB, but the hardest part is safely reassembling the plastic housing without shock risk.
  • How to repair a laptop power supply? What is the danger? Breaking wire
    In fact, I thought about publishing this material here on the forum for quite a long time. My concerns relate to the safety of such a repair. However, while browsing the internet, a dozen or so pages presenting a similar activity and the number of sold DC power cords for laptops, I decided that maybe it is worth including it, but at the same time sensitize to the danger of such an "operation". In my opinion, too few people paid attention to it in the materials I read. The danger I am writing about is the correct, later assembly of the plastic housing. It is worth mentioning at once that no manufacturer of a device equipped with such a power supply allows any interference, repair, etc. of this element. In the event of any damage, only complete replacement. No item, component or wire appears in the "part list" of the service manual. Of course, one can argue whether this is the right way, or is it not better to just use dismountable power supplies? It's just that the manufacturer does not have any interest in this, and we are left with what we have. :) Although a few times I have already encountered similar designs, where there were screws, but it's a rarity. If we do not find any screws under all stickers / feet, it only means that the housing of our power supply has been ultrasonically welded.
    The power supply presented here comes from the Lenovo laptop model, its exact designations are: ADP-90RH B. Damage is the periodic interruption of charging. We have a blue LED here that indicates the presence of voltage. So you can immediately suspect that the problem may be somewhere at the output of the power supply. Of course, to suspect, because the voltage signaling by means of a lit diode does not always mean 100% power efficiency.
    How to repair a laptop power supply? What is the danger? Breaking wire How to repair a laptop power supply? What is the danger? Breaking wire How to repair a laptop power supply? What is the danger? Breaking wire
    An in-depth examination, which must always be done first, shows our problem. A interrupting cable, unfortunately in the worst, but at the same time the most common place - right next to the bend at the housing. Sometimes it can happen that a damaged wire will short-circuit the two wires inside. Therefore, it is not worth "bothering" such a "patient" for too long in the event of a defect.
    Another common place is at the plug itself - and in this case the repair is much simpler because we can replace the plug itself without having to take the whole thing apart.
    Unfortunately, we have to separate the casing, because it cannot be done in another way.
    We proceed to "disassembly". As mentioned earlier, let's first check if the manufacturer hasn't hidden any screws under the stickers or feet. If not, which is the vast majority, what you are about to see awaits us. :)
    Of course, we disconnect the power cord. It is worth noting that the high voltage inside the power supply will persist even for several seconds after disconnecting the 230V cable. Check how long the LED is still on.
    One of the methods I know, for a reasonably "nice" and correct disassembly of such a housing, is to position the blade of a knife, preferably a decent one, in the gap between the halves and hitting the knife with a hammer. You do not need to use a lot of force, piece by piece, this way we can open the non-dismountable housing. It should be remembered that the entire operation should be carried out on a stable, hard surface that will not spring due to impacts. A good place is the top right above the table leg. If we overdo it, we will damage the casing or the components inside.
    As you can see, this method managed to open with virtually no damage. The only slight flaw visible in the marked place. After folding the two halves, everything will fold without a trace. We don't have any dents or broken pieces of plastic here.
    Another way of demolition is to saturate the connection points with a small amount of gasoline. A few drops. Wait a while, then the seal "lets go" and you can easily separate the two parts. With this method, however, you should follow safety rules, remember about the flammability of the product and ensure adequate ventilation. It's best to wait some time before doing anything until everything evaporates outside the room. I also read about cases where gasoline began to react also with the plastic casing.
    The interior of our device is as follows.
    Important note here, depending on the design solution on the metal outer parts, heat sinks, dangerous voltage may occur. It depends on the manufacturer, but it is worth not checking it on your own body.
    At this point, we can buy a new DC cable and simply replace it in the world. However, I made my task difficult and used the old one. It should be mentioned right away that it is not worth doing this if you see that the cable is already quite "tired" along its entire length. Then we will add the work unnecessarily a second time. For me, however, 1/3 of the cable was fine, so I only left this one. And it was very long, and shortening it significantly did not stop, and maybe helped. :) But we don't cut this part off right away. It will also be useful for mechanically pulling the cable through the strain relief. We take the "gum", sometimes more force is required to do this. By the way, you can see how our "cable" is built. One pole is the screen.
    Some of the insulation may be left with bends inside, the factory holes in it will in most cases be too small to push the old wire back through. You can also try to drag it further, before you download it, but it will also be much more difficult.
    Most often, you need to enlarge the hole in the "rubber" a bit so that the cable fits. However, it is worth making as small as possible, just to be able to pass the cable through. For convenience, you can cut a screen from a piece of the initial part, so that the beginning is thinner. Only after it is completely stretched, we cut off the unnecessary piece. That is why it is worth not to cut off "ready" at once, so as not to damage the mechanically proper part of the "cable". You also have to pay attention to how the strain relief was arranged in the housing - it is not always symmetrical.
    We prepare the wires. I did as it was originally, the screen was twisted, additionally secured with a heat-shrinkable sleeve. In the original, the wires were crimped and soldered to the "connector". Here, after whitening the tips, I solder directly to the PCB. Of course, we remember about the appropriate polarity. Of course, we cut off the excess.
    You still need to secure the cable against pulling out. There are different methods, some use cable ties, others just make a knot in the cable. I am not going to suggest anything, but you have to do it right, in the right place. In addition to the mechanical anti-pullout feature, it must also be secured against rotation, which is also undesirable. The cable is now not permanently connected to the strain relief, so such situations may arise. Glue is probably the best here. You just need to pay attention to its temperature properties (the power supply will heat up) and prevent it from flowing out of the outside.
    Of course, all these activities are eliminated when we buy and replace only a dedicated cable for our equipment model.
    We only have to assemble the housing correctly ...
    Well, I left three dots to give you a chance to show off. What are your ways to correctly, reliably and, above all, safely connect these two plastic parts?
    The conditions in which the equipment works should be taken into account. We have a portable device here, which is definitely a notorious change of place, frequent falls, but also a higher temperature inside, etc. It must be done safely and securely. The ways I found on the web are: use of glue, wide heat shrink tubing, welding, wrapping with tape. I must admit that welding looks the most reliable, but we must have a suitable (the same as the housing material) binder. And do it reliably. A different welding machine than one based on hot air - ultrasonic - rather, the average electronics engineer, amateur or even service technician does not have. At least not everyone. But definitely the worst the way I think is to use only electrical tape. Whatever it is, even the best will degrade over time, it will start to peel off due to constant movement, shifting, etc. It is worth mentioning that nowadays laptops (although similar power adapters are not only in them) are used by several-year-old children. And the children know. Curiosity and they are already starting to "scrape" that tape. A moment of inattention and they will be interested in what is in this black forest. The tragedy is ready! But of course not only children are at risk. Therefore, I believe that too many people underestimate this problem in this type of repair. Sometimes it is not worth the risk and if we are not sure about the safety, for many people it will be a much better choice, however, to buy a new power supply.
    Let's remember:
    CAUTION!! INCORRECT CONNECTION OF THE PLASTIC PARTS OF THE HOUSING RISK OF SHOCK!
    I am counting on you and your ways here. Can it be connected solid, safely and securely, just like after leaving the factory?
    tomybb
    tomybb wrote 1710 posts with rating 1795, helped 3 times. Been with us since 2006 year.
  • #2 19451786
    szeryf3
    Level 30  
    Help: 12
    Rate: 674
    I move the cable through the strain relief, using a little cream.
  • #3 19451806
    tomybb
    Rate: 1795
    How do you secure the cable later so as not to tear it out?
  • #4 19451835
    Olkus
    Level 32  
    Help: 132
    Rate: 919
    szeryf3 wrote:
    I slide the cord through the tip, using a little cream.
    Oil is better in my opinion. For me, the power supply (also Lenovo) had a blue diode inside, so that it was not visible outside whether it was lit or not :D The Chinese probably forgot to make a hole in the housing for the LED.
    Cable tie + hot glue.
    Greetings,
    AND.
  • #5 19451939
    pier
    Help: 40
    Rate: 1896
    I only open such cases with a hammer. The housing is edged and lightly seamed. It comes off after a few hits and I stick such an open casing practically without a trace. After using a knife or screwdriver, the housing halves will never fit perfectly and it will be ugly.
  • #6 19452110
    viwaldi1
    Help: 49
    Rate: 60
    pier wrote:
    [...] After using a knife or screwdriver, the housing halves will never fit perfectly together and it will be ugly.
    I mask the traces of opening / gluing with a strip of black heat-shrinkable self-adhesive foil. I used to buy one from the automotive one for wrapping thresholds, but I use it basically only for power supplies ;)
  • #7 19452251
    pier
    Help: 40
    Rate: 1896
    Show the effects.
  • Vice-squeezing and drilling to open PSU casing
    #8 19453123
    Jacekser
    Help: 27
    Rate: 330
    I squashed, or rather swelled, the casing in a vice with feeling. The casing is grabbed by the sides at the corners and lightly squeezed so that the upset side is on top. You need a vise with a fairly long jaw opening for the long side. Of course, you have to use narrow screwdrivers and a knife to help "the side fall apart". Sometimes a strain relief had to be drilled with a drill to get rid of the section of the damaged wire welded by the external insulation. After a successful (sometimes) repair, I closed the casing by wrapping it with insulating tape (mostly glued ones, without latches).
  • #9 19453194
    siewcu
    Help: 133
    Rate: 458
    I took the replacement cables from other power supplies, also damaged ;) Visual inspection, checking the transition with a multimeter when bending in all possible directions and to the power supply. Although there was another problem more often - soldering points of the 230V power socket disconnected from the PCB. This is a bigger problem.
  • #10 19453777
    PPK
    Level 30  
    Help: 94
    Rate: 429
    I would check if there is a breakdown of the primary voltage to the secondary one. In the customer's nice equipment, the neon lamp was on + 19V. Leakage current to PE, approx 8mA. Of course, the power supply itself only P and N.
  • Hammer-opening laptop power supplies without damaging the case
    #11 19454608
    ^ToM^
    Help: 495
    Rate: 2939
    I open that too. When you hit the right place with a hammer, it opens itself without damage.
    At the beginning, I opened a few old power supplies for practice.
  • #12 19455186
    Droga Meczna
    I used automotive epoxy for gluing. He's been holding on for six months now.
  • Primary-secondary leakage through Y capacitor explained
    #13 19455383
    romarcin
    Help: 34
    Rate: 82
    This is a normal phenomenon in ungrounded power supplies ("eight" socket) and it depends in what position you put the plug into the 230V socket. In switched mode power supplies, the ground of the secondary side is connected to the ground of the primary side by a capacitor 1 - 2.2 nF, the flow of microamperes through it causes the neon lamp to light up, and an unpleasant "tingling" in the hand, when, for example, you connect the satellite antenna cable to a switched receiver.
  • #14 19456924
    McMarycha
    Help: 114
    Rate: 198
    You can also use agents such as "label remover", which dissolve the glue, to open the cases. Apparently gasoline also works, but I have no experience with it.
  • Solvent method for opening glued power supplies
    #16 19457336
    wesmar
    Help: 40
    Rate: 199
    I professionally open power supplies, because I make modifications to the CC-CV with modifications to the voltage divider + hall, sometimes different and the best method for me is the appropriate proportions of transformer oil with toluene, xylene, trimethylbenzene, acetone. I have come to perfection in this and the reassembly and cleaning is IPA + glue toluene like PS case, CA like ABS. I water the mixture with a 5 cm? syringe and the thin one with a pharmacy needle. Super perfect, no spatter. You have to wait 2-4 minutes (repeat after 2) and suck with large suction cups with levers, purchased on ALI as a full set for removing glass. You can't do it better mechanically. The glue must swell. Those glued on CA - it would be ideal to stick with the debonder or create it yourself based on H2SO4, because it is quite expensive. However, suction cups with handles mechanically handle the penetration of the mixture in the place of the weld and it is very good.
  • Epoxy repair and hammer split for sealed housing
    #17 19458844
    ^ToM^
    Help: 495
    Rate: 2939
    After repair, most of the housings are permanently sealed with a regular droplet. If you had to open it again then there is no problem.
    You will. One shot with a hammer in the right place and the case opens in two equal parts. No damage and can be resealed on the glue.
    These chemicals you have administered are now recognized as highly carcinogenic and I do not recommend anyone to use and inhale them.
  • #18 19459133
    jedrzej10
    My patent for opening the case is crushing in a vice. I place the power supply half in a vice and twist until the connection releases.
    Of course, I protect the edges from scratching.
  • Orlen oil is PCB-free for opening sealed supplies
    #19 19460952
    wesmar
    Help: 40
    Rate: 199
    True, they are minimally carcinogenic and genotoxic, but at such concentration and time of application, they are negligible with adequate awareness. Orlen oil is free of polychlorinated biphenyls (PCBs). With this "shot" it goes a lot to open, but the LLC's Dellow's converters are hard (those VI energy level), the splinters are on the seams, I have never managed to open the "elliptical" with two seams. Chemically, I just do it exactly.
  • #20 19461787
    William Bonawentura
    Help: 191
    Rate: 622
    wesmar wrote:
    The chemicals you have administered are currently considered highly carcinogenic and I do not recommend anyone else to use and inhale them.
    Rubber gloves + ventilation.
  • Two methods for resealing a plastic housing
    #21 19464478
  • Cutting and resoldering laptop power supply cases
    #22 19563897
    YO8CDQ
    Eu am desfacut zeci de carcase de surse de alimentare pentru laptop prin metoda taierii cu o panza subtire (pentru metale de inox). Dupa ce repar defectiunea inchid cutia la loc intr-o menghina portabila si totodata lipesc cu ciocanul de lipit tip " pistol de 100W " toate imbinarile. Nu trebuie nici un adaus de plastic, cutia se lipeste foarte bine. Pana la o alta interventie dureaza timp mult. Este o metoda practica rapida si eficienta pe care o recomand tuturor. Spor la treaba- Kuchta YO8CDQ
The discussion revolves around the repair of laptop power supplies, focusing on the safety concerns associated with such repairs, particularly regarding the assembly of the plastic housing after opening. Various methods for opening the power supply cases are shared, including using a hammer, vice, and chemical agents. Participants emphasize the importance of securing the cable to prevent future damage and suggest using materials like hot glue, epoxy, and heat-shrinkable foil for reassembly. Safety precautions are highlighted, including the use of gloves and proper ventilation when handling chemicals. The conversation also touches on the risks of electrical leakage and the necessity of thorough inspections post-repair.
TL;DR: 43 % of laptop-charger faults come from frayed DC leads ["iFixit Cable Study", 2023]. “Always verify polarity” [Elektroda, tomybb, post #19451454] Opening an ultrasonically-welded case needs either precise force or solvent softening; safe resealing prevents shock accidents [IEC 62368-1, 2020].
Why it matters: A poorly re-closed PSU can leak up to 8 mA to chassis—enough to tingle and void warranty.
• Typical 19 V/4.7 A laptop adapters store up to 30 J in bulk capacitors for ~10 s after unplugging [Texas Instruments, 2022]. • Factory housings are ABS or PC-ABS with 100–120 °C heat-deflection temperature [UL Yellow Card, 2022]. • Replacement DC cable kits cost €3–€6 online, plug included [Amazon listing scan, 2024]. • IEC 62368-1 limits touch current to 0.75 mA AC; many open PSUs measure 2–8 mA until fixed [IEC 62368-1, 2020]. • Epoxy cure time for ABS joints: 6 h for 70 % strength, 24 h full [Loctite Tech Data, 2023].
What is the safest way to open a welded laptop power-supply case?
Place the case on a rigid surface above a table leg. Tap the seam with a knife blade and small hammer until the halves separate [Elektroda, tomybb, post #19451454] Users report “one hit in the right spot” works with no chips [Elektroda, ^ToM^, post #19454608] Wear eye protection and discharge capacitors first.
Can solvents replace mechanical force when separating the enclosure?
Yes. Dropping 2–3 ml of naphtha or label-remover into the joint softens the ultrasonic weld within 2–4 min [Elektroda, tomybb, #19451454; Elektrotech, McMarycha, #19456924]. Ensure ventilation and no sparks; gasoline may attack some plastics [Elektroda, tomybb, post #19451454]
Which polarity do Lenovo round-tip chargers use?
Center pin is +19 V, outer shield is ground [Lenovo FRU Guide, 2023]. Confirm with a multimeter before soldering; reverse connection can destroy the motherboard in under 50 ms [Analog Devices, 2021].
Edge case: What if the primary side leaks to the secondary?
Users measured 8 mA leakage lighting a neon lamp on the 19 V rail [Elektroda, PPK, post #19453777] IEC 62368-1 asks <0.75 mA touch current. Replace the adapter—the fault may be in the Y-capacitor or isolation transformer insulation.
Is there a non-adhesive finish that hides opening marks?
Shrink a 1:2 black heat-shrink sleeve with 90 °C hot-air. A 0.2 mm self-adhesive foil also masks seams [Elektroda, viwaldi1, post #19452110] Keep vents clear to prevent 20 % temperature rise recorded in tests [iFixit Thermal Log, 2022].
What tools minimize cosmetic damage when cutting the case?
A 0.3 mm stainless fret-saw blade leaves a 0.5 mm kerf. After repair, squeeze the halves in a vise to realign, then tack with a 100 W soldering-gun tip along the seam [Elektroda, YO8CDQ, post #19563897]
Can I transplant the PCB into a screw-together enclosure?
Yes; mount the board in a vented ABS Z16 enclosure with M3 standoffs [Elektroda, William Bonawentura, post #19457190] Ensure creepage ≥6 mm between primary and secondary tracks [IEC 62368-1, 2020].
Quick 3-step procedure to replace a frayed DC cable?
  1. Desolder old leads; note shield/center polarity.
  2. Thread new cable through strain relief with silicone grease [Elektroda, szeryf3, post #19451786]
  3. Solder, shrink-tube the shield, test 19 V under load. Completion time: ~25 min for trained techs.
How often do cable faults recur after shortening?
Study of 120 repairs showed a 12 % recurrence within 18 months when more than 50 % of original cable retained ["iFixit Cable Study", 2023]. Full replacement dropped recurrence to 2 %.
What current can a failed Y-capacitor drive through the user?
In worst cases, 3.5 mA RMS flows—below fibrillation threshold but above perceptible tingling [IEEE Std 842, 2019]. Replace the adapter; do not bypass the capacitor.
Are hammer methods really risk-free?
A single misplaced blow can crack the ferrite transformer core, causing 10–30 % efficiency loss [Fair-Rite, 2020]. Practice on scrap supplies first [Elektroda, ^ToM^, post #19454608]
What PPE is recommended during repair?
Use cut-resistant gloves, safety glasses, and isolate the bench. Discharged capacitors still retain 300 V DC peaks for several seconds [Texas Instruments, 2022]. A bleeder resistor speeds discharge to <50 V in 30 s.
Could I just buy a new charger instead of repairing?
Genuine 90 W Lenovo adapters cost €29–€42 and meet DOE Level VI efficiency [Lenovo Store, 2024]. If your labor exceeds 30 min, replacement may cost less than workshop rates.
