[Solved] Zgemma h9s no current date. After replacing the platter with a larger one.
maleo89 19287 4
  • #1 18979839
    maleo89
    I have a problem with the current date on my decoder, zgemma h9s, after replacing the dish with a larger one the date and time has been reset. The update from the remote control does not give anything both from the server and the transponder. How to restore the current date and time?
  • Factory reset and manual time assignment fix date display
    #2 19022362
  • #3 19022827
    LeDy
    Help: 1992
    Rate: 2942
    Do not do factory settings or it will delete everything you have. Set manually.
  • #4 20279002
    piterk
    Rate: 12
    I had the same problem. After restarting the receiver the date was set to 2023r 4.02. Changing the way the time was updated did not help. I logged in via FTP and noticed that there are 2 files created with future date. The cure for the problem was to clean the contents of the file /etc/fake-hwclock.data . ( Total Commander and F4)
  • #5 20312665
    cenoley
    Rate: 26
    The simplest thing to try is to turn oscam off, restart, turn oscam on.
