How to upload new software to ODU? T-Mobile Internet 5G Home Office.
franieczek 16764 14
Can I upload new software to the T-Mobile ODU to fix a blinking IDU and no Internet, or is the ODU’s Ethernet/RJ45 port damaged?
You probably cannot fix this by uploading software; the more likely fault is a damaged RJ45/Ethernet port in the ODU. First bypass the IDU and connect the Ethernet cable directly between the ODU and a computer to check whether the link comes up, and try a different Ethernet cable as well [#20468678] [#20469556] If the computer still shows that the Ethernet cable is not connected or you cannot reach the ODU at 192.168.x.x, that points to a damaged port on the ODU [#20469443] [#20469376] The cable also carries PoE power, so the modem may still light up and show 4G/5G even when data lines in the connector are bad [#20469556] The suggested repair is to find a service that can replace the damaged RJ45 port, although such repairs are uncommon [#20470234]
  • Broken Ethernet clips likely causing IDU link failure
    #1 20468619
    franieczek
    >>20420625
    Good morning, hello colleagues and I’m asking for help, I have Home Office from T-Mobile, odu shows 4G coverage on the application, it is connected to the Internet, but on the idu router the diode is flashing all the time and there is no Internet connection, I have already reset everything and still nothing, the diode is blinking when I connected the second one connects the same antenna immediately. Is there any way to upload new software to Odu, T Mobile they claim that there is mechanical damage, the Ethernet cable clips are broken and they do not take into account complaints, they want PLN 1,700 for the repair, i.e. replacement with a new one at my expense, please help
    Moderated By jimasek:
    I have separated a new thread
    3/1/19. Do not send messages in archived topics if it is another question, especially a different one from the person asking. Out of respect for the questioner, start your own topic. You can only add a way to solve the problem.
  • #2 20468678
    matek451
    Help: 4352
    Rate: 5808
    But specifically o is damaged, the ODU has an Ethernet port, you plug the cable from the IDU into it, you checked whether the connection works, skip the ODU and plug the Ethernet cable directly to the computer and on the other side to the ODU.
  • #3 20469079
    franieczek
    The internet cable is connected to the power supply and the power supply to the router
  • #5 20469376
    franieczek
    When I connect directly to the computer, I cannot connect to ODU 192.168.
  • #6 20469443
    matek451
    Help: 4352
    Rate: 5808
    If on the Ethernet card you have a connection status of the type: Ethernet cable not connected, it means that the port in the ODU is damaged as T-Mobile informed you.
  • #7 20469524
    franieczek
    When I go through the application, it says that Internet access is connected, but it is possible that the socket is damaged, which is why it does not send data to the computer or to the ID. Do you know if it can be repaired?
  • Check Ethernet cable, PoE power, and LED colors
    #8 20469556
    matek451
    Help: 4352
    Rate: 5808
    This Ethernet cable also provides POE power to the external modem, so theoretically this power supply may work and the modem will connect to the Internet, but if the PINS in the Ethernet connector are damaged, data transmission to the IDU or Ethernet card in the computer may not work, I also show access to 5G/4G these diodes at the connector and next to the power supply. The power one and one of the 5G or LTE lights are on, what colors? Have you tried with a different Ethernet cable?
  • #9 20469942
    franieczek
    Simple and interlaced, nothing helped, when I returned it to T-Mobile, it said it was mechanically damaged and they wouldn't replace it with a new one, and it's been like that since I received it, so I have to pay and have it go wrong, that's why I'm looking for a solution myself, but I'll probably have to take it to some service center.
  • #11 20470210
    franieczek
    Yes, the only thing I know about it is that T-Mobile is reluctant to repair or replace it, so what should I do, the device doesn’t work, if I repair it, I lose the manufacturer’s warranty in installments and I pay off the device anyway, I don’t sell it, I just want to repair it
  • ODU repair requires RJ45 port replacement
    #12 20470234
    matek451
    Help: 4352
    Rate: 5808
    You need to look for a service that will replace the damaged RJ45 port with a functional one, it won`t be easy because practically no one does it. And the equipment is problematic anyway, I have it at home, strange configuration, low antenna gain. In addition, it`s a weak IDU router, exotic. No Bridge mode on the ODU, no signal diagnostics, overall a failure compared to the 5G CPE from ZTE, i.e. MC7010. He didn`t make a career, the only advantage is his low costs at T-Mobile.
  • #13 20470263
    franieczek
    Thank you for your help and best regards
  • #14 21203809
    XdekHckr
    >>20469942 .
    If it's been like this since you received it, why didn't you report it straight away? I had problems with the SIM card not being detected and they replaced the whole ODU for me in a few days for free.
  • Check Ethernet cable, PoE power, and LED status
    #15 21618931
    gracjanbijak3
    matek451 wrote:
    This Ethernet cable is also the POE power supply for the external modem, so in theory this power supply can work and the modem will connect to the internet, but if the PINS in the Ethernet connector are damaged, then data transmission to the IDU or Ethernet card in the computer may not work. Access to 5G/4G is also shown by these LEDs next to the connector and next to the power one. The one for power and any of the 5G or LTE ones are lit - what colours are they? Have you tried with a different Ethernet cable?
    matek451 wrote:
    This Ethernet cable is also the POE power to the external modem, so theoretically this power could work and the modem would connect to the internet, but if the PINS in the Ethernet connector are damaged, then data transmission to the IDU or Ethernet card in the computer may not work. Access to 5G/4G is also shown by these LEDs next to the connector and next to the power one. The one for power and any of the 5G or LTE ones are lit - what colours are they? Have you tried with a different Ethernet cable?
The discussion concerns a T-Mobile Home Office 5G internet set with an outdoor ODU and indoor IDU router, where the ODU shows 4G/5G connectivity in the app but the IDU has a blinking LED and no usable internet connection. Troubleshooting included resets, checking the Ethernet/PoE link, bypassing the IDU, and testing with another antenna/cable, but the problem persisted. The main suspected fault is mechanical damage to the ODU Ethernet RJ45 port or its pins, preventing data transfer even though power and radio status may still work. Participants concluded that firmware upload is not the likely fix and recommended hardware repair by replacing the damaged RJ45 socket or using a service center; one reply also noted that T-Mobile may replace the whole ODU under warranty in some cases.
TL;DR: 1 Ethernet cable carries PoE and data; "if the PINS in the Ethernet connector are damaged, data transmission may not work." Skip firmware fixes, test a direct PC link, and treat it as hardware first. [Elektroda, matek451, post #20469556]
Why it matters: This FAQ helps T‑Mobile 5G Home Office users diagnose ODU/IDU "connected but no internet" issues and decide when repair or swap beats a firmware chase.
How do I quickly diagnose “ODU shows 4G, IDU blinks, no internet”?
Diagnose the Ethernet link first, not firmware. 1. Ensure the ODU is powered. 2. Connect a PC directly to the ODU, bypassing the IDU. 3. If the OS shows “Ethernet cable not connected,” the ODU Ethernet port is damaged. That is a hardware fault, not a software issue. [Elektroda, matek451, post #20469443]
Can uploading new software/firmware fix this ODU issue?
No, firmware will not repair a bad Ethernet jack. The radio can attach while PoE works, yet data fails on broken pins. As one expert notes, “if the PINS in the Ethernet connector are damaged, data transmission may not work.” Replace or repair hardware instead. [Elektroda, matek451, post #20469556]
How do I test the cable versus the ODU Ethernet port?
Swap in a different Ethernet cable and observe LEDs near the ODU connector and power unit. If power and LTE/5G LEDs light, the radio link is up. If devices still show no Ethernet link or data, suspect damaged RJ45 pins or the ODU port. [Elektroda, matek451, post #20469556]
I can’t reach 192.168.x.x on direct connection—what does that point to?
If your PC shows “Ethernet cable not connected” when cabled directly to the ODU, the ODU’s Ethernet port is faulty. Without a physical link, no IP address or web UI can be reached. Replace the port or the unit to restore connectivity. [Elektroda, matek451, post #20469443]
Is RJ45 port replacement on the ODU possible, and who can do it?
It is possible, but finding a shop that will swap the damaged RJ45 is difficult. An experienced user notes that practically no one offers this service. If you locate a specialist, ask about warranty implications and sealing. [Elektroda, matek451, post #20470234]
How much might an out‑of‑warranty ODU replacement cost?
One user was quoted PLN 1,700 when T‑Mobile classified the fault as mechanical damage. Your cost can differ by contract and assessment. Use this as a ballpark when considering third‑party repair versus carrier swap. [Elektroda, franieczek, post #20468619]
Does the ODU support Bridge mode or provide signal diagnostics?
No. “No Bridge mode on the ODU, no signal diagnostics,” which limits integration with stronger routers and hinders RF analysis. Expect a basic, locked setup geared for plug‑and‑play rather than advanced tuning or monitoring. [Elektroda, matek451, post #20470234]
Who owns the hardware during the contract? Can I open it?
The T‑Mobile 5G Home Office set remains the operator’s property until the final subscription fee is paid. Before modifying or repairing the unit, contact T‑Mobile for guidance to avoid contractual issues. [Elektroda, matek451, post #20469977]
I reported a fault right away—does T‑Mobile swap the ODU quickly?
A user who had a SIM detection fault reports the ODU was replaced in a few days at no cost. Early reporting and clear fault description can speed resolution. Escalate promptly if the unit is defective on arrival. [Elektroda, XdekHckr, post #21203809]
Why does the app say “Internet connected” while devices have no data?
PoE can power the ODU and let it attach to LTE/5G, lighting the radio LEDs. If RJ45 pins for data are damaged, Ethernet frames never reach the IDU or your PC. The app reflects radio status, not LAN link health. [Elektroda, matek451, post #20469556]
What LEDs should I check to separate radio access from Ethernet issues?
Verify the power LED and one LTE/5G LED on the ODU or near the injector. Lit radio LEDs mean the modem is on‑air. If there’s still no Ethernet link, focus on the cable and the ODU RJ45 port integrity. [Elektroda, matek451, post #20469556]
Is the bundled IDU router worth keeping, and what alternatives exist?
The bundled IDU is weak and the ODU is limited. One expert calls it “overall a failure compared to the 5G CPE from ZTE, i.e. MC7010.” If your plan allows, consider a stronger 5G CPE for better routing and Wi‑Fi. [Elektroda, matek451, post #20470234]
