Panasonic TX-43GX550B: Vestel 17IPS72P LED Backlight Issues & Troubleshooting Tips
jp123456789 7653 1
  • Suspected resistor fault in 17IPS72P backlight circuit
    #1 19851094
    jp123456789
    The LED backlight is not lighting up in my Panasonic TX-43GX550B TV. I have taken the thing apart several times to have a look for different problems. Curiously, if I try turning it on after I have disassembled it somewhat, it often starts working again for some unknown reason, at which point I put it back together, put it back on the wall, everything is fine for a few power cycles and then the backlight fails again. It is only the backlight that stops working, everything else is fine.
    None of the LEDs are broken or damaged - I have taken the thing apart back to the backlight and used an LED test kit to find that they are all fine.
    There is no visible damage that I can see on the power board. I don't know where I'd get hold of the circuit diagram for the 17IPS72P power board anyway. Nevertheless, it seems there is a problem with the LED power delivery; I don't know what.
    There is another thread talking about a similar model (Vestel 17IPS71) in some detail concluding that there is a bad resistor value in the circuit. Is this the same problem here?
  • #2 19852828
    fhocorp
    Hi
    This is probably the case.
    Vestel Power supplies had a short circuit protection in the LED driver. In my cases, I have checked resistors, capacitors, diodes and MOSFETs near the LED driver connector. Most of the time, the MOSFET or a diode is the clue of the faulty backlight.
    FHOCORP.NET
    Rue du Reservoir, Talant, 21240 | Company Website: www.fhocorp.net
