Technical data of SilentiumPC Pactum PT-3 thermal paste and comparison with Arct
Mihose 19698 4
  • #1 20183089
    Mihose
    Does anyone have the specs for this thermal paste? I would like to buy fere 5 and this paste is added in the set and I do not know if it is worth buying another one
  • #2 20183187
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Hello, instead of technical data, which will not translate into much anyway, it is better to look for tests of this paste.
    Overall it's good and no reason to buy another. Anyway, if you decide that it does not meet your expectations, you can always exchange it for another one.
  • #3 20183189
    Mihose
    Thanks
  • #4 20183228
    2konrafal1993
    Help: 581
    Rate: 746
    I used this paste and it likes to dry quite quickly, about a year was enough for it to be dry. It can be for some time and then you can replace it, the paste is not bad but if you don't feel like looking there for a long time, it's better to buy something better.
  • #5 20183322
    dt1
    Help: 7315
    Rate: 8292
    I also have several coolers with this paste applied and I do not see an increase in temperatures above the norm.
