IDU ODU 200 Connection Issue: Green LED on ODU, No Connection with Panel, Firmware Update Problem
mastibdg 5364 4
  • #1 16727433
    mastibdg
    Rate: 15
    Hello! I have a problem with the IDU ODU 200, everything was ok, and since yesterday it is not working, only the green LED is lit on the ODU, which was not there before, and of course the panel says that there is no connection with the IDU and ODU. I wanted to update the ODU firmware, but I can not connect without a connection, the factory settings also do not give anything, cables checked. Anyone have any ideas or just a service?
  • #2 16728318
    sosarek
    Help: 9320
    Rate: 15532
    If the cables are working, it is probably a damaged modem in the antenna - contact CP.
    Z
    Pka, Poznań, 60-850
  • #3 16728327
    matek451
    Help: 4352
    Rate: 5808
    And where does this "wonder of technology" from CP work. Have you used LTE1800 or LTE800 and what were the signal parameters before?
  • #4 16729323
    mastibdg
    Rate: 15
    The location is Bydgoszcz, os. Common. I checked on various, preferably on this 2600, probably, the download speed reached 90mb, and suddenly there is no connection to the odu.
    The signal was blue all the time, almost full.
  • #5 16733942
    KOCUREK1970
    Help: 3860
    Rate: 5488
    mastibdg wrote:
    I have a problem with IDU ODU 200
    How did you get it all connected together?
    The coaxial cable from the roof is technically sound?
    A technically functional SIM card?
