[Solved] Chromecast 4.0 Remote Unresponsive: Checking Infrared Diode, Pairing & Processor Heat Issues
Tenno 50118 7
  • Remote processor heating suggests internal failure
    #1 20028828
    Tenno
    Rate: 13
    I have a problem with the Chromecast 4.0 remote.
    1. Does anyone of you know the solution?
    - the pilot does not respond
    - new batteries, checked with a meter
    - I check the infrared diode with a photo camera from the phone, it does not light up
    - after clicking any button, the diode between the buttons for switching on and changing the input signal on the TV does not light up (the diode between the two lowest buttons on the remote control)
    - no response to a longer press of two keys (arrow and home) to pair.
    - the dongle itself works (I checked with the apk on the phone and the Xbox pad).
    - I undressed the remote control and connected it to the battery - I noticed that the plate with processors was heating up above the battery contacts.
    - after submitting, still no reaction as above.
    2. In the USA you can buy the remote control only, but I couldn't find it on the PL pages. Can you recommend a voice search alternative?
    Thank you in advance for all your help! :)
  • #2 20039107
    szopson
    Rate: 11
    The dial button on my chromecast 4.0 remote is broken and I'm having trouble buying a second one as well. I think I will order in the German google store and redirect the parcel to Poland using mailboxde.
    How to disassemble this remote control so as not to break it? can you give me a hint?
  • #3 20039206
    Tenno
    Rate: 13
    I bought a second Chromecast. I paired the old one with the TV remote. Do not reset the device because without the remote control you will not start. I also launched Android TV remote applications on my smartphone.
    You disassemble the remote control like a telephone, carefully prying it open. Then unscrew the screws from the plate.
  • #4 20243041
    dekormilodz
    Rate: 14
    The remote control for Chromecast 4.0 is not infrared but on Bluetooth and you need to pair it with the device by holding down 2 buttons
  • #5 20243052
    Tenno
    Rate: 13
    dekormilodz wrote:
    The remote control for chromecast 4.0 is not infrared but on. Bluetooth and you need to pair it with the device by holding down 2 buttons
    no response from the remote control when pressing these 2 buttons, normally the LED is on during this pairing, it is not on for me.
  • #6 20246436
    Judykator
    Rate: 26
    And which buttons
  • #7 20493701
    xabro1
    Rate: 36
    For pairing "Back" and "Home". To reset the remote control, remove the batteries, wait a few minutes, press the "Home" button and while holding it, insert the batteries. When the LED starts flashing quickly, you can release the button.
  • #8 20801827
    Tenno
    Rate: 13
    I bought a new unit in the HD version (remote control same as for 4k).
The discussion revolves around issues with the Chromecast 4.0 remote, specifically its unresponsiveness. The user reports that the remote does not respond despite new batteries and checks on the infrared diode, which does not light up. They also mention that the processor heats up when the remote is disassembled and connected to a battery. Other users clarify that the Chromecast 4.0 remote operates via Bluetooth, not infrared, and provide pairing instructions using the "Back" and "Home" buttons. Suggestions include using an Android TV remote application as an alternative and tips for disassembling the remote without damage.
