Clonagem de BSI Peugeot 208 Delphi: Como resolver problema de EEPROM casada com a flash?
Kanela 3435 6
  • #1 20630048
    Kanela
    Boa noite a todos!
    Estou precisando substituir uma BSI Delphi EL4, Peugeot 208 (ano 2022).
    Eu li a EEPROM 95128 da BSI original e li também a EEPROM da outra BSI.
    Clonei, porém o carro não funcionou, vi que a EEPROM é casada com a flash.
    Como posso clonar essa BSI?
  • #2 20631253
    olo-eu
    Help: 93
    Rate: 162
    What processor is there?
    OL-NET Olgierd Wiemann
    Kasprowicza 1/51, Iława, 14-200 | Tel.: +48 XXXXXXXXX (Show)
  • #3 20992139
    tirlip2018
    >>20630048
    you need connect to diagbox for online configuration. i done on mine after online configuration everything works fine
    >>20631253
    with diagbox do bsi replacement follow instruction. btw first you need get key code. i done mine everything works fine
  • #4 20992361
    kamyczek
    Help: 394
    Rate: 573
    Cloning only with the right equipment....
  • #5 21314033
    macko23b
    What equipment is capable of cloning this BSI? The UHDS doesn't seem to have it.
  • #6 21315838
    Tadas
    Help: 25
    Rate: 57
    olo-eu wrote:
    What kind of processor is sitting there?
    Maybe so .... uPD76Fxxxx
    Added after 3 [hours] 10 [minutes]: .
    >>20630048 .
    Send original and donor batches to bsi
  • #7 21727630
    luscikmartin
    If anyone needs a dump, it's from the new BSI, not installed in the car.
    EL4 EEPROM 95128
    • NOVA BSI EL4 CEM00_9830707780 00_HW D6_SW 6_05___S_3111964118_eeprom 95128_org.bin (16 KB) You must be logged in to download this attachment.
Discussion about replacing/cloning a Delphi EL4 BSI from a Peugeot 208 (2022) where copying only the 95128 EEPROM did not make the car work because the EEPROM is paired with the flash memory. Suggested approaches include online BSI replacement/configuration with Diagbox, obtaining the key code first, using the correct cloning equipment, and possibly transferring both original and donor data to the BSI. One reply mentions that the dump should come from the new BSI not yet installed in the vehicle.
