Optimizing ODU IDU 200 LTE Plus Internet Speed: Solutions for Stable Connectivity
rychu123Xqi 5436 3
  • #1 16379427
    rychu123Xqi
    I have a problem with the Internet from the very beginning it worked like the speedtest shows and I don't know what to do with it. Optimizing ODU IDU 200 LTE Plus Internet Speed: Solutions for Stable Connectivity help
  • #2 16379584
    sebap
    Help: 538
    Rate: 1082
    Give back the trash that is Odu Idu.
  • #3 16380124
    matek451
    Help: 4352
    Rate: 5808
    Start by entering the location. You have these speeds on LTE1800aero2 or LTE800Sferii, how far to BTS. Show screenshots from status on IDU, signal parameters. The BTS you are using is massively overloaded, in Plus it is the norm in many locations, it is a poor operator. Sometimes the only solution is to force the connection to another unloaded Plus BTS. for this purpose external directional antennas are used for the selected band. IDU-ODU 200 is scrap, it has a poor omnidirectional antenna in the ODU, it works like that at short distances from the BTS. Nobody oriented will take it, it is an electric break for me. I follow the opinion of the predecessor.
  • #4 16381512
    KOCUREK1970
    Help: 3861
    Rate: 5489
    rychu123Xqi wrote:
    Free internet help ODU IDU 200 LTE in the plus
    And what did he read in the instructions ?:
    WARNING!
    o Do not mount the set if you have an antenna system
    with multi-switch devices.
    o Do not mount amplifiers between ODU and IDU devices.
    o Filters, tees, antenna sockets with filters, installed in the installation
    antenna and "cutting off" signal at 2.4 GHz may cause
    malfunction of the set, or completely prevent its operation.
    o ODU-200 and IDU-200 devices are not compatible with IDU-100 devices
    and ODU-100!
    Do you have it mounted "solo", or via satellite or other TV?
