Youtube Vanced - video cannot be played - reason, bypassing Google ban, HUAWEI
csvrbntyu 39537 19
  • Hi.
    For a few days, random people stopped working Youtube Vanced. The app launches, loads videos and when I select a video it says "The video cannot be played in this app".
    The reason turned out to be simple - money. Google did not like the free bypassing of ads, and began to ban microG access to the google account, so the effects are as above. It helps to change the Google account logged into the microG, or logging in there not with the "Sign in" button, but "HUAWEI" . Login to your Google account looks identical, the operation of the application also, but Google bans no longer affect the application.
    I hope that positioning the forum in Google will make it reach more people, because I was sitting on the puzzle for several days.
    Regards.
    csvrbntyu
    Level 30  
    csvrbntyu wrote 1394 posts with rating 405, helped 163 times. Been with us since 2022 year.
  • #2 20534377
    Maronpl
    Unfortunately, after logging in via the HUAWEI button, video playback still does not work. Only after changing to another profile assigned to the same email address, it causes the videos to play, but it is a different profile, so subscriptions, favorite videos, etc. are not visible. You'd have to re-subscribe.
    But for a moment there was a glimmer of hope ;)
  • #3 20544991
    bartoszgrzyb36
    Rate: 8
    How something revanced works and there is a similar link
    Here
    https://revanced.net/
    You download microgvanced
    And then you install yt
  • #4 20546366
    piotrek2500
    An error occurred while parsing the package. This yt revanced doesn't work
  • #5 20546809
    siudziu1
    Yesterday there was also a problem with vanced, I uninstalled the vanced manager, restarted the phone, installed the vanced manager from now + tube + microg and it works, it's strange because it works on my S21 ultra all the time.
  • #6 20547849
    staś pytalski
    Help: 760
    Rate: 1436
    siudziu1 wrote:
    Yesterday there was also a problem with vanced, I uninstalled the vancedmenager, restarted the phone, installed the vanced manager from now + tube + microg and it works, it's strange because it works on my S21 ultra all the time.
    The installer can no longer be downloaded from vancedapp.com.
  • #7 20547869
    internick
    Level 36  
    Help: 273
    Rate: 555
    Both Vanced (17.33.42) and ReVanced (18.14.41) lie at 4pda.
  • #8 20547882
    staś pytalski
    Help: 760
    Rate: 1436
    I have YT Vanced 3/17/38 can't update manager. It says that I can't watch the movie. Interestingly, on the older phone the same configuration still works, even recently downloaded. I think it's a matter of days when they will block.
    I will try to download another version.
  • ReVanced Extended 17 works as Vanced replacement
    #9 20549168
    rzoska
    Rate: 22
    Unfortunately, Vanced died. I had an older version that I didn't update as soon as I heard Vanced was about to be released. Maybe that's why it worked for me for so long, and more precisely, only recently I saw a message that the content could not be displayed. Combining with older or newer versions is unlikely to do anything. On my S20FE it doesn't work. HOWEVER ! Recently, I have been testing the YouTube ReVanced Extended application in version 17 with great success. It is practically a Vanced clone with the latest developments. So far it's been working great and I hope it stays that way.
  • #10 20556014
    nevisek77
    Revanced is cool, but I still have a problem with stopping the movie on average every few minutes ... The screen goes black and you have to start a new movie to make something move. Has someone solved this problem?
  • #11 20557318
    goryl011
    nevisek77 wrote:
    Revanced is cool, but I still have a problem with stopping the movie on average every few minutes ... The screen goes black and you have to start a new movie to make something move. Someone solved this problem?
    I have the same problem, on average every 40 seconds everything stops. Maybe it's a settings issue but I doubt it. They're probably already taking revanced 😒
  • Repatching ReVanced APK fixed playback issue
    #12 20557390
    0wawak0
    I was able to fix the playback issue. The description is on Reddit, just write it in the search engine and the first result from the shore. Download Youtube ReVanced and "patch" the installer (.apk file) using the Revanced Manager application.
    Search in google:
    "ReVanced Manager guide for dummies
    Guide last updated: 2023-04-25"
    I don't know if I can post links, so please do your own research.
    But to make things worse, background playback doesn't work. I'll let you know how I deal with it.
    edit:
    You have successfully repaired the revanced application by following the instructions. Apparently I messed something up during patching previously. Everything works. The only functionality that doesn't seem to work is the sponsor block but it's not a problem.
    Remember to download YT ReVanced from official sites because there are a lot of fake websites with a supposedly ready-made .apk file that can be infected!
  • #14 20567367
    nutergsm
    Help: 1034
    Rate: 1665
    I recommend the NewPipe app.
  • ReVanced workaround fixed background playback on Huawei
    #15 20603730
    rzoska
    Rate: 22
    >>20564881
    BruceD - Thanks to the "King of Gold"! I was already broken because, unfortunately, ReVanced stopped working for me again. Not only playing in the background, but after 2-3 minutes it stopped playing. I got angry and took the YT Premium trial period to test it. And what? And ..wno. The YT application normally, i.e. with the screen on, worked properly, but when the screen was turned off after 2-3 minutes it stopped playing. I installed what you provided in the link and so far it works perfectly.
  • #16 20603915
    BruceD
    You are welcome. I use this app almost every day, as does my colleague from work, and it has never jammed even for a second.
  • #17 20618973
    Stanley_P
    Help: 62
    Rate: 294
    rzoska wrote:
    >>20564881
    I join the thanks. The old Vanced stopped working for me in exactly the same way as described in the first post. It helped to switch to a different account, but you know - this is not it.
    I'm adding a link to YT Music Revanced - HERE . It works fine for me, you can listen in the background and without ads :-)
    Regards.
  • #18 20689652
    loganmiller976
    >>20556014
    Sounds frustrating! I haven't encountered that issue with https://revancedyoutube.org/ Revanced. Maybe try updating the app or checking your device settings. If the problem persists, reaching out to their support could help. Happy streaming.
  • #19 21319302
    rohansharmaa41
    If you're encountering the 'video cannot be played' error on YouTube Vanced due to bypassing the Google ban on your Huawei device, https://vancedyoutube.org/ it might be because of restrictions. Try clearing the app's cache, reinstalling, or using alternative methods like an APK update to resolve the issue and restore functionality for uninterrupted viewing.
  • #20 21344708
    anchor32
    YouTube Vanced Apk is 100% secure and confirmed through numerous anti-virus & anti-malicious locators. All bugs & glitches are settled in the most recent overhaul of this vanced app. https://youtubevanced.dev/
YouTube Vanced users have encountered the error "The video cannot be played in this app," primarily due to Google restricting microG access to Google accounts, which disables ad bypass functionality. Workarounds include switching Google accounts within microG or using alternative login methods such as the "HUAWEI" button, though these are not consistently effective. The original Vanced app is largely considered defunct, with many users transitioning to YouTube ReVanced, a community-driven fork offering similar features and ongoing updates. ReVanced requires patching the APK via the ReVanced Manager to restore playback functionality, but some users report intermittent playback issues such as video freezing or stopping every few minutes. Alternative apps like NewPipe and YT Music ReVanced are also recommended for ad-free playback and background listening. Official download sources are emphasized to avoid malware risks. Device-specific reports include Samsung Galaxy S21 Ultra and S20 FE, with varying success in app functionality. The Vanced installer is no longer available from official sites, pushing users toward ReVanced and other third-party solutions.
TL;DR: On some devices playback stops after 2–3 minutes; "ReVanced stopped working for me again." Installing a different build restored background play. [Elektroda, rzoska, post #20603730]
Why it matters: This FAQ helps Android users fix YouTube Vanced/ReVanced playback errors, bans, and freezes, including Huawei-specific sign-in issues.
How do I fix “The video cannot be played in this app” on YouTube Vanced?
Google blocked microG sign-ins, which triggers this message. Two fixes helped users: change the Google account used in microG, or log in using the HUAWEI button within microG. Both actions can bypass the ban and restore playback. If you still see the error, move to ReVanced or re‑install with clean components. [Elektroda, csvrbntyu, post #20399380]
The HUAWEI button didn’t help—what else can I try?
Switch to another profile tied to the same email. That allowed playback for at least one user, but subscriptions and favorites were not visible on that alternate profile. You would need to re‑subscribe on the working profile to rebuild your feed. This is a trade-off to regain playback quickly. [Elektroda, Maronpl, post #20534377]
Why did YouTube Vanced stop working—is it dead?
A user reports, "Vanced died." Older installs now show content errors, and mixing versions does not help. Migrating to YouTube ReVanced Extended v17 worked well as a modern replacement and provided stable playback. Expect ongoing changes, so keep your build maintained. [Elektroda, rzoska, post #20549168]
Where can I get working builds if the official site is down?
Some users sourced builds from 4pda, citing Vanced 17.33.42 and ReVanced 18.14.41. Availability changes often, and mirrors vary by region. Verify integrity before installing and prefer trusted sources when possible. Community-shared mirrors may disappear without notice. [Elektroda, internick, post #20547869]
Why can’t I download Vanced Manager from vancedapp.com?
The Vanced installer is no longer downloadable from vancedapp.com. That shutdown blocks straightforward reinstalls and updates from the original channel. You will need to rely on community tools or migrate to ReVanced with a proper patching method. [Elektroda, staś pytalski, post #20547849]
How do I properly install YouTube ReVanced?
Use the ReVanced Manager patch method.
  1. Install ReVanced Manager from its official source.
  2. Download the supported YouTube APK and patch it with Manager.
  3. Install the patched APK and test playback features. “Everything works,” after repatching correctly, noted one user. Also, download only from official sources to avoid fakes. [Elektroda, 0wawak0, post #20557390]
Why do my videos freeze every ~40 seconds on ReVanced?
Users report recurring freezes, for example, “on average every 40 seconds everything stops.” One user doubted a settings cause. This points to app or patch-level issues rather than your configuration. Try a fresh patch or an alternate build as a next step. [Elektroda, goryl011, post #20557318]
How can I stop the freezes or black screen mid‑video?
One user concluded the stalls were ads that the app failed to skip. Installing a different APK build immediately removed jamming, with no freezes afterward. “It hasn’t jammed once,” they reported after days of use. If your build stalls, try a known working variant. [Elektroda, BruceD, post #20564881]
Does ReVanced Extended work as a reliable Vanced replacement?
Yes. A user had “great success” with YouTube ReVanced Extended v17. They called it “practically a Vanced clone” with current patches. If classic Vanced fails, Extended is a strong drop‑in with familiar features. Maintain updates to keep stability. [Elektroda, rzoska, post #20549168]
Is there a simple, lightweight alternative client?
Try NewPipe. A forum member recommends it as an alternative to Vanced/ReVanced. It suits users who want a straightforward solution without Google account integration. It is a quick way to continue watching without patching workflows. [Elektroda, nutergsm, post #20567367]
Background playback stops after 2–3 minutes—how do I restore it?
One user saw background audio stop after 2–3 minutes, even on YouTube Premium. Installing an alternate build shared in the thread restored stable background playback. If your background play times out, try a different working build. [Elektroda, rzoska, post #20603730]
A clean reinstall of Manager + Tube + microG helped on S21—should I try that?
Yes. Removing Vanced Manager, rebooting, and reinstalling Manager, Tube, and microG restored playback for a Galaxy S21 Ultra user. A clean sequence can clear broken dependencies or outdated components. Reboot between uninstall and reinstall for best results. [Elektroda, siudziu1, post #20546809]
I get “An error occurred while parsing the package” with ReVanced—what should I do?
Re‑patch the YouTube APK with ReVanced Manager and reinstall. One user fixed install and playback issues by following the Manager guide and repatching correctly. “Apparently I messed something up during patching previously.” A fresh, correct patch often resolves install errors. [Elektroda, 0wawak0, post #20557390]
How do I get ad‑free background music with YouTube Music?
Install YouTube Music ReVanced from the referenced source. A user reported it works fine, including background listening and no ads. If video clients are unstable, Music ReVanced can cover audio needs reliably. Keep to trusted sources when installing. [Elektroda, Stanley_P, post #20618973]
Are third‑party “ready APK” sites safe to use?
Exercise caution. A user warns there are many fake sites offering pre‑patched APKs that may be infected. “There are a lot of fake websites with a supposedly ready‑made .apk file that can be infected!” Prefer official or well‑vetted sources. [Elektroda, 0wawak0, post #20557390]
