Opel Astra J 1.4 Turbo 140km - " Vehicle breakdown, please contact service centre
ArekK3 33651 10
  • #1 20067483
    ArekK3
    Level 4  
    Hello, I have a problem with my 2010 Opel Astra J 1.4 Turbo 140km, while driving I get the message "Vehicle failure, contact service". After the message appears, the car minimally loses its power, the coolant temperature is OK (90 degrees), besides this, no other message appears. I would like to find out what the problem is and what should be done in this respect, does this result in a serious fault in the car. Please advise.
  • #2 20067501
    Alfred_92
    Help: 148
    Rate: 705
    Clear message "Contact service", it doesn't necessarily have to be ASO.
    We have no idea what's wrong with it, the power is cutting because it's protecting itself from damage- but why it's not knowing anything.
  • #3 20067511
    ArekK3
    Level 4  
    Alfred_92 wrote:
    Clear message "Contact service", not necessarily ASO.
    We have no idea what's wrong with it, the power cuts because it's protecting itself from damage - but why it doesn't know anything.
    Could anyone else comment on this problem? Or if you need any more information I will write. Greetings.
    Could it be the fault of some components? (Turbo / electrics / controllers etc).
  • #4 20067529
    milejow
    Help: 1559
    Rate: 5129
    ArekK3 wrote:
    Could anyone else comment on this problem ?
    Yes
    Alfred_92 wrote:
    We have no idea what's wrong with it, the power cuts because it's fail-safe - but why it doesn't know anything.
    And many, many more responding in the same way. Could be the fault of the components you mentioned and many more
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #5 20067536
    ArekK3
    Level 4  
    milejow wrote:
    Yes
    Hmm well it's not an interesting situation, I thought I'd find out something, at most I'll have to drive up to the ASO :(
  • #6 20067541
    jerry1960
    Level 37  
    Help: 284
    Rate: 1554
    ASO will be expensive, look for an independent workshop and read the errors.
  • #7 20067543
    Alfred_92
    Help: 148
    Rate: 705
    I'm saying that a workshop will suffice, it doesn't have to be an ASO straight away.
  • #8 20067796
    urkotrebor
    Help: 37
    Rate: 80
    Such a message could mean anything , including a burnt out bulb .
    If you don't hook the car up to a tester then you could be calling a fortune teller , the result will be the same as after this discussion .
    Have a look here http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes you will see how many options you have .
  • #9 20068038
  • #11 20068871
✨ The user reports a "Vehicle failure, contact service" message appearing in their 2010 Opel Astra J 1.4 Turbo while driving, accompanied by a slight loss of power. The coolant temperature remains normal at 90 degrees. Responses suggest that the issue could stem from various components, including the turbo, electrical systems, or controllers. It is recommended to consult an independent workshop for diagnostics rather than an authorized service organization (ASO), as the problem could be minor, such as a burnt-out bulb. A diagnostic test is essential to identify the specific fault.
