Kemppi minARC 150: Low Arc Post IGBT, MUR 460 Diodes Replacement & Voltage Checks
pgbpowercontrol 1542 1
  • #1 20746042
    pgbpowercontrol
    Hello, I have a Kemppi minARC 150, the IGBT and MUR 460 diodes were replaced, which were destroyed, the machine managed to turn on but the arc is too low, I checked the voltage of the main source at 309V and the auxiliary source at 23.4V... 100% discarded main panel control module since I did cross tests and it is in good condition....could someone give me some help please, thanks
  • #2 20746216
    madamsz1
    Help: 1057
    Rate: 1711
    Check the welding current measurement system.
