Sonoff S-Mate: Simultaneous Activation of Two Buttons Issue with Mini R3
self2 876 0
  • Simultaneous key presses only trigger one scene
    #1 20347334
    self2
    I have connected a sonoff s-mate to a two-key switch, and there are two sonoff mini R3s at the lamp. All with an 'old-style' installation, where I only have an L input and two L outputs in the box under the switch. Properly paired of course, with scenes set up.
    And everything works almost fine. I.e. I am able to switch on the corresponding bulbs using both keys of the switch. However, there is one 'but' in this operation. When I toggle both keys at the same time (a typical situation when leaving/entering a room and turning the entire lamp off or on), only one action (one bulb) switches. A separate switch click has to be spent on the other. In addition, at this point the keys will remain 'out of sync', i.e. one is up, the other down.
    It is as if the two actions cannot work at the same time,
    Anyone noticed this and solved it somehow? Maybe some ideas on how to configure the actions?
    Greetings
    Rafal Wysocki
