Join the Tech Talk: Troubleshooting Clamp Issues for Skoda Felicje 1996
ViktorMC 54917 9
Why does a white deposit form on my battery terminals, and can it affect charging or alternator health?
A white deposit on the battery terminals is usually caused by leaking battery posts or acid vapors released during charging reacting with the clamp material, and poor contact at the clamps can also contribute [#1994060] [#1989497] [#1989378] Check that the clamps fit tightly, inspect whether the battery posts are damaged, and make sure the connection is really sealed [#1989378] [#1994060] If the battery is not charging properly, measure the charging voltage and battery condition, because low charging, a loose belt, a faulty regulator, or bad connections can let acid “come out of the battery” [#1994854] Felt washers under the clamps can help keep the terminals clean, and some replies also recommend petroleum jelly on the joint [#1993983] [#1994152] If the charging problem persists, the alternator and battery can keep suffering from the undercharging and corrosion [#1994060] [#1994854]
  • #1 1989352
    ViktorMC
    Rate: 22
    Hello everyone.
    I looked through most of the posts on this topic and found no answer to my problem. I have skode felicje from 1996. For about 6 years everything was ok but then akus fell. After replacing the brushes in the alternator broke and now there is a raid on the terminals and there are problems with the alternator. Recently, it has been repaired and the entire middle of the alternator + rectifier bridge has been replaced. The problem is that the battery still has a white coating on the terminals, although the terminals are brand new. Why is this raid formed? Could this affect battery charging and alternator health?
    Thanks in advance everyone for the answers!
  • #2 1989378
    didot
    Help: 6
    Rate: 9
    from my experience, a raid on the clamps was formed when the clamps did not adhere very accurately to the battery posts .. tighten them neat and see if the posts are damaged, if you need to pour the pole ... I swear when she did not connect well, so I think it will be it ..
  • #3 1989497
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    I noticed a sudden formation of white-green "blooms" when the connection between the battery plug and its housing was unsealed; The acid vapors released during charging react with the clamp material (brass) and form "mushrooms". This is partially recommended by covering the joint with technical petroleum jelly. However, I have to dispel a myth: recently I heard that technical petroleum jelly is called so because it conducts electricity, therefore the pin and clamp are lubricated before connection. :D This was proved recently by my technically educated neighbor ...
  • #4 1993557
    ViktorMC
    Rate: 22
    It seems to me that the clamps are properly mounted, moreover, the original clamps had a notch in some place where you could see the battery pin. So is this the only cause of the raid?
  • #5 1993878
    dragon400
    Rate: 17
    It helps to carve out holes in a piece of felt and put on the + cells, - put the clamps on the battery and let a few drops of engine oil (IT WORKS)
  • #6 1993904
    ViktorMC
    Rate: 22
    hmmmm ... how would it work ... anyway, I would like a more detailed description.
  • #7 1993983
    brodzik
    I confirm this way with felt. The holes in the felt washers must fit snugly to the battery posts (they must not be too loose). I have been using this method for many years and my clamps are always clean. It really works.
    Felt washers are placed on the battery terminals under the clamps.
  • #8 1994060
    beata pn
    Rate: 15
    hello, your so-called the efflorescence on the clamps is caused by leaky battery posts. probably it is some non-proprietary mercet battery, so it is their factory defect. you will not do anything about it. felt will help in 60%, but after some time they will oxidize the clamps.
    clean 1 * a month
    seal the battery post with silicone and felt and a little copper grease on the surface of the clamp (tightly all over the area)
    replace the battery. for some brand name. bosch. maintenance-free or other centers (they are quite tight), I recommend they are expensive, but for 5 years you forget about the battery. regulator, winding) try to control this "bloom" because you will not earn for alternators: d
  • #9 1994152
    ohc_turbo
    Rate: 17
    smear vaseline vaseline i used to read about it is the cheapest and supposedly reliable agent i smeared it and it's ok :)
  • #10 1994854
    marek234
    Rate: 18
    Check the charging voltage and battery level. If it is too low, the acid "comes out of the battery".
    The cause of poor charging can be a poorly tensioned belt, frequent engine start + lights, slacked regulator, poor connections, etc.
    In addition, an undercharged battery will die very quickly.
    If necessary (when the alternator does not keep charging), the battery from the rectifier should be recharged.
The discussion revolves around troubleshooting battery terminal corrosion issues in a 1996 Skoda Felicja. The user reports persistent white coating on battery terminals despite replacing the alternator and terminals. Responses suggest that poor connections, leaky battery posts, and acid vapors during charging may cause the corrosion. Recommendations include ensuring tight connections, using felt washers under clamps, applying petroleum jelly or copper grease, and sealing battery posts with silicone. Additionally, checking the charging voltage and battery condition is advised to prevent further issues.
