[Solved] Electrolux PNC 91153607801 - [Solved] Electrolux TT702 - heat up only on short
mmatkovi 1254 1
  • Beko 32 mm tachometer coil fixed id0 id1 errors
    #1 19460182
    mmatkovi
    similar problem solved in an older topic from 2017. has helped me to solve the same symptoms, but on dishwasher which has tachymeter integrated with recirculation pump. There is no possibility to order only tachymeter. Complete pump with tacho costs about 120€.
    Error codes are id0, id1, id0.
    Solution:
    - cut the wires
    - tachymeter out, diameter 32 mm
    - tachymeter shows 235 to 478 oms, every time different numbers (which is bad).
    - bought 32 mm Beko tachymeter 372205505 (tacho coil with metal shell(compagnaro)) which shows resistance of 93 oms.
    - wires soldered
    - everything works
    Beko tacho cost is 7.6 € vs 120€ pump with tacho.
    Was lucky to find a store willing to measure diameter for me (told them that resistance is not important).
    #2 19460189
    mmatkovi
    Solution:
    - cut the wires
    - wires soldered
    - everything works
    Post contains solution.
