Toshiba 32W1333DG with 17MB95 Main Board and VES315WNDL01 Screen Showing Bad Image
mnjoao 2115 4
  • #1 21123825
    mnjoao
    Level 4  
    Rate: 10
    Mark: Toshiba
    Model: 32w1333dg
    Chassis (main board, components): 17MB95
    LCD Screen/Panel (if exist): VES315WNDL01
    More information: bad image
    Good afternoon, I need the firmware for this TV that has chromatic errors in the image, thank you
  • #2 21123854
    billobirillo
    Help: 338
    Rate: 797
    color errors after a wrong software update?
    if not, the software most probably will not help
    attached, the software
    • MB95S_TOS_LA_V219z.zip (28.31 MB) You must be logged in to download this attachment.
  • #3 21124059
    mnjoao
    Level 4  
    Rate: 10
    Thanks for the answer, the defect is as if it were in dry mode with the colors inverted, I've already done a factory reset in service mode but it didn't solve it, I haven't updated it yet but I was thinking about reprogramming the U10, if you have that firmware I would appreciate it
    thanks
    yokoono51
    Help: 172
    Rate: 316
    Look. For programmer.
    • Toshiba 32W1333DG main 17MB95S-1 panel VES315WNDL-01.rar (326.74 KB) You must be logged in to download this attachment.
  • #5 21124541
    mnjoao
    Level 4  
    Rate: 10
    thank you very much
