The steering wheel turns left by itself and I cannot calibrate it
mareksala7 1581 1
  • #1 20064728
    mareksala7
    Wiram, I have a similar problem in Logitech G25, my steering wheel is gradually turning to the left, I will not miss 4KM so as not to have to calibrate it. This always happens after the car has been repaired in a rally. Anyone know what kaman?
    Separated from the topic: The steering wheel turns left by itself and I cannot calibrate it
    by dt1 on 17 Jun 2022 14:47
  • #2 20065940
    miro.nasz
    Help: 88
    Rate: 171
    Hello!
    Check the suspension - mountings, frame - rocker arms, toe-in, camber angles / geometry, wheel runout / and play.
    Check the condition of the frame if it has not been eaten by rust. in places of mounting rocker arms, shock absorbers.
    Regards Miro our
