NETIA FTTH Fiber Opinions: 300 Mbps Package, Transfer Speeds, Modem/Router Choices & Upload Speeds
P.O-O 7956 5
  • #1 16703110
    P.O-O
    Siemandero!
    I don't know if this is the right forum for such a topic ... I want to set up the internet (Wawa, Bemowo). In the block I have the opportunity to establish cable connections (Vectra up to 150 Mbps, Orange up to 80 Mbps, Netia up to 100 Mbps and UPC up to 250 Mbps) and recently it is possible to use the "light" from Netia. There is a max package in my block. 300 Mbps (average package with TV and recorder and LTE phone for PLN 80 per month; contract for 12 or 24 ms).
    I wanted to ask NETIA users, how do you do this company's optical fiber? Do the actual transfers differ significantly from those you pay for? (when it comes to "cable" Internet from NETIA I read a lot of negative reviews). Do they pull the optical fiber directly to the house or just to the staircase? What modems / routers are there to choose? What is the upload there (with option 300)? I send a lot ...
    How is fiber from NETIA working ???
    Thanks for the opinion!
    Regards, Piotr Economical-Last.
  • #2 16704498
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Ask at the source how they connect it (in different places they connect and install it differently).
    The contract should specify the minimum and average speed - do not expect 300 Mb for a 24/7/365 traffic jam to 100%.
    Usually a 10% download.
  • #3 16814331
    seb235
    Help: 98
    Rate: 74
    I have been using the netia link for 5 years and I praise myself despite the fact that this is a CU service. If it wasn't for the fact that there was no option to buy a faster connection than 16Mbps, I would probably not change it. Sites, all VOD, YT services etc. ... zero problems, rock stable link and virtually zero crashes.
    Vectra, UPC - Cable TV here are advantages and disadvantages, depending on the location and neighbors.
    Orange up to 80 Mbps - VDSL2 (Speed from 20 to 80 Mb / s depending on the distance from DSLAM, quality of cabling, etc. ...)
    Netia FTTH - and here by far the most forward-looking, and in my opinion in this direction you should go. Call the hotline best and find out how it is connected to you and what are the real possibilities in your location. Unfortunately, these ads are different, in front of my house on the pole there is a netia offer up to 100Mb / s and you can really have a maximum of 16Mb / s in ADSL technology.
  • #4 17748769
    czarny_alibaba
    Help: 5
    Rate: 151
    Internet MAX 150 Mb / s from Netia
    I am asking for opinion, how do fiber optics from NETIA work?
    Which router do you recommend from them when signing the Agreement today?
    Is it worth signing an Agreement with them or is Orange Fiber Optic better?
  • #5 17748832
    seb235
    Help: 98
    Rate: 74
    I personally do not have one but I have not seen any negative reviews anywhere this time, and two have used netia on copper and I can safely recommend their service. The optical fiber alone does not change anything but better access line parameters
    If I had a choice, it is definitely netia - they have better connections.
    I would not count too much to buy my operator's equipment.
  • #6 17749018
    czarny_alibaba
    Help: 5
    Rate: 151
    P.O-O wrote:
    Siemandero!
    I am curious myself how is it?
