Best ESP Board for Relay Module Control with WiFi and Compact Size?
Kiboooo 2709 13
Which small ESP board should I use to control a relay module over Wi‑Fi?
The thread recommends the ESP-12E/F as the best compact choice, or a Wemos D1 mini if you want a very small dev board with microUSB power and programming [#17814043] The ESP-12E/F has 4 MB of flash and more GPIO available, while the ESP-01 is discouraged because it has only 512 kB flash and very limited GPIO [#17814043] For relay control, one reply notes that the GPIO should drive the relay through a transistor rather than directly [#17814096] If you want to program it in Arduino IDE, use the ESP8266 Arduino core/libraries from github.com/esp8266/arduino [#17814861][#17814964] If you prefer less coding, EasyESP firmware was also mentioned as an option [#17814861]
  • #1 17814024
    Kiboooo
    I need an esp board however I don't know which one to choose. I will only use it to control the relay module and connect via wifi to the esp32 board. It also has to be relatively as small as possible. Does anyone have an idea which module would be suitable for this?
  • #2 17814043
    rafels
    Help: 69
    Rate: 166
    Probably the best would be the ESP12E or F. They have 4MB of flash, a lot of software goes in and they are easily accessible. It is so small that there is no room for goldpins.
    I would avoid the ESP01 modules as they have 512kB and very little Gpio output and are similarly priced to the above. Supposedly 512kB should be enough to control relays, but it varies, new functions and ideas come along. The system itself takes up most of this flash.
    However, these are bare modules, requiring power and an external programmer.
    Also consider how much Gpio you need and evaluate the modules from that side.
    If you are looking for a small devboard then I recommend the Wemos D1 mini. It has power and programming via microUSB and is not much bigger than the bare modules.
  • #3 17814064
    Kiboooo
    I was referring more to something like the arduino pro mini, only with wifi.
  • #4 17814096
    rafels
    Help: 69
    Rate: 166
    On Wemos, the control solution would be limited to adding a transistor to the Gpio controlling the relays. The code would take a few dozen lines of Lua code on the NodeMCU software. Here examples http://www.nodemcu.com/index_en.html
    And that's it.
    But you can always try around attaching an additional AVR to the 32 bit mcu.
  • #6 17814583
  • #7 17814595
    Kiboooo
    And how do you programme it then?
  • #8 17814627
  • #10 17814861
    rafels
    Help: 69
    Rate: 166
    This is where you need to learn programming to achieve full flexibility. I don't know if you have any experience with this, but since you are writing about ESP32 you probably already know something. You can program either in C in the Arduino environment or in Lua scripts on the NodeMCU firmware.
    If you want to do it without programming, then read about the EasyESP firmware on the internet.
  • #11 17814892
    Kiboooo
    I will definitely be programming on the arduino platform, as I already have that one in my little finger.
  • #12 17814925
    rafels
    Help: 69
    Rate: 166
    Except that there is a completely different set of libraries for ESP. Actually, only the editor is the same.
  • #13 17814938
    Kiboooo
    And where can I find these libraries?
The discussion centers around selecting a suitable ESP board for controlling a relay module via WiFi, with an emphasis on compact size. Recommendations include the ESP12E or ESP12F for their 4MB flash memory and GPIO availability, while the ESP01 is discouraged due to its limited 512kB memory and GPIO outputs. The Wemos D1 Mini is suggested as a small development board with microUSB power and programming capabilities. For those seeking a ready-made solution, the ESP-01S is mentioned as a viable option. Programming can be done using the Arduino IDE or NodeMCU firmware, with resources provided for library access and setup. The conversation also touches on the need for additional components like transistors for relay control and the importance of understanding programming for flexibility in control.
TL;DR: ESP‑12E/F fit compact WiFi relay builds: 4MB flash; “They have 4MB of flash.” Wemos D1 mini adds microUSB power/programming; avoid ESP‑01 for limited GPIO. [Elektroda, rafels, post #17814043]
Why it matters: Makers choosing an ESP to drive a relay need small size, enough flash, and easy programming.
What’s the best ESP board for a compact WiFi relay module?
ESP‑12E/F suits minimal builds with 4MB flash and small footprint. Wemos D1 mini adds microUSB power and programming, easing prototyping. Avoid ESP‑01 for its limited GPIO and smaller flash. “I recommend the Wemos D1 mini.” [Elektroda, rafels, post #17814043]
Is there an ESP board like an Arduino Pro Mini, but with WiFi?
Yes. Wemos D1 mini behaves like a tiny dev board with onboard USB. It is only slightly larger than bare ESP‑12 modules. It simplifies wiring and flashing and fits tight enclosures. It is a practical Pro‑Mini‑with‑WiFi choice. [Elektroda, rafels, post #17814043]
Can I drive a relay directly from an ESP8266/ESP32 GPIO pin?
Use a transistor between the GPIO and the relay input. With NodeMCU firmware, relay control needs “a few dozen lines of Lua.” Directly powering a relay from a pin is not advised. The transistor protects the MCU and ensures reliable switching. [Elektroda, rafels, post #17814096]
Are there ready‑made WiFi relay boards using ESP8266?
Yes. Ready‑made relay modules exist that use an ESP‑01S for WiFi control. They offer a compact path to a networked relay. These boards are useful as remote, WiFi‑addressable relay endpoints. [Elektroda, khoam, post #17814583]
How do I program an ESP‑01/ESP‑01S on a relay board?
Remove the ESP‑01 from the relay module and place it in an ESP‑01 USB programmer. Flash your firmware, then reinstall the module. This approach works because the ESP‑01 is removable on those boards. [Elektroda, khoam, post #17814627]
How do I flash an ESP‑01S for a WiFi relay?
  1. Extract the ESP‑01/ESP‑01S from the relay board and insert it in a suitable programmer.
  2. Upload your firmware through the programmer.
  3. Reinstall the module on the relay board and test switching. [Elektroda, khoam, post #17814627]
Can I avoid coding and still control relays over WiFi?
Yes. You can flash a ready firmware to the ESP8266 and configure it. The thread suggests using the EasyESP firmware to avoid writing code. This path fits quick proofs of concept or non‑programmers. You trade flexibility for speed of setup. [Elektroda, rafels, post #17814861]
Where do I get ESP8266 support for Arduino IDE?
Install the ESP8266 Arduino core and libraries from the official GitHub repository. The linked post also includes a beginner tutorial. After installation, select an ESP8266 board and compile sketches. This is the standard Arduino‑style workflow for ESP8266. [Elektroda, rafels, post #17814964]
Do Arduino AVR libraries work unchanged on ESP8266?
No. “There is a completely different set of libraries for ESP.” Only the Arduino IDE editor is the same. Plan to use ESP‑specific or compatible libraries. Test code, as some AVR‑only libraries will not compile. [Elektroda, rafels, post #17814925]
Is the ESP‑01 too limited for a relay project?
It works, but expansion is constrained. ESP‑01 variants can have 512kB flash and very few GPIOs. That limits future features and OTA updates. The base system consumes much of that flash. Choose ESP‑12E/F or D1 mini for 4MB and flexibility. [Elektroda, rafels, post #17814043]
How should I link an ESP32 master to an ESP8266 relay node?
Give the ESP8266 a simple HTTP or TCP server that exposes relay endpoints. Have the ESP32 call those endpoints over WiFi. The Arduino core provides client and server examples to implement this pattern. [esp8266/Arduino]
Do I need an extra AVR microcontroller next to an ESP8266?
No. Use the ESP8266 alone for relay control and WiFi. If desired, you can attach an additional AVR to the 32‑bit MCU. Most projects do not require the extra chip, keeping designs simpler. [Elektroda, rafels, post #17814096]
How many GPIOs should I plan for when choosing a module?
Plan module choice around your GPIO needs. If you foresee adding features, pick modules with more pins. Evaluate options from the GPIO side to avoid redesigns later. [Elektroda, rafels, post #17814043]
