Remedy: Alexa Dot 2nd generation does not respond to plugging in or resetting
ziomek.pl 774 5
  • #1 19830333
    ziomek.pl
    Level 4  
    Hi I got an Alexa Dot 2nd generation today to play with but I decided to fix it because it is not working.
    Connecting it to the pendant doesn't work, I tried to reset it but also nothing maybe someone has some advice?
  • #3 19831044
    bhtom
    Help: 446
    Rate: 604
    Welcome,
    ziomek.pl wrote:
    Connecting to the prong
    I, however, suggest connecting to the prong.... ;)
    Regards.
  • #4 19831062
    ziomek.pl
    Level 4  
    sk1977 wrote:
    Check the power supply for starters.
    The power supply is 100% good but I will still check under other
  • #5 19842695
    ziomek.pl
    Level 4  
    Hello? Someone there
  • #6 19842846
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    If it's not a power supply then it will be rather difficult to get help in this section. Particularly as you are not posting basic information that might contribute anything to the topic - e.g. current draw, visual inspection results after disassembly (e.g. physical damage, traces of burnt components).
