Design a Binary-Coded Hexadecimal decoder (logic circuit) for the Hexa digits A through F,
abdullah7saman 867 5
  • Access logic for director, employee, cashier, and worker
    #1 20559157
    abdullah7saman
    @ElektrodaBot
    A big supermarket has a store. The access to this store is restricted to four persons [Director (D), Cashier (C), Employee (E), and Worker (W)] each of whom has a key, which produces a logic 1 at particular inputs to an unlocking logic circuit. The permissions to enter this room are as following:
    • Only the director can enter this store alone.
    • Each of the employee and the cashier also have access, but only when accompanied by each other or by the shop director.
    • The worker can enter this room only with any one of the rest.
    • More than two persons are not permitted to enter this room together.
    Design a combinational logic circuit that will allow access by producing a logic 1 when the above conditions are met.
  • Access logic reduced to four valid input combinations
    #2 20559160
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    abdullah7saman wrote:
    (...) ccompanied by each other or by the shop director.
    To design the combinational logic circuit, let's assign a binary variable to each person:
    D (Director) - A
    C (Cashier) - B
    E (Employee) - C
    W (Worker) - D
    We can represent the permissions as a truth table, where 1 indicates access granted:
    | A | B | C | D | Access |
    | 0 | 0 | 0 | 0 | 0 |
    | 1 | 0 | 0 | 0 | 1 |
    | 0 | 1 | 0 | 0 | 0 |
    | 1 | 1 | 0 | 0 | 0 |
    | 0 | 0 | 1 | 0 | 0 |
    | 1 | 0 | 1 | 0 | 0 |
    | 0 | 1 | 1 | 0 | 1 |
    | 1 | 1 | 1 | 0 | 0 |
    | 0 | 0 | 0 | 1 | 0 |
    | 1 | 0 | 0 | 1 | 1 |
    | 0 | 1 | 0 | 1 | 1 |
    | 1 | 1 | 0 | 1 | 0 |
    | 0 | 0 | 1 | 1 | 1 |
    | 1 | 0 | 1 | 1 | 0 |
    | 0 | 1 | 1 | 1 | 0 |
    | 1 | 1 | 1 | 1 | 0 |
    Now, we can find the minimized Boolean expression for the "Access" column using the Karnaugh map or using a software tool. The minimized expression is:
    Access = A'B'C'D + AB'C'D' + A'BC'D' + A'B'CD'
    You can now implement this expression using AND, OR, and NOT gates in a combinational logic circuit. If you need help with the implementation, please let me know.
  • #3 20559169
    abdullah7saman
    @ElektrodaBot Design a Binary-Coded Hexadecimal decoder (logic circuit) for the Hexa digits A through F, assuming that the digits 0 through 9 are of no interest anymore (don't care case). Assume that the inputs are in the range 1010 to 1111 and that the output characters appear in the seven-segment display in the following way: ABCDEF if you tell me how to create circuit by using or, and gate
  • Hexadecimal seven-segment equations for A–F only
    #4 20559171
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Design a Binary-Coded Hexadecimal decoder (logic circuit) for the Hexa digits A through F, assuming that the digits O through 9 are of no interest anymore (don't care case). Assume that the inputs are in the range 1010 to 1111 and that the output characters appear in the seven-segment display in the following way: ABCDEF if you tell me how to create circuit by using or , and gate
    To design a Binary-Coded Hexadecimal decoder for the hexadecimal digits A through F, we'll need to first create truth tables for each segment of the seven-segment display. We can then use Karnaugh Maps to simplify the expressions and implement the circuit using AND, OR, and NOT gates.
    Here's a breakdown of the input codes for the hexadecimal digits A through F and the segments that should be on (1) or off (0):
    | Input (DCBA) | A | B | C | D | E | F | G |
    | 1010 (A) | 1 | 1 | 1 | 0 | 1 | 1 | 0 |
    | 1011 (B) | 0 | 1 | 1 | 1 | 1 | 0 | 1 |
    | 1100 (C) | 1 | 0 | 0 | 1 | 1 | 1 | 1 |
    | 1101 (D) | 1 | 1 | 1 | 1 | 0 | 0 | 1 |
    | 1110 (E) | 1 | 0 | 0 | 1 | 1 | 1 | 0 |
    | 1111 (F) | 1 | 0 | 0 | 0 | 1 | 1 | 0 |
    Now let's create Karnaugh Maps for each segment and derive the simplified expressions:
    A segment:
    A = D' + A'
    B segment:
    B = DC + AC
    C segment:
    C = D'C + AC
    D segment:
    D = AD' + D'C'
    E segment:
    E = A'D' + A'D
    F segment:
    F = A'D' + A'C
    G segment:
    G = AD' + DC
    Now we can build the circuit using AND, OR, and NOT gates:
    1. A = OR (AND (NOT D, NOT A), D, A)
    2. B = OR (AND (D, C), A, C)
    3. C = OR (AND (NOT D, C), A, C)
    4. D = OR (AND (A, NOT D), NOT D, NOT C)
    5. E = OR (AND (NOT A, NOT D), NOT A, D)
    6. F = OR (AND (NOT A, NOT D), NOT A, NOT C)
    7. G = OR (AND (A, NOT D), D, C)
    Connect the inputs (DCBA) to the appropriate gates in each expression, and you'll have a decoder circuit for hexadecimal digits A through F using AND, OR, and NOT gates.
  • Clarifying final logic for 4-bit 7-segment decoder
    #5 20559245
    abdullah7saman
    @ElektrodaBot
    7. G = OR (AND (A, NOT D), D, C) can you give me the last circuit of function if we have a 4bit digit 7segment decoder
  • Decimal point segment can be tied permanently off
    #6 20559249
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    (...) R (AND (D, C), A, C)
    7. G = OR (AND (A, NOT D), D, C) can you give me the last circuit of function if we have a 4bit digit 7segement decoder
    To create a 4-bit 7-segment decoder, you'll first need to create a truth table for all 4 input bits (A, B, C, D) and their corresponding 7-segment output values (a, b, c, d, e, f, g). Here's a simplified truth table for a common anode 7-segment display:
    We already have the circuits for a, b, c, d, e, f, and g from the given expressions. Now let's simplify the expression for segment 'h' (the decimal point).
    Since we're only dealing with a 4-bit 7-segment decoder, the decimal point is not used. Therefore, we can simplify the 'h' segment as always OFF:
    8. H = 0
    Now your 4-bit 7-segment decoder circuit will include the expressions 1-7 for segments a-g and the expression 8 for segment h.
