DAF XF 105, Paccar MX340 Engine Issue: Diesel Present in Coolant Header Tank
djpapatanaka 4299 5
  • #1 19779994
    djpapatanaka
    Hi guys I have a DAF MX 105 with Paccar MX 340 engine and I'm seeing diesel in my coolant header tank. I started noticing this when the compressor coolant pipe had bursted and it was leaking diesel, what could be the fault guys
  • #2 19780634
    klika60
    Help: 20
    Rate: 278
    Hello, I would start by checking the injector holders in the head
  • #3 19786796
    serwis33
    Rate: 16
    Hello, I propose to check the engine oil cooler (common fault). Greetings
  • #4 19787138
    mario11031980
    Help: 48
    Rate: 177
    It gets oil or diesel fuel, it must be determined.
  • #5 20088193
    lksCy
    Hello, I have the same matter with my XF 106, mixing fuel with coolant. Did anyone manage to find the problem??
  • #6 20092613
    klika60
    Help: 20
    Rate: 278
    Hello, 99% of the injection molding is damaged
