Zgemma h9s - I cannot enter IP:8888 and upload lines - no connection
barti1988r 29625 8
  • OpenWebif works but port 8888 is inaccessible
    #1 19778708
    barti1988r
    Hello and welcome. As in the topic, I cannot access Zgemma IP:8888 from the browser to upload the lines. Generally, everything was OK, until I messed up something in oscam.conf and pasted something wrong there. And now there is no TV, and the worst thing is that I can`t go back there and paste the correct settings. I will also add that OpenWebif connects to me. I know I may not have described it precisely, but I`m no expert.
    Kind regards.
  • #2 19778727
    badyl00
    Level 30  
    Help: 221
    Rate: 301
    You can connect via FTP and edit the config or view the config via dreamexplorer.
  • #3 19780033
    Przem188
    EDA specialist
    Help: 157
    Rate: 156
    Apparently you don`t have oscam with http support installed. Look for another oscam in the add-ons menu, install it and switch to it.
  • #4 19780840
    tomaszlonski
    Help: 347
    Rate: 901
    He probably has a good one because he saw the Oscam interface in the browser.
    The problem is with the httpallowed setting, wrong entry.
    Usually it is
    Code: text
  • Misplaced disablecrcccws line blocks OScam access
    #5 19782237
    danivil
    I'll join the topic because I have the same problem. I entered a line in oscam.conf that apparently shouldn't be there and now I can't receive the channels and I can't access OScam through the browser. I managed to log in via TotalCommander. I will add that I entered disablecrcccws = 1 in the oscam.conf tab (originally the content of this tab was empty - a message something like "file does not exist" was displayed). I've already tried changing http allowed but it didn't help. I am attaching oscam.conf from the tuxbox/oscam path. There is also a file with the same name in tuxbox/config, i.e. oscam.conf, and in this file there was the line that I added unnecessarily. I deleted it and left the file empty as at the beginning, but it didn't help. Please help.
    • oscam.conf.docx (12.04 KB) You must be logged in to download this attachment.
  • #6 19782300
    tomaszlonski
    Help: 347
    Rate: 901
    If you have no idea where to enter it, no wonder it doesn`t work.
    Readers are in oscam.server.
    Apart from that, you don`t have the rest of the configuration for Polish programs, but that`s not the topic of this forum.
  • #7 20416177
    expol1
    Rate: 53
    I had an identical problem.
    It helped:
    disconnecting the decoder from the power supply for a few seconds and reconnecting it.
    Then only enter OpenWebif.
  • #8 20416256
    badyl00
    Level 30  
    Help: 221
    Rate: 301
    It helped:
    No connection. In this case, it`s about oscam.
  • #9 20419723
    pikarel
    Help: 410
    Rate: 1853
    badyl00 wrote:
    It helped:
    Why no connection?
    After all, Open Webif has an Add-ons menu and Oscam Webinterface in it.
    To enter the interface, Oscam must be running.
The user is experiencing issues accessing the Zgemma H9S device via IP:8888 to upload configuration lines after modifying the oscam.conf file incorrectly. While OpenWebif connects successfully, the user cannot restore TV functionality. Responses suggest connecting via FTP to edit the configuration, ensuring that the correct oscam version with HTTP support is installed, and checking the httpallowed setting in oscam.conf. Some users recommend power cycling the device as a potential fix. The discussion highlights the importance of proper configuration in oscam.server and the need for correct settings to access the Oscam interface.
