Affordable Solutions for Controlling Relay Output via Email Commands
killer 960 10
How can I control a relay output by predefined email commands over LAN or WiFi at a reasonable cost?
A cheap solution is to use an ESP32 with a mail client and simple message parsing to react to commands sent from a predefined email address [#19483535] For Ethernet, one suggested setup was an ESP32 with open LUA firmware plus a MODBUS interface, then add a set of MODBUS relays; the whole system should stay under about PLN 400 [#19484468] If WiFi and only one small relay/contact are needed, a ready-made ESP32/LUA solution would cost much less [#19484468] With a budget of up to PLN 2000 for hardware and software, the same commenter estimated you could buy about 10–20 such units [#19483535]
  • #1 19482225
    killer
    Level 19  
    Help: 15
    Rate: 17
    I'm looking for a reasonably priced way to be able to control a relay output via email, obviously from a predefined address, based on a predefined command (whether in text or in the subject of a message).
    In a similar way to how we control the control panel with SMS commands, here, for various reasons, the only control option is via e-mail.
    Have any of you dealt with this subject?
  • #2 19482255
    TvWidget
    Help: 472
    Rate: 699
    What exactly is meant by "reasonably priced" ?
  • #3 19482298
    killer
    Level 19  
    Help: 15
    Rate: 17
    Let's say up to 2000 PLN for hardware with software, assuming that in this upper limit we already have these controllable outputs from 9 upwards.
  • #4 19482331
    TvWidget
    Help: 472
    Rate: 699
    Specify further the interface through which the device is to communicate (LAN, WiFi, GPRS).
  • #5 19482340
    killer
    Level 19  
    Help: 15
    Rate: 17
    LAN, eventually WiFi
  • #6 19482361
    TvWidget
    Help: 472
    Rate: 699
    Should this relay be a small one, e.g. as in a PIR detector, or a large one for switching 230V mains devices?
  • #7 19482371
    killer
    Level 19  
    Help: 15
    Rate: 17
    Only a simple controllable contact or e.g. OC output is needed, i.e. small currents. Further on I can already manage if larger loads need to be controlled.
  • #8 19482414
    TvWidget
    Help: 472
    Rate: 699
    I sent the information to PW.
  • #9 19483482
    adwlodar
    Help: 111
    Rate: 245
    Can you at least let us in on the secret?
  • #10 19483535
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    And wouldn't the cheap-as-butter ESP32 with a mail client suffice, perhaps with some creative modifications - some message parsing.
    There is quite a lot of software (free), probably even for the Arduniuniu environment.
    Added after 4 [minutes]: .
    killer wrote:
    Let's say up to max 2000PLN for hardware with software
    For this money you will have from 10 - 20 pieces.
  • ESP32 Lua modbus relay solution under PLN 400
    #11 19484468
    TvWidget
    Help: 472
    Rate: 699
    If the communication is to take place via Ethernet then I have proposed a device based on ESP32 with open software in LUA and a MODBUS interface. You will still need a set of relays with MODBUS to complete the set. The total cost should not exceed PLN 400.
    In the case of WiFi and one small relay, the cost of a ready-made solution on also ESP32 with LUA is much less.
The discussion revolves around finding an affordable solution to control relay outputs via email commands, with a budget of up to 2000 PLN. Users inquire about the communication interface, specifying preferences for LAN or WiFi. The relay requirements include simple controllable contacts for small currents, with suggestions for using an ESP32 microcontroller equipped with a mail client for message parsing. A proposed solution involves using an ESP32 with open-source software in LUA and a MODBUS interface, with total costs estimated to be around 400 PLN for Ethernet communication. The ESP32 is highlighted as a cost-effective option for WiFi applications as well.
