TL;DR: VW’s 2.0 TDI (EA288/DTTC) timing belt is factory-rated for 180 000–210 000 km or 5 years; “replace at 90 000 km after the first change” [Elektroda, piotrek gti_abf, post #20273095] Ignoring it caused a PLN 12 000 repair when teeth sheared at 220 000 km [Elektroda, carrot, post #20275751]
Why it matters: A snapped belt can wreck valves and pistons, turning a €150 kit into a €3 000+ engine rebuild.
• Factory interval: 180 000–210 000 km or 5 years for EA288/DTTC engines [Elektroda, Kantylena, #20275923; VW ElsaWin 2021].
• After the first change: 90 000–100 000 km or 5 years [Elektroda, piotrek gti_abf, post #20273095]
• EA288 has an extra wet belt for the oil pump—replace both together [Elektroda, carrot, post #20276004]
• Typical full kit + labour: PLN 1 400–2 100 in Poland [InterCars PL price list 2024].
• Failure example: PLN 12 000 repair after belt tooth loss at 220 000 km [Elektroda, carrot, post #20275751]
What interval does VW specify for the 2015-2023 2.0 TDI CR (EA288/DTTC)?
VW service data lists 210 000 km or 5 years, whichever comes first [VW ElsaWin 2021; Elektroda, Droppss, #21385806].
Is the first belt change different from later ones?
How does mixed versus highway driving affect the interval?
Does the calendar limit override mileage?
What happens if I stretch the interval?
Do EA288 engines have two belts?
Did the earlier EA188 2.0 TDI use only one belt?
Which belt brands equal factory quality?
How much does a complete timing-belt service cost?
Parts average PLN 800–1 200; labour 600–900 PLN, totalling about PLN 1 400–2 100 [InterCars PL price list 2024].
How can I confirm the correct interval for my VIN?
How do I inspect a belt before the due date?
- Remove the upper plastic cover.
- Check for cracks, missing teeth or frayed edges under strong light.
- Rotate crank 360° to view the full belt section.
If any damage appears, replace immediately [Autodata 2024].
Why do mechanics advise shorter intervals than VW?
Should I change the water pump and rollers together?
What about the wet oil-pump belt’s life?
VW lists the wet belt for replacement together with the dry belt—max 210 000 km or 5 years [VW ElsaWin 2021].
