MOT Validity Debate: Examination on 10.07 and Validity Until 10.07.22 or 13.07.22?
locarnos 18114 15
If I have a car inspection done before the current MOT expires, is the next validity date counted from the inspection date or from the old expiry date?
The next MOT is counted for one year from the date the inspection is actually performed, so an inspection done on 10.07 is valid until 10.07.22, not 13.07.22 [#19517882] The legal reference quoted in the thread says periodic technical inspection is done annually and the next date is entered from the date of the inspection, with the old expiry date not preserved under the rules then in force [#19518015] Claims that an earlier inspection would keep the previous expiry date were described as future changes that were not yet in force at the time [#19517940][#20117778]
  • #1 19517843
    locarnos
    Rate: 36
    Hello. The car had MOT until 13.07. The examination was carried out on 10.07. According to what I read, the inspection should be valid until 13.07.22. However, it is written that it is valid until 10.07.22. Shouldn't it be that if I do the review earlier, the later date to which the review was carried out should be entered in the proof?
  • #2 19517882
    Jacek1l
    Help: 7
    Rate: 71
    The review is valid for one year from the moment of its performance.
  • #3 19517886
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    locarnos wrote:
    Shouldn't it be like that?
    shouldn't
  • #4 19517891
    sanfran
    Help: 963
    Rate: 3004
    locarnos wrote:
    Shouldn't it be that if I do a review earlier, the later date to which the review was carried out should be entered in the proof?
    It seems that work is underway to modify the law to make it work in this way, i.e. for the date to be maintained, the car must be inspected no earlier than a month before the deadline, but for now it is a year from the examination.
  • #5 19517911
    locarnos
    Rate: 36
    It's wrong on the web
    From 2019, you can also perform a technical inspection of the car "in reserve", i.e. 30 days before the deadline. What's more, even if we perform the inspection faster, its validity will be extended by one year, counting from the date on the registration certificate.
    https://kioskpolis.pl/przeglad-samochodu-przed-co-powinienes-wiedzec/
  • Inspection validity extends from the test date, not expiry date
    #6 19517940
    ta_tar
    Help: 699
    Rate: 2052
    Probably not all stations know about it. I checked my ID and having a deadline of May 23, I did the research on May 14 and unfortunately the entry of the next examination is on May 14 of the next year.
  • #7 19517996
    sanfran
    Help: 963
    Rate: 3004
    So they modified. You should be proud of the diagnostics.
  • Cites road traffic law on MOT validity dates
    #8 19518015
    Jacdiag
    Level 30  
    Help: 116
    Rate: 382
    Because you don't listen to rumors, you only use the provisions of the law, and this is published at http://isap.sejm.gov.pl/
    ISAP - Internet System of Legal Acts
    The dates of the tests are specified in the Road Traffic Law, Art. 81
    Latest consolidated text OJ 2021 pos. 450 http://isap.sejm.gov.pl/isap.nsf/DocDetails.xsp?id=WDU20210000450
    5. Periodic technical inspection of the vehicle is carried out annually , subject to sec. 6-10.
    6. Periodic technical inspection of a passenger car, a truck with a maximum permissible mass not exceeding 3.5 t, a motorcycle or a trailer with a maximum permissible mass not exceeding 3.5 t shall be carried out before the expiry of 3 years from the date of first registration, then before the expiry of 5 years from first registration and no later than 2 years from the date of the previous technical inspection, and then before the end of the next year from the date of the inspection. This does not apply to a vehicle carrying dangerous goods, a taxi, a motor vehicle designed to transport 5 to 9 people, used for commercial road transport of people, a "SAM" vehicle, a gas-powered vehicle, an emergency vehicle and a vehicle used for driving lessons or state exam, which are subject to annual technical examinations.
    7. Periodic technical inspection of the agricultural tractor, agricultural trailer and moped shall be carried out before the expiry of 3 years from the date of first registration, and then before the expiry of each subsequent 2 years from the date of the examination.
    8. The provisions of sec. 6 and 7 also apply to the vehicles referred to in par. 6 and 7, registered for the first time abroad. In this case, for the day of the first registration referred to in par. 6 and 7, the date of first registration abroad is assumed.
    9. Periodic technical inspection of the bus is carried out before the end of the year from the date of first registration and then every 6 months.
    10. The light trailer and the historic vehicle are not subject to periodic technical inspections. In the case of a historic vehicle used for commercial road transport, it is subject to annual technical inspections.
    If the test result is negative ( n ) then there is 14 days for the "correction", and the deadline for the correction is set for a year from the date of the examination with the result n
    6. The technical examination of the vehicle consisting in re-checking the assemblies and systems, in which defects were found, shall be made in terms of their removal, if within a period not longer than 14 days from the date of the examination, the station where these defects were found checks. After performing the test consisting in re-checking the assemblies and systems, the authorized diagnostician, after finding that all significant faults and faults posing a threat have been removed, enters the next date of periodic technical inspection into the registration certificate. This period is counted from the date of the test in which the defects were found.
    Added after 14 [minutes]:
    I invite you to SKP and wish you "success in cleaning"
  • #9 20115991
    kikoo2
    The paragraphs say: Must be inspected within a year from the previous inspection. Does not apply to new and other special situations. Nothing about dates and extensions.
  • #10 20115996
    cirrostrato
    Help: 286
    Rate: 958
    "Nówka" of a four-year-old, after three years I'm doing a review .... now after a year I'm doing another review, the diagnostician didn't even blink an eye, I went through the health path, I got the registration card by paying PLN 99 earlier without any entry ..... I forgot, that the second review is done AFTER TWO YEARS and only the next one every year.
  • Second inspection treated as optional safety check
    #11 20116091
    750kV
    Help: 240
    Rate: 713
    The diagnostician decided that you are requesting an inspection out of safety concerns, resulting from your suspicion of faults. He considered this review to be additional, not mandatory.
  • #12 20116206
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    In Ireland you can do an inspection up to three months in advance. So if I do three months before the prescribed date, I have 15 months.
  • Early MOT keeps the original expiry date
    #13 20116267
    ta_tar
    Help: 699
    Rate: 2052
    Excerpt from:
    https://www.autobaza.pl/page/portal/news/zmia...hniciczne-samochodow-od-1-wrzesnia-2022-roku/
    "Examination 30 days ahead of schedule, taking into account the previous date
    Prospective drivers who arrive at the diagnostic station up to 30 days before the scheduled date will gain. In their case, the date of the next examination will be set for one year from the previously agreed date. This is a tribute to drivers who for some reason want to perform the test earlier (e.g. due to a planned trip)."
    It turns out that only from September 1, 2022 will there be an entry from the previous date, not the current date of the examination.
    You don't have for the next 15 months, you still have 12 months from the current date because those three months overlap.
  • #14 20116390
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    Yeah. You are indeed right. But at least I have some leeway :)
  • #15 20116580
    janosiksik
    Help: 94
    Rate: 169
    Ireland is a strange country, you can have tires, any other, but if you are missing a hubcap, you will not pass the inspection, unless .... you take off the other three. If the rear wiper is not working, there will be no service unless.... you remove the arm of that wiper. Worst of all, when the fuel filler cap jams, you can forget about the inspection. ;) :)
  • September 1, 2022 rule changes not yet in force
    #16 20117778
    Jacdiag
    Level 30  
    Help: 116
    Rate: 382
    autobaza.pl/ wrote:
    Of course, the fact that changes in technical research will take effect from September 1, 2022, is not yet decided . Let us remind you that there has been talk of major changes in this area since autumn 2020. However, in the end, the draft went to the Legal Committee. Now it has to be approved by the government, then go to the plenary, be voted on and signed by the president .
    So when the relevant statute book appears, then we can discuss :!:
    And now it falls under SF
    Added after 12 [minutes]:
    ps.
    now I noticed that it's old from February 9, 2022
The discussion centers on the validity of a car's MOT (Ministry of Transport) inspection, specifically whether an examination conducted on July 10 should be valid until July 13, 2022, or only until July 10, 2022. Participants clarify that the current law states the inspection is valid for one year from the date of examination, and modifications to allow for earlier inspections to maintain the original expiration date are in progress but not yet implemented. A user notes discrepancies in how different diagnostic stations record inspection dates, leading to confusion. The conversation also references upcoming changes to regulations that will allow inspections to be conducted up to 30 days in advance while retaining the original expiration date.
TL;DR: Poland’s 14‑day retest rule applies, and "periodic inspection is carried out annually"—so early tests reset the expiry to the exam date. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
Why it matters: It helps Poland-based drivers plan inspections without losing days and dispels the "30 days early" myth.
  • Validity is counted one year from the inspection date; a 14‑day retest counts from the failed test date. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
  • New cars: 3 years from first registration, then 2 years, then every year; listed special-use vehicles are annual. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
  • Buses: first within one year, then every 6 months thereafter. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
  • Historic vehicles and light trailers: no periodic inspections; historic used commercially require annual checks. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
  • Early testing does not preserve the previous expiry date under current Polish law. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
Does an early vehicle inspection keep my old expiry date in Poland?
No. The next expiry is one year from the exam date. The law says "before the end of the next year from the date of the inspection." [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
I tested on 10.07, but my old expiry was 13.07. What is my new expiry?
It becomes 10.07 next year. Only a 14‑day retest after a failed test counts from the earlier failed test date. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
Where did the "30 days early keeps the date" idea come from?
It was discussed as a proposal. As of mid‑2022, forum updates noted it was not yet decided or enacted. [Elektroda, Jacdiag, post #20117778]
What is the official schedule for new cars (3‑5‑2‑1 rule)?
New cars: before 3 years from first registration, then before 5 years, then within 2 years, then annually thereafter. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
What happens if I fail the inspection? How does the 14‑day retest work?
Return to the same station within 14 days. The next date is counted from the failed test date. "This period is counted from the date of the test in which the defects were found." [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
What if I miss the 14‑day window or go to another station?
You lose the retest rule. Your next expiry then runs from the later inspection date at the new visit. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
How do rules differ for buses, taxis, LPG, ADR, and similar vehicles?
Buses: first within one year, then every 6 months. Taxis, ADR carriers, LPG vehicles, emergency, SAM, and driving‑school/exam vehicles: annual inspections. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
Are historic vehicles and light trailers exempt from periodic inspections?
Yes. Historic vehicles and light trailers are not subject to periodic inspections. Historic vehicles used commercially require annual checks. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
My station wrote the exam date as the new expiry when I went early. Is that wrong?
It is correct under current law. Early testing resets the clock to the exam day unless it was a 14‑day retest. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
Can I ask for an additional inspection that doesn’t change my mandatory schedule?
Some diagnosticians perform a voluntary additional check on request. It does not replace or extend the mandatory periodic schedule. [Elektroda, 750kV, post #20116091]
How should I plan an early inspection before a long trip without losing days?
  1. Check your current due date in the registration certificate.
  2. Book the inspection as close to the deadline as practical.
  3. If you must go early, note your next expiry runs from your exam date. This avoids unnecessary loss of remaining days. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
Did a change take effect on 1 Sept 2022 to preserve the previous date?
A widely shared article mentioned that date. A forum legal summary noted the change was still not approved or signed then. [Elektroda, Jacdiag, post #20117778]
If I test after my old expiry has passed, how is the new date set?
Your next expiry runs one year from the new inspection date. The law ties validity to the exam date. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
What entry goes in the registration certificate after a retest?
The diagnostician enters the next periodic date, counted from the date of the failed test that triggered the retest. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
What are the intervals for agricultural tractors, agricultural trailers, and mopeds?
Before 3 years from first registration, then every 2 years thereafter. This schedule is set in Article 81. [“Prawo o ruchu drogowym – art. 81 (ISAP)”]
