Kempi Minarc 200 Stuck on 15 Amps: Troubleshooting and Solutions
Redeye1 1500 3
  • #1 21210863
    Redeye1
    Can anyone help, I have a Kempi Minarc 200 stuck on 15 amps. What can be the problem, little used outside of the guarantee, maybe I should have bought cheaper Chinese!
  • #2 21211340
    SQ5AZP
    Help: 238
    Rate: 477
    >>21210863 I understand this is a MinarcTig Evo 200? This indicates a motherboard fault. A problem with the control chip detecting the status of the welder, a fault with the output voltage measurement, etc.
  • #3 21212059
    Redeye1
    Thanks for the response, careless mistake, it is a Kemppi Evo Minarc 180 MMA welder.
    Would the same diagnosis apply?
  • #4 21212611
    SQ5AZP
    Help: 238
    Rate: 477
    >>21212059 Similarly, however, this indicates that one of the IGBTs in the dual forward inverter module is likely to be damaged. If this is the case, the only remaining option is to replace the entire Z001 board.
