[Solved] Wireless socket thermostat with separate temperature sensor for cooker control
mlewan 1044 2
  • #1 20291666
    mlewan
    Help: 26
    Rate: 92
    Hi.
    I am looking for a solution for switching on the cooker using a device in the socket (currently I just have a timer there), with the temperature sensor to be in another part of the house. All wireless. What do you recommend?
    Thank you in advance for your answers :) .
    csvrbntyu
    Level 30  
    Help: 163
    Rate: 405
    Tuya. 2 devices on Wifi, wireless switch to the cooker, thermostat where you want it and with the app you set the automation - what should happen when.
  • #3 20291825
    mlewan
    Help: 26
    Rate: 92
    Thank you very much, the answer explains everything.
