Control of the Led's on the ceiling connected to the lighting line - shelly ?
yhmmm 804 1
  • Use a Shelly relay with wall button control
    #1 20327781
    yhmmm
    Hello, I have a specific problem ;) .
    The masters doing the finishing touched up the ceiling auxiliary lighting (led strips in the built in) to the current from the lamps in two places. They gave simple controllers: Milight FUT036S and wired under a button from the same company.... works because it switches off, on.
    The problem begins, for example, when the power goes out, because these LEDs start automatically when the power returns and you have to switch them off using the button. The controller is not programmable and nothing can be done there....
    Does anyone have any idea how to secure and control it so that the LEDs do not automatically switch on when the fuse is reset? I have a Shelly 2.5 on the external roller shutters and it works, ok I found a Shelly 1pm could I manage it in a simple way? For example, remove the Milight controller and put a Shelly in front of the power supply and a button for it?
    Shelly is a suggestion, I don't need a phone control, just something to secure the LEDs and a wall button.
    I bet a big beer for your help! ;) .
  • Shelly emergency power mode for lighting control
    #2 20335523
    AdrianHDmaxxx
    Help: 11
    Rate: 16
    As for Shelly, yes, you can use it to secure the lighting. You can set it to turn the lighting off when the power is switched off, and on when it is switched back on. You can also combine it with a wall button to allow you to turn lights on/off with the push of a button.
    How to do it ?
    To programme Shelly, you first need to connect it to your Wi-Fi network and register it with the Shelly app. You then need to open the app and go to the Settings tab. In the „Operating mode” section, you can select the „Emergency power” mode. Here you can choose whether you want to switch the lighting off when the power is switched off and also on when it is switched back on.
    If you want to use a wall button, you can configure it under „Button settings”. Here you can configure the operation of the button, such as turning the lighting on/off or changing the brightness.
    I hope this helps.
