Selection of WI-FI thermostat to control the central heating circulation pump via UTP cable
oskarosi 1026 1
  • Clarifying Wi-Fi thermostat for remote pump switching
    #1 19713453
    oskarosi
    Hi
    Can I ask for your help in selecting a suitable device for the following diagram:
    Selection of WI-FI thermostat to control the central heating circulation pump via UTP cable .
    I would like to place a thermostat with Wi-Fi function in building 2, which can be wired between the buildings using UTP cable. In building no. 1 there is a central heating circulation pump whose operation I would like to control by switching 230V AC on/off.
  • #2 19715893
    mechanic8
    Help: 6
    Rate: 17
    If you want to run it over UTP, what do you need the Wi-Fi function for? To control it? If so, why an on/off control?
