[Solved] Zgemma H9S: Oscam Update Issue - Missing Folders & Line Update Methods
kanareczek89 27744 3
  • Missing oscam config folders on Zgemma H9S
    #1 19688493
    kanareczek89
    Rate: 34
    Hello, problem with oscam update in zgemma h9s decoder, the two most known locations are empty, we are talking about:
    ../var/keys/oscam_sci0 - in my case it ends with /keys/
    ../etc/tuxbox/config/oscam/ - in my case there is no /oscam/ in the config folder
    I will add only that I upload files in oscam.server and oscam.user format ... I do not know any other method for line updates, please help.
  • #2 19688689
    tomaszlonski
    Help: 347
    Rate: 901
    The tuner you have is not important. It was at least look at the system forum what you have you would know.
    The actual configuration update is editing via the web interface.
    Normally the oscam configuration is in the directory /etc/tuxbox/config/ .
    Binary is in /usr/bin/ .
    ps Sometimes it depends on the system where it is located or where the installer puts it, ie the start script.
  • #3 19868007
    rakowskidaniel89
    Rate: 20
    that is, it is enough to upload oscam.server and oscam.user to the /etc/tuxbox/config/ folder and it should work if I already have softcam oscam-j_11411, cscam-cycek 11704-arm-ssl102=libusb and some other
  • #4 19963346
    kanareczek89
    Rate: 34
    help from the forum.
