[Solved] AP mode in Wemos D1 mini and ESP8266: routing network traffic and manipulation of metrics
tos18 2094 8
  • Question about changing ESP8266 AP route metrics
    #1 20802190
    tos18
    Help: 1113
    Rate: 1870
    The Wemos D1 mini and others based on the ESP8266 have AP (Access Point) mode which works very nicely but I have one problem.
    When a client computer connects to such an AP it treats it as a default gateway and tries to route all network traffic through it, no matter that we have other connections active (lan, lte, second wlan). As a result, it is impossible to use the internet after connecting to esp. Also it is not possible to correctly display a page set up on esp when it has links to external sources (e.g. jquery, bootstrap, etc)
    From what I can see the connection with esp has a metric of 3 while others have higher values (my current wifi connection has 20)
    Is there any solution ?
    I don't know if esp has the possibility to manipulate the metric.
  • #2 20802761
  • #3 20802778
    tos18
    Help: 1113
    Rate: 1870
    yes:
    Code: Arduino
    or yes:
    Code: Arduino
    In both cases the same effect.
  • #4 20802784
  • #5 20802792
    tos18
    Help: 1113
    Rate: 1870
    I can't because I won't know the network address at the target location.
    That's why I use AP mode. If I had access to the network I would use STA mode and the problem would not exist.
  • Use client mode to discover the router gateway
    #6 20802823
  • STA mode avoids routing issues with ESP8266 AP
    #7 20802858
    tos18
    Help: 1113
    Rate: 1870
    If esp were to be on the same network then I would use STA mode, DHCP would assign an address and specify the gateway - no problem in STA mode.
    There is also no problem if the connection to esp has a metric further (read larger) than the internet connection being used.
    Then the connections work correctly and all traffic is directed to the default gateway and queries for esp go to the network created by esp.
  • #9 20802956
    tos18
    Help: 1113
    Rate: 1870
    Code: Arduino
    Helped.
    Metrics something around 300 and no registered gate.
    Thanks again.
The discussion revolves around the challenges faced when using the Wemos D1 mini and ESP8266 in Access Point (AP) mode, particularly regarding network traffic routing. When a client connects to the ESP's AP, it defaults to using the ESP as the gateway, disrupting internet access through other connections. Users explore potential solutions, including configuring the ESP's gateway settings. Suggestions include setting the gateway to 0.0.0.0 to prevent it from being treated as a default gateway, which successfully resolved the issue for one user. The conversation also touches on the importance of network metrics and the implications of using different modes (AP vs. STA) based on network access.
