[Solved] Integration of the PROXIMA NW1 SIO radio into the Somfy system via TaHoma Switchboard
maco_mci 912 1
  • #1 19692545
    maco_mci
    I have acquired a PROXIMA NW1 SIO radio transceiver because it supposedly works with the Somfy system,
    And is it possible to connect it to the Somfy system to be controlled through the TaHoma Switch?
  • #2 21857825
    maco_mci
    The control unit is not working, and has been returned
