Nju fibre optic (orange) 300 Mbps with FunBox 3.0 router with Wi-Fi - or Netia fibre optic ?
czarny_alibaba 18816 30
Should I choose nju fibre optic from Orange with the FunBox 3.0 router, or is Netia fibre a better choice for a 300 Mb/s line?
Choose Orange/nju if you want the more stable and predictable option; one reply specifically recommends Orange, and another says Orange fibre works stably and predictably [#20797833][#20797870] If you need more control over your network, ask for an ONT terminal during installation so you can use your own router instead of being tied to the FunBox [#20797491][#20797916][#20797870] The FunBox 3.0 is described as decent for basic use and one user reports nearly three years of trouble-free operation, although it is an older device with mixed opinions [#20797870][#20797284][#20797276] Netia may also offer ONT/bridge options, but one reply warns that its support is poor and that you may get whatever hardware is in stock [#20798076][#20798085]
  • Explains SSID, LAN domain, and Windows network name
    #31 21609076
    IC_Current
    Help: 1499
    Rate: 2521
    czarny_alibaba wrote:
    I noticed that the LAN network name is assigned to the 2.4GHz WiFi network name?
    There are three independent identifiers.
    1. the SSID (identifies the point of connection to the radio network). You can change it at any time.
    2. local domain on the LAN. Usually not configurable or not used at all in SOHO equipment. The equivalent of .pl, .com etc, only used to identify hosts within a LAN. Sometimes it exists, but you don't have to enter it anywhere, nor do you know about it, because the home DNS server adds it itself when a request comes in from a host inside the network. This identifier is the most important for the cooperation of devices in the network.
    3. the identifier assigned by Windows. A kind of free American naming so that a non-technical user quickly knows what he is connected to. Useful, for example, to know that you have just disconnected from your home WiFi in the background and connected to a hotspot from your phone. This ID can be changed in the system registry (Windows 7 still had a graphical option) to whatever you like. It is probably this ID that you are referring to.
The discussion compares nju fibre optic (Orange) 300 Mb/s with FunBox 3.0 Wi‑Fi against Netia fibre offers, focusing on price, contract terms, router/ONT equipment, and service flexibility. Orange/nju is described as stable and predictable, with good interconnection and the option to request an ONT terminal instead of using the provider’s router, which allows use of a personal router and more advanced network features. FunBox 3.0 is reported to work reliably for basic use and can be wall-mounted horizontally, but it is considered an older device and some users prefer newer equipment such as FunBox 6.0. Netia is discussed as an alternative with Huawei HG8245Q2 router/ONT combo and promotional pricing, but concerns are raised about support quality and limited choice of supplied hardware. The thread also covers practical setup questions such as bridge mode, public IP, VLANs, IPv6, and whether to disable provider settings or keep the operator’s configuration unchanged.
TL;DR: Przy 300 Mb/s za 49 zł/mies. częściej polecano nju/Orange niż Netię, a najważniejsza rada brzmiała: „załatw ONT u technika”. Ten FAQ jest dla osób wybierających domowy światłowód i chcących uniknąć problemów z routerem operatora, własnym sprzętem i montażem FunBoxa 3.0. [#20797916]
Dlaczego to ważne: W tym wątku cena obu ofert jest zbliżona, ale o wygodzie na co dzień bardziej decydują stabilność, dostęp do ONT i możliwość użycia własnego routera niż samo 300 Mb/s.
Cecha nju / Orange Netia
Prędkość z wątku 300 Mb/s / 50 Mb/s 300 Mb/s lub 600 Mb/s
Cena miesięczna 49 zł 50 zł lub 1 zł przez 12 mies., potem 49,90 zł
Umowa na czas nieokreślony zwykle 24 miesiące
Sprzęt z wątku FunBox 3.0 z Wi‑Fi Huawei HG8245Q2 ONT combo
Elastyczność można wypowiedzieć bez dopłat promocja wiąże na 24 mies.
Kluczowy wniosek: Jeśli chcesz po prostu stabilnego internetu, Orange/nju zebrał w wątku lepsze opinie. Jeśli planujesz własny router, VPN, DDNS lub rozbudowane Wi‑Fi, kluczowe jest uzyskanie terminala ONT podczas instalacji.
  • nju/Orange w omawianej ofercie dawał do 300 Mb/s pobierania, 50 Mb/s wysyłania, 49 zł miesięcznie i 50 zł jednorazowej instalacji. [#20796927]
  • Netia była opisana w dwóch wariantach: 300 Mb/s za 50 zł/mies. albo 600 Mb/s za 1 zł przez 12 miesięcy i 49,90 zł przez kolejne 12 miesięcy. [#20798033]
  • FunBox 3.0 można powiesić na ścianie; użytkownik opisał montaż na śrubach w poziomie, z przewodami skierowanymi w dół. [#20797299]
  • W Orange prośbę o ONT trzeba zwykle zgłosić technikowi przy umawianiu wizyty i ponownie rano w dniu montażu, bo zamówienie nie zawsze przyjmuje taki wpis. [#20797916]
  • Wątek podkreślał cztery praktyczne kryteria wyboru łącza: publiczny IP, obsługę VLAN, możliwość podpięcia własnego routera oraz routing i punkty styku z innymi operatorami. [#20797491]
Nju światłowód od Orange z FunBox 3.0 czy Netia 300 Mb/s — co lepiej wybrać do stabilnego internetu domowego?
Do stabilnego internetu domowego częściej polecano nju/Orange. W wątku Orange dostał kilka pozytywnych opinii za przewidywalne działanie, a Netia była chwalona głównie ceną. Przy niemal tej samej opłacie, 49 zł w nju i 50 zł w Netii, przewagą nju była umowa na czas nieokreślony i możliwość rezygnacji bez dodatkowych opłat. Jeśli priorytetem jest spokój i mniej kombinowania, Orange wypadał lepiej niż Netia 300 Mb/s. [#20797833]
Jak w praktyce działa FunBox 3.0 z Wi‑Fi przy łączu 300 Mb/s i czy użytkownicy narzekają na stabilność?
FunBox 3.0 w tym wątku działał stabilnie i bez zgłoszonych zawieszeń. Użytkownik używający go prawie 3 lata napisał, że „nie ma na co narzekać” i że sprzęt działa tak, jak powinien. Inny uczestnik dodał, że FB3 i FB6 są przyzwoite do podstawowych zastosowań, a FB6 ma bardzo dobre radio. W praktyce oznacza to, że przy łączu 300 Mb/s FunBox 3.0 wystarcza do zwykłego domu, jeśli nie potrzebujesz zaawansowanych funkcji sieciowych. [#20797284]
W jaki sposób zamontować FunBox 3.0 na ścianie i jakie uchwyty lub otwory montażowe ma z tyłu obudowy?
FunBox 3.0 da się powiesić na ścianie na śrubach. Z tyłu obudowy są elementy montażowe pod łby śrub, opisane w wątku jako odlewy lub zaczepy, na których zawiesza się urządzenie. Jeden użytkownik zamontował go poziomo, bo wtedy przewody schodzą w dół, a pionowy montaż uznał za mniej praktyczny. Jeśli chcesz prosty montaż bez półki, ten router ma do tego fizyczne punkty zaczepu. [#20797299]
Jak załatwić u Orange lub nju montaż terminala ONT zamiast samego FunBoxa podczas instalacji światłowodu?
Trzeba to załatwić bezpośrednio z technikiem, nie tylko na etapie zamówienia. 1. Przy składaniu zamówienia zgłoś, że chcesz terminal ONT. 2. Przy umawianiu wizyty powiedz to ponownie. 3. Rano w dniu montażu przypomnij technikowi, żeby zabrał ONT do samochodu. W wątku podano, że system zamówień potrafi nie przyjmować takiej adnotacji, więc samo zgłoszenie na infolinii nie wystarcza. [#20797916]
Co to jest terminal ONT i dlaczego warto go mieć przy światłowodzie Orange lub Netii?
Terminal ONT warto mieć, bo daje swobodę wyboru własnego routera i uniezależnia sieć domową od FunBoxa lub routera operatora. „ONT” to terminal światłowodowy, który kończy łącze optyczne i zamienia je na Ethernet, dzięki czemu możesz podłączyć własny router, zachowując większą kontrolę nad VPN, DDNS, Wi‑Fi i konfiguracją sieci. W wątku wskazano też konkretne korzyści: łatwiejsze użycie własnych AP, fast roamingu i własnych usług sieciowych. [#20797833]
Kiedy własny router ma sens przy światłowodzie Orange, a kiedy wystarczy FunBox 3.0 lub FunBox 6.0?
Własny router ma sens wtedy, gdy potrzebujesz funkcji, których nie daje sprzęt operatora. W wątku wymieniono VPN, własnych dostawców DDNS, kilka punktów AP i fast roaming. Jeśli używasz internetu standardowo, FunBox 3.0 lub 6.0 wystarcza, a FB6 oceniono nawet jako bardzo dobry radiowo. Najprostsza zasada jest taka: do zwykłego domu zostaw FunBoxa, ale przy bardziej rozbudowanej sieci poproś o ONT i podłącz własny router. [#20797870]
Na czym polega bridge mode w routerach operatora i jak pomaga przy podłączeniu własnego routera?
Bridge mode upraszcza podłączenie własnego routera, bo ogranicza rolę sprzętu operatora do przekazania łącza dalej. „Bridge mode” to tryb pracy routera operatora, który działa jak most sieciowy i przekazuje połączenie do innego routera, zamiast samodzielnie wykonywać pełny routing, NAT i obsługę całej sieci domowej. W wątku podano, że w Netii alternatywą dla ONT może być właśnie bridge, jeśli chcesz użyć własnego sprzętu bez pełnej zależności od routera operatora. [#20798076]
Co to jest DS-Lite w Orange i jak wpływa na IPv4, publiczny adres IP oraz zgodność z własnym sprzętem?
DS-Lite w Orange może utrudnić użycie własnego sprzętu i pełnej kontroli nad IPv4. „DS-Lite” to mechanizm dostępu internetowego, który ogranicza zużycie publicznych adresów IPv4 przez operatora, a ruch IPv4 przenosi przez infrastrukturę IPv6, co zmienia sposób działania części routerów i usług. W wątku padło, że taka konfiguracja jest domyślna przy FunBoxie i że prawie żaden gotowy router z domyślnym firmware nie obsługuje jej poprawnie. To ważny wyjątek dla osób planujących własny router. [#20797947]
Jakie rzeczy warto sprawdzić przed podpisaniem umowy na światłowód, takie jak publiczny IP, VLAN, routing i punkty styku z innymi operatorami?
Przed podpisaniem umowy sprawdź nie tylko cenę, ale też cztery techniczne warunki. Po pierwsze, zapytaj o publiczny adres IP, dynamiczny lub stały. Po drugie, upewnij się, czy możesz podłączyć własny router i czy obsługuje on wymagany VLAN na WAN. Po trzecie, zapytaj o routing i pingi do gier. Po czwarte, sprawdź punkty styku operatora z innymi sieciami. W wątku wskazano właśnie te elementy jako bardziej praktyczne niż same deklarowane 300 Mb/s. [#20797491]
Ile naprawdę kosztuje oferta Netia 600 Mb/s za 1 zł przez 12 miesięcy, a potem 49,90 zł, w przeliczeniu na cały 24-miesięczny kontrakt?
Ta oferta daje średnio około 25,45 zł miesięcznie przez 24 miesiące. Liczenie z wątku wygląda tak: 12 × 1 zł = 12 zł, a 12 × 49,90 zł = 598,80 zł. Razem wychodzi 610,80 zł za cały kontrakt 24-miesięczny. Po podzieleniu przez 24 miesiące dostajesz około 25,45 zł miesięcznie, co autor wątku zaokrąglił do 25 zł/mies. To bardzo atrakcyjna cena, ale wiąże na pełne 24 miesiące. [#20798033]
Czym różni się Huawei HG8245Q2 od Huawei HG8245Q i który model Netia daje jako ONT combo?
W tym wątku nie podano technicznej różnicy między HG8245Q2 a HG8245Q. Jedyna konkretna informacja jest taka, że w danym momencie Netia oferowała model Huawei HG8245Q2 jako „Router ONT Combo”. Jeśli chcesz porównania portów, Wi‑Fi lub firmware obu wersji, ten materiał go nie zawiera. Na podstawie samej dyskusji można bezpiecznie stwierdzić tylko, że HG8245Q2 był wskazany jako aktualnie wydawany przez Netię sprzęt combo. [#20798089]
Jakie ustawienia w Huawei HG8245Q2 warto zmienić po instalacji, a których lepiej nie ruszać, żeby nie stracić internetu?
Najbezpieczniej niczego nie zmieniać w ustawieniach operatora po instalacji. W wątku padła jednoznaczna rada, żeby nie grzebać w konfiguracji HG8245Q2, bo każdy operator ma własne ustawienia i po zmianach można szybko zostać bez internetu. To dotyczy szczególnie parametrów połączenia WAN i innych opcji dostępowych. Jeśli potrzebujesz innych funkcji, lepszą drogą jest ONT lub bridge oraz własny router, a nie ręczna zmiana parametrów operatora. [#20800602]
Dlaczego operatorzy wolą wydawać własne routery zamiast samych terminali ONT i co to zmienia dla diagnostyki oraz pomocy technicznej?
Operatorzy wolą własne routery, bo łatwiej je zdalnie diagnozować i prościej wspierać przez infolinię. W wątku wskazano trzy powody: zdalną diagnostykę, prostsze instrukcje dla klientów typu „jaki kolor ma dioda” oraz mniejsze ryzyko problemów z VLAN, IPTV i telefonią na prywatnym sprzęcie. Dodano też aspekt biznesowy: przy FunBoxie Orange domyślnie używa DS-Lite, co oszczędza adresy IPv4. Dla klienta oznacza to mniej swobody, ale zwykle prostszy kontakt z pomocą techniczną. [#20797947]
Jak zmienić nazwę sieci Wi‑Fi w Huawei OptiXstar HG8245X6-10 i czym różni się SSID od nazwy LAN?
Nazwę Wi‑Fi zmieniasz przez ustawienia SSID, a nie przez konfigurację LAN. W odpowiedzi wyjaśniono, że SSID dotyczy wyłącznie sieci bezprzewodowej, czyli nazwy widocznej na telefonie lub laptopie. LAN to sieć kablowa i zwykle nie wymaga własnej nazwy w domowym sprzęcie SOHO. Jeśli widzisz wspólną nazwę przy 2,4 GHz, to odnosi się ona do Wi‑Fi, a nie do fizycznej sieci LAN. [#21608617]
Dlaczego Windows pokazuje inną nazwę sieci niż SSID Wi‑Fi i gdzie zmienia się identyfikator sieci lokalnej?
Windows może pokazywać inną nazwę, bo to nie zawsze jest SSID Wi‑Fi. W wątku rozróżniono trzy identyfikatory: SSID punktu dostępowego, lokalną domenę LAN oraz nazwę nadawaną przez Windows dla wygody użytkownika. To właśnie ten trzeci identyfikator bywa inny niż nazwa Wi‑Fi. Podano też, że w Windows 7 była do tego opcja graficzna, a obecnie taki identyfikator można zmieniać w rejestrze systemu. [#21609076]
