How to send commands from Blynk to ESP8266?
def1000 1200 8
  • Need a Blynk virtual pin command handler
    #1 19517070
    def1000
    Please help me with my problem. I have written code in Arduino to measure the pH and temp of the pool. I added a control in Blynk to have a view in the mobile. Everything works as expected except for one thing. I calibrate the meter from the console and on the PC it works too, but I would like to be able to calibrate directly from the Blynk console and here is the problem. Because when I start the virtual port that shows the temperature and enter the AT command, nothing happens. So I cannot transfer commands from the Blynk to the ESP8266?
    Please help.
  • #2 19517237
  • #3 19517240
    def1000
    only ESP8266 without UNO, therefore RX / TX pins free....
  • #4 19517258
  • #5 19517793
    def1000
    that's not the point mate.... With the ESp on the Blynk the terminal shows the data, but with the Blynk terminal from a mobile phone when I type in AT commands it no longer does....
    And that's what I'm after. If anyone can help, please do. Best regards
  • Explaining BLYNK_WRITE virtual pin parameter handling
    #6 19517906
  • #7 19519221
    def1000
    mate a terminal on a virtual PIN will work but one way and not send the other way. Maybe if you know and want to help then please provide an example sketch....
  • Blynk terminal replies with Polo to Marco
    #8 19519246
  • #9 19519472
    def1000
    works... Great respect. I can see you are great and I hope you will be of service in the future too. You can email your business card to: lechkom(_at_)onet.pl -Thank you
The discussion revolves around sending commands from the Blynk app to an ESP8266 module for calibrating a pH and temperature meter. The user successfully measures and displays data on Blynk but struggles to send AT commands from the Blynk terminal on a mobile device to the ESP8266. Responses suggest using the Blynk component called Terminal to facilitate communication, emphasizing the need for proper handling of virtual pins and the BLYNK_WRITE function. An example sketch is provided to illustrate how to set up a virtual serial terminal, allowing for two-way communication between the Blynk app and the ESP8266.
