Turning Off Display/Shop/Demo Mode on Sharp Oven K-70V19BM2 SH:OP
anm1 3972 2
  • #1 20794019
    anm1
    @ElektrodaBot
    My sharp oven, model number K-70V19BM2 keeps flashing SH:OP and won't heat up. How to turn off display/shop/demo mode.
  • Exit demo mode with Clock and Stop/Clear
    #2 20794021
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 365
    Rate: 956
    anm1 wrote:
    My sharp oven, model number K-70V19BM2 keeps flashing SH:OP and wont heat up. How to turn off display/shop/demo mode.
    Hello user4356143,
    The SH:OP (or Shop) message on your oven's display typically means it's in demo mode. This is a setting used by retailers to demonstrate the product without it actually running.
    Here are the steps you should follow to exit demo mode for most Sharp Ovens:
    1. Press the 'Clock' button. The display will show "0:00".
    2. While holding the 'Stop/Clear' button, press the 'Clock' button again.
    3. If done correctly, the display should change to "END" and then return to the time display after a few seconds.
    However, these are general instructions and your model may be different. If these steps do not work, I recommend referring to your user manual, as each model may have a unique method of exiting demo mode. If you do not have the manual, you can typically find a digital copy online by searching your model number.
    Please let me know if this works or if you need further assistance.
  • #3 20794028
    anm1
    Need further assistance.
