IPv4 and IPv6 addresses in FTTH tmobile and orange, CG-NAT, ONT, PPPoE sessions
marcinfx585 18177 37
How do IPv4 and IPv6 addressing work on T-Mobile and Orange FTTH, including CG-NAT, ONT availability, and whether two PPPoE sessions can give public addresses?
T-Mobile FTTH is described as IPv4 behind CG-NAT by default, with some reports of a tested or requestable public IPv4 option; the thread does not settle a clear T-Mobile IPv6 mode [#20713591][#20945505] Orange FTTH is clearer: with a PPPoE username ending in `/ipv6` you get IPv6 (reported as a /64 or /48) and IPv4 via DS-Lite/AFTR, while a plain PPPoE session gives one public IPv4 and no IPv6 [#20713591] One poster says Orange can run both PPPoE sessions at the same time (`/ipv6` and without the suffix), but IPv4 throughput may drop compared with a single session [#20713591] For Orange, public IPv6 and IPv4 are also described as full dual-stack on their equipment, and ONT can often be arranged with the installer if agreed in advance, although official consumer availability and the exact procedure seem to depend on the region/network [#21388265][#20751808][#21042799] For T-Mobile ONT, reports conflict: one user says it can be requested or comes in the package, while another says an installer in his area refused it [#20945505][#21011239]
  • #31 21387701
    IC_Current
    Help: 1499
    Rate: 2521
    soulafein83 wrote:
    set up IPv6 with me
    On this neutered pseudo-blowout of an internet connection;
    soulafein83 wrote:
    from T-Mobile
    Besides, Matter and the rest work on IPv4 too, after all
  • Clarifying IPv6 setup and verification for Matter
    #32 21387992
    soulafein83
    IC_Current wrote:
    soulafein83 wrote:
    set up IPv6 with me
    soulafein83 wrote:
    from T-Mobile
    Besides, Matter and the rest, after all, also work on IPv4
    Hey. This is not an answer to the question. I just wanted to know how exactly to set up IPv6 and how to check if I have IPv6. I need IPv6 for Matter because that is the requirement of the Home Assistant plugin.
    So, if I may ask, please write in simple words if it can be done.
  • #33 21388018
  • #34 21388235
    IC_Current
    Help: 1499
    Rate: 2521
    You got the answer. The link from TM is a hollow and neuter for viewing pjs.
    There is NO IPv6. There is NO public IPv4.
    At most you can set up a VPN to some IPv6 tunnel broker.
  • MatterHub needs local IPv6 for Google Home
    #35 21388248
    soulafein83
    IC_Current wrote:
    soulafein83 wrote:
    I just wanted to know how exactly to set up IPv6 and how to check that I have IPv6.
    Ok thanks. That being said - my contract with T-Mobile ends in a month. I have the option to change my internet provider to INEA - do you happen to know if changing to this provider will change anything for me on the above topic (I want to stay on my Deco mesh)?
    Second thing - according to the specs Matter needs IPv6 local to work properly, although it also supports IPv4.
    In the MatterHub (addon to Home Assistants) documentation it states:
    "Therefore it is strongly recommended to activate IPv6 for your local area network. If your current network relies on IPv4, it should be no problem to run both in parallel. Some routers already have that activated by default.
    In addition, the matter protocol relies on a stable communication over TCP and UDP on port 5353 for mDNS and the configured Matter-port of your bridge. Make sure that there is no firewall or VLAN setup in place blocking the communication between the bridge and your controller."
    Maybe I'm misunderstanding something, but I have not been able to connect this MatterHub to e.g. Google Home, hence my question about IPv6.
  • #36 21388265
    IC_Current
    Help: 1499
    Rate: 2521
    I don't know about Inea. Not my regions. Public IPv6 and IPv4 is available in Orange in full dualstack (you can fasten two PPPoE sessions simultaneously) on their equipment. Only at start-up it is necessary to embrace ONT with the technician.
  • #37 21388267
    soulafein83
    IC_Current wrote:
    I don't know about Inea. Not my regions. Public IPv6 and IPv4 are available in Orange in full dualstack (you can zip two PPPoE sessions simultaneously) on their equipment. Only at start-up it is necessary to embrace ONT with the technician.
    I have written one more question above - I promise last ;) .
  • #38 21388268
    IC_Current
    Help: 1499
    Rate: 2521
    I am not familiar with this Matter or what principle it communicates with. If the system components on the LAN are to communicate via IPv6, then it is sufficient to use ULC addresses. However, if the communication is to leave the local network, then you already need global addresses from the operator.
T-Mobile FTTH connections on Orange infrastructure typically provide IPv4 addresses behind CG-NAT, similar to LTE networks, with public IPv4 addresses available optionally, sometimes for a fee or upon request. Customers receive PPPoE credentials (username and password) at contract signing, enabling configuration of sessions for IPv4 and IPv6. The ONT device is generally provided by T-Mobile technicians if requested in advance; refusal to install without ONT is possible, but may depend on region and technician discretion. Orange does not officially provide ONTs to individual customers unless specifically arranged. IPv6 is native and public on these networks, with no NAT applied to IPv6 addresses, though firewall rules may restrict inbound traffic. Orange uses NAT64 and CLAT for IPv6 on LTE/5G mobile networks. Dual PPPoE sessions can be configured to obtain separate public IPv4 and IPv6 addresses, but hardware acceleration for PPPoE/NAT may be lacking on some routers, impacting throughput. Public IPv4 addresses are scarce and often come with static assignment. Operators pre-configure ONT/router devices, limiting local technician configuration. Geolocation of IP addresses depends on geoIP databases but generally aligns with Orange Polska or TP-Net ASNs. Some users report vulnerabilities in operator-supplied devices and prefer to use their own ONT and routers. IPv6 support is important for modern protocols like Matter, with local IPv6 sufficient for LAN communication but global IPv6 needed for external access. Alternative providers like INEA may offer ONT and public IP configurations differing from T-Mobile and Orange. Overall, the network setup involves CG-NAT for IPv4 by default, native public IPv6, PPPoE authentication, and operator-controlled ONT provisioning with regional variability.
