What WiFi switch to control the electric heater in a solar boiler?
przemneu 840 3
  • WiFi dry-contact switch for heater control
    #1 21246530
    przemneu
    Rate: 19
    Hello, I need a wifi switch that will be able to short and disconnect 2 wires connected to the switch without sending any voltage to them from each other. Can you recommend something?
    Context: i have an old boiler that has a solar heater and an electric heater. It has one potentiometer that turns off/adjusts the additional water heating with the electric heater.
    I want it to switch on on demand or at a specific time e.g. only in the evening for an hour reheating the water to the temperature set on the potentiometer. I can't make a wifi socket, because then it would also turn off the fluid pump in the solar heater, and this is supposed to work independently. So I would like to plug such a switch between the electric heater and its potentiometer controlling only the electric heater circuit.
  • #2 21246539
    kindlar
    Help: 919
    Rate: 1622
    You incorporate the heater into the sonofa.
  • #3 21246541
    MORT
    Help: 63
    Rate: 181
    You can use any wifi socket. Use the socket to switch on any additional relay for 230VAC and pass whatever you want through the relay contacts.
  • Directly switching the heater phase with a Tuya relay module
    #4 21246570
    przemneu
    Rate: 19
    Something like this wouldn't it?
    https://allegro.pl/oferta/przekaznik-dopuszko...ewodowy-modul-wifi-tuya-smart-16a-13838667790
    I would mount the control voltage for the relay itself and just plug in the phase wire going from the potentiometer to the heater.
    I don't really understand how I would use a wifi hub here.
    Added after 6 [minutes]:
    Okay, I understand the ... The extra relay, but maybe I could do without it if I used what I linked to.
