[Solved] Electrolux ESL66010 - does not dry and heat up the tacho coil, how to replace it
kingsmal 17166 20
How do I replace the riveted tacho coil in an Electrolux ESL66010 dishwasher?
You need to drill out the rivets to open the holder and get to the coil; the coil itself is also retained by four folded sheet-metal tabs, and on reassembly you can glue it back or rivet it again [#16602252] In practice, the replacement is simple once the circulation pump is removed: pry out the old coil, press the new one in, and then reassemble everything [#16754428] Several users reported that this fixed the no-heat/no-dry symptom, even when the original coil measured around 200 Ω and seemed electrically OK [#16754428][#17479734][#19020603] Before replacing it, though, other replies recommend checking the thermostat, heater, heater relay, and reading the service error codes first [#16299853][#16299934][#16602666]
  • #1 16297572
    kingsmal
    The dishwasher does not dry and heat up. According to the advice on the forum, I bought a tacho coil. Unfortunately, there is a problem how to replace it? It looks like the part that holds it in place is riveted. How to open the case to get to the coil?
    Electrolux ESL66010 - does not dry and heat up the tacho coil, how to replace itWP_2017022...05_Pro.jpg (1.82 MB)You must be logged in to download this attachment.
  • #2 16299853
    domis33
    Help: 13
    Rate: 218
    I would rather check the thermostat
  • #3 16299934
    zibi1971
    Home appliances specialist
    Help: 262
    Rate: 1118
    Start with simpler matters: relay, heater. Enter the service mode when id0 pops up, then after checking the other elements you can cling to the tacho coil.
  • #4 16300645
    peter falk
    Help: 1158
    Rate: 3356
    kingsmal wrote:
    does not heat.
    Cold water or slightly heated?
  • #5 16602252
    maymar
    Unfortunately, you need to drill these rivets to get to the coil. The coil itself is also kept in this basket by 4 folded pieces of sheet metal from the basket. Reassembly is just glue or try to rivet (I glued) ...
  • #6 16602666
    zibi1971
    Help: 262
    Rate: 1118
    It will be funny if it is not a tacho coil, the basis is reading the error code
  • #7 16647712
    raczkow
    Rate: 16
    How does the tacho repair (replace) result?
    Recently, I have a similar phenomenon in my Electrolux ESL67070R. It started with the "undissolved" cork from the dishwasher cleaner, the second time it dissolved, but that could mean that the right temperature had not been reached. When you open the door, you feel hot during washing, but I have the impression that steam was once bursting. After washing, the dishes are warm and unfortunately wet ...
    In the service mode it reads two errors: id0 and id1. I just looked at the beam at the bend (door - housing). At first glance, I didn't notice anything suspicious ...
  • #8 16647863
    krisg1
    Rate: 36
    Have you checked the relay on the control module? Electrolux uses the cheapest electronics you can get. I got a heater relay (the white housing got brown).
  • #9 16648608
    raczkow
    Rate: 16
    No, I haven't done a thorough analysis yet. As soon as I have something I will let you know.
  • #10 16754428
    raczkow
    Rate: 16
    Replacing the tacho brought results - cost about PLN 20 and a little wiping the kitchen floor ;) Despite the fact that the measurement of the resistance of the original coil did not show a break, and even it was within the normal range, i.e. if I remember correctly about 200? (?), Each time the error id0 and id1 was repeated - and wet, sometimes unwashed dishes .
    I bought the coil for alledrogo - its resistance was about 90?, I replaced and everything returned to normal - normal operation, no errors. The mere replacement of the coil in the circulation pump - trivial, it was enough to remove the pump, "pick" the old coil, in its place press a new one and that's all. The most difficult task is to eject the dishwasher, put it on its head to have access to the guts, and then repeat the operation in the reverse order.
  • #11 17479734
    figurel
    Help: 33
    Rate: 121
    The dishwasher washes but after finishing the dishes were barely warm, lukewarm, wet. After replacing the tachometric coil (bought on Allegro from the Beko washing machine for 34.4 with shipping). It warms perfectly and when finished, when the door is opened, steam finally explodes, and hot, scalded dishes dry quickly. So with these symptoms, it's worth risking self-repair. Simple replacement, push-in coil only, cheap and satisfying :) The old coil was 236?, the new 90?.
  • #12 17770190
    kamaz8
    Rate: 25
    Can you colleagues give some link to this coil? I'm just looking for a tacho for my dishwasher because it looks like I fell the same. Hot water is not hot on a short program, but cold on a long program.
  • #13 17770203
    figurel
    Help: 33
    Rate: 121
    On Allegro, enter "tacho beko coil" in the search engine and buy.
  • #14 17770680
    kamaz8
    Rate: 25
    Thanks a lot.
    After replacement, everything works as it should, greetings
  • #15 18089454
    Gimpus
    I had the same symptoms in the Electrolux ESF 66710 dishwasher. Replacing the tacho coil solved the problem definitely.
  • #16 18422571
    WarszawaAa1
    I have the same Electrolux ESL 66010, but after replacing the heater, after a week with a new heater, it does not heat up again at all, what to do?
  • #17 18423192
    BOYXBA
    The only method to check a coil is megger meter....or if you hit it and changes resistance just replace it...
  • #18 18424718
    WarszawaAa1
    peter falk wrote:
    kingsmal wrote:
    does not heat.
    D = Hello. I am asking for advice, completely cold water, the heater replaced with a new one and without any result. Does tach cause that the water is not heated / heated at all?
  • #19 18424829
    kamaz8
    Rate: 25
    There can be dozens of reasons for the lack of heating water, it's hard to guess without any information, the heater was damaged? what about the relay? turns on? were any measurements made with the meter? maybe a picture of electronics though ?.
  • #20 18953279
    coobin77
    Can anyone tell you how to enter the service mode of this dishwasher? Nowhere on the Internet is this secret knowledge ...
    Thanks in advance.
  • #21 19020603
    coobin77
    Hi
    Unfortunately, no one wanted to share this secret knowledge of how to enter the service mode, so I replaced the tacho generator blindly. I decided that it is worth the risk because the cost is low, and there is a good chance that this is the reason for the lack of water heating. And ... it was successful, the dishwasher works like new, heats up until steam bursts and it does not spit out because it burns all the muck.
    Greetings
✨ The Electrolux ESL66010 dishwasher is experiencing issues with drying and heating, prompting the user to seek advice on replacing the tacho coil. Forum responses suggest checking other components like the thermostat and heater before replacing the coil. To access the tacho coil, users must drill out rivets and may need to remove the pump. Successful replacements of the tacho coil have resolved similar issues, with users reporting improved heating and drying performance. The tacho coil can be sourced from online platforms like Allegro, and its replacement is generally straightforward, although accessing the internal components may require significant effort.
