After seals change the machine PCB board was not connected correctly and this killed the main PCB board. I have a similar model with no display, so I swap all boards (main power board, front panel board and the flow meter board) from the donor machine. Now I have the flowing issue (please check the video). All lights on and the machine is not starting at all. Sometimes the light are on right after I plug the power cord.
adjiski
adjiski
