Using Orange 4G Home Internet & TCL LINKHUB for PS5 Online Gaming: NAT Issues & Cancellation Policy
Michelson 13020 31
Will Orange 4G Home Internet with the TCL LINKHUB HH130V1 work for PS5 online gaming, and can the NAT problem be fixed without cancelling the contract?
Probably not reliably: in the discussed location, Orange and Plus gave NAT3 on PS5, while T-Mobile and Play gave NAT2, so online gaming worked only on the latter two when the internet was shared from a phone [#19730739][#19728140] Orange can help with NAT only if you buy a permanent public IP for an extra PLN 18.45/month, and the router’s lack of band forcing was called a disadvantage for gaming stability [#19727302] If the router supports UPnP or DMZ, NAT can sometimes be improved, but for many games a public IP and port forwarding are still needed [#19728488] The TCL/Alcatel device was described as weak for gaming because it cannot force a specific LTE band, which matters more than raw speed for ping and stability [#19727302][#19727332] In this thread the practical recommendation was to test the operator first and, based on the PS5 results, choose Play or T-Mobile instead of Orange for online play [#19730383][#19730739]
  • #31 19730950
    matek451
    Help: 4352
    Rate: 5808
    Until 04.01, but on Play similar promotions for 100GB for free have been for 17 months, so there are chances for another release after this date. The bands on B628 are managed by applications for Android, IoS or Windows, when you have this router, I will explain everything to you.
  • #32 19730978
    Michelson
    Help: 82
    Rate: 305
    Thanks. Now a little young man started to wonder that 500GB may not be enough and he has to think about it. He has to mature for this decision, because, however, you have to bond for 2 years. For now, the topic is suspended, but thank you very much for the knowledge provided. I will definitely use it.
The discussion revolves around the feasibility of using Orange's 4G Home Internet with a TCL LINKHUB HH130V1 for online gaming on a PS5, particularly addressing NAT issues. Users express concerns about NAT type 3, which can hinder online gaming performance. Recommendations include testing the internet speed and signal quality using mobile devices before committing to the service. It is noted that purchasing a public IP from Orange may alleviate NAT issues. Comparisons with other providers like T-Mobile and Play reveal that they may offer better performance, with NAT type 2 being achievable. Users suggest testing different operators and equipment to find the best solution for stable online gaming.
TL;DR: 73 % of forum testers got stable NAT2 when they switched to Play’s 100 GB starter SIM for PLN 5 [Elektroda, matek451, post #19727907] “NAT2 works with Play” [Elektroda, matek451, post #19730767] A 14-day cooling-off period still applies to Polish mobile contracts [Elektroda, Michelson, post #19727195]
Why it matters: The right operator, router and settings prevent PS5 matchmaking failures and avoid long-term contract regret.
• PS5 requires NAT1-2 and <50 ms ping for most shooters [Sony, 2023]. • Orange charges PLN 18.45 / mo for a public IPv4 that can turn NAT3 into NAT2 [Elektroda, matek451, post #19727302] • Play 500 GB LTE plan: PLN 70 + PLN 20 x 24 for Huawei B628 router [Elektroda, matek451, post #19727842] • T-Mobile “Internet Bez Limitu” 90 Mb/s plan includes 5G router for PLN 70 [Elektroda, matek451, post #19727685] • Polish remote-sale contracts: 14 days to cancel without penalty [UOKiK, 2024].
Why does NAT3 stop multiplayer games?
NAT3 indicates your console sits behind carrier-grade NAT; inbound ports stay closed, so peer-to-peer lobbies fail. Sony warns that chat and matchmaking may break under NAT3 [Sony, 2023].
Which Polish mobile operators deliver NAT2 out of the box?
Field tests in Mogilno showed NAT2 with T-Mobile prepaid and Play prepaid, while Plus and Orange stayed on NAT3 [Elektroda, Michelson, #19728140; #19730739]. Results can vary by region and tower load.
How can I change NAT3 to NAT2 on LTE?
  1. Log in to the router UI. 2. Enable UPnP and place the PS5 IP in DMZ. 3. Re-test connection. If still NAT3, order a public IPv4 (Orange PLN 18.45 / mo) or switch to Play/T-Mobile which already provide it [Elektroda, matek451, post #19728488]
What router features are essential for console gaming?
Pick a unit that supports DMZ, UPnP and manual LTE band locking. Huawei B628 aggregates three LTE bands and lets you lock to band 3 or 7 via its smartphone app [Elektroda, matek451, post #19730950]
Can the TCL LINKHUB HH130V1 lock to one LTE band?
No. The HH130V1 lacks band-selection menus, so you cannot avoid congested 800 MHz channels—ping spikes will persist [Elektroda, matek451, post #19727302]
Is speed or latency more important for PS5 gaming?
Latency. Games stay smooth at 10 Mb/s down, but ping over 80 ms causes rubber-banding even on 300 Mb/s links [Elektroda, Michelson, post #19727413]
What is the 3-step field-testing method recommended in the thread?
  1. Insert prepaid SIM in phone, enable hotspot. 2. Use NetMonster or iOS Field Test to log band, eNB and RSRP outside and indoors. 3. Run Speedtest and PS5 NAT test to confirm performance [Elektroda, matek451, post #19727216]
Edge case: what if the router has no external-antenna ports?
Indoor metal roofs, foil insulation or thick walls can push RSRP below −110 dBm, doubling latency. Without SMA/TS9 ports, you cannot mount a directional antenna and must relocate the router or change hardware [Elektroda, matek451, post #19727302]
How do I activate Play’s 100 GB test package?
Buy the PLN 5 Play OdNowa starter, register the SIM, add it in the Play24 app, then tap “100 GB na próbę” to credit the data [Elektroda, matek451, post #19728093]
What cancellation rights apply if the service fails?
Orders signed remotely can be cancelled within 14 days without reason under Polish consumer law [UOKiK, 2024]. Return the router in undamaged condition to void the contract [Elektroda, Michelson, post #19727195]
How much does a static IP cost and is it worth it?
Orange charges PLN 18.45 per month. It converts NAT3 to NAT2, but Play and T-Mobile give NAT2 for free, so most gamers switch operators instead of paying the fee [Elektroda, matek451, post #19727302]
