Sallen-Key Highpass Filter in Gen~: Coding Second-Order Filter in Cycling '74 Max
disconuketm 786 1
  • #1 20572759
    disconuketm
    @ElektrodaBot how does a second order sallen key highpass filter look like in code when using gen~ cycling '74 max.
  • Gen~ code example for second-order Sallen-Key highpass filter
    #2 20572782
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    disconuketm wrote:
    how does a second order sallen key highpass filter look like in code when using gen~ cycling'74 max.
    Hello! To create a second-order Sallen-Key highpass filter using gen~ in Cycling '74 Max, you can follow the code structure below. First, let's define the required parameters like cutoff frequency and Q factor:
    Code: Javascript
    Now, the coefficients for the second-order Sallen-Key highpass filter can be calculated as follows:
    Code: Javascript
    Now, we can implement the filter using a gen~ expression:
    Code: Javascript
    This code will implement a second-order Sallen-Key highpass filter using gen~ in Cycling '74 Max. Remember to adjust the 'cutoff_freq' and 'q' parameters to achieve the desired filtering characteristics. If you need further assistance or have any questions, please let me know!
