Info on BL602 Module SDV-002_V1.2 from Aliexpress 3-Gang Switch, Pin Compatibility & GPIOs
chlebok 1023 0
  • Bootloader flashes but module never joins Wi-Fi
    #1 20814000
    chlebok
    Rate: 56
    Hello, I have same module, but have problem. I wrote binary succesfuly, but after reset can't connect. The module isn't visible in wifi. I tried first with 2M partition. I tried with 2,000,000 baud rate option aswell. Boot pin pull-up is removed avfer flash.
    Can't find what is wrong. @p.kaczmarek2 help me :)
    To view the material on this forum you must be logged in.
    Logs
    [21:55:06.102] - ========= Interface is Uart =========
    [21:55:06.107] - eflash loader bin is eflash_loader_40m.bin
    [21:55:06.109] - ========= chip flash id: ef4015 =========
    [21:55:06.114] - create partition.bin, pt_new is True
    [21:55:06.126] - fw_boot_head_gen xtal: 40M
    [21:55:06.129] - Create bootheader using chips\bl602\img_create_iot\efuse_bootheader_cfg.ini
    [21:55:06.130] - Updating data according to
    [21:55:06.131] - Created file len:176
    [21:55:06.134] - Create efuse using chips\bl602\img_create_iot\efuse_bootheader_cfg.ini
    [21:55:06.135] - Updating data according to
    [21:55:06.137] - Created file len:128
    [21:55:06.143] - ========= sp image create =========
    [21:55:06.144] - Image hash is b'c5e2ce515a5783ac80efdd4910238a466572f882b53b3284e63c763e1da9847f'
    [21:55:06.144] - Hash ignored
    [21:55:06.145] - Header crc ignored
    [21:55:06.145] - Write flash img
    [21:55:06.147] - Encrypt efuse data
    [21:55:06.155] - fw_boot_head_gen xtal: 40M
    [21:55:06.160] - Create bootheader using chips\bl602\img_create_iot\efuse_bootheader_cfg.ini
    [21:55:06.161] - Updating data according to
    [21:55:06.163] - Created file len:176
    [21:55:06.165] - Create efuse using chips\bl602\img_create_iot\efuse_bootheader_cfg.ini
    [21:55:06.167] - Updating data according to
    [21:55:06.169] - Created file len:128
    [21:55:06.175] - ========= sp image create =========
    [21:55:06.183] - Image hash is b'cc5359a93ec6856a986e7f8ab5d32227da205ddbc502198c3d4511ba31a321d8'
    [21:55:06.183] - Header crc: b'82f202ab'
    [21:55:06.184] - Write flash img
    [21:55:06.189] - Encrypt efuse data
    [21:55:06.191] - FW Header is 176, 3920 still needed
    [21:55:06.193] - FW OTA bin header is Done. Len is 4096
    [21:55:06.265] - BL60X_OTA_Ver1.0
    [21:55:06.348] - FW OTA bin is Done. Len is 759904
    [21:55:06.778] - OTA XZ file len = 404528
    [21:55:06.779] - Partiton len = 557056
    [21:55:06.780] - BL60X_OTA_Ver1.0
    [21:55:06.828] - FW OTA xz is Done
    [21:55:06.829] - ========= eflash loader config =========
    [21:55:06.831] - Image offset = 8192
    [21:55:06.878] - =========C:/Users/PCchleb/Downloads/BouffaloLabDevCube-v1.8.6(1)/chips/bl602/device_tree/bl_factory_params_IoTKitA_40M.dts ——> C:\Users\PCchleb\Downloads\BouffaloLabDevCube-v1.8.6(1)\chips\bl602/device_tree/ro_params.dtb=========
    [21:55:07.035] - Version: eflash_loader_v2.4.7
    [21:55:07.035] - Program Start
    [21:55:07.035] - ========= eflash loader cmd arguments =========
    [21:55:07.036] - Config file: C:\Users\PCchleb\Downloads\BouffaloLabDevCube-v1.8.6(1)\chips\bl602\eflash_loader/eflash_loader_cfg.ini
    [21:55:07.038] - serial port is COM3
    [21:55:07.039] - cpu_reset=False
    [21:55:07.039] - chiptype: bl602
    [21:55:07.039] - ========= Interface is uart =========
    [21:55:07.039] - com speed: 500000
    [21:55:07.041] - Eflash load helper file: C:\Users\PCchleb\Downloads\BouffaloLabDevCube-v1.8.6(1)\chips\bl602\eflash_loader/eflash_loader_40m.bin
    [21:55:07.041] - ========= load eflash_loader.bin =========
    [21:55:07.042] - Load eflash_loader.bin via uart
    [21:55:07.042] - ========= image load =========
    [21:55:07.345] - FLc0c0 unknown
    [21:55:07.346] - Not ack OK
    [21:55:07.346] - FLc0c0 unknown
    [21:55:07.346] - result: FLc0c0 unknown
    [21:55:07.683] - tx rx and power off, press the machine!
    [21:55:07.684] - cutoff time is 0.1
    [21:55:07.791] - power on tx and rx
    [21:55:08.603] - reset cnt: 0, reset hold: 0.005, shake hand delay: 0.1
    [21:55:08.604] - clean buf
    [21:55:08.726] - send sync
    [21:55:08.941] - ack is c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c0c04f4b
    [21:55:09.048] - shake hand success
    [21:55:09.063] - get_boot_info
    [21:55:09.065] - data read is b'01000000000000000300000075cb9a4cb97c1500'
    [21:55:09.065] - ========= chipid: 7cb94c9acb75 =========
    [21:55:09.065] - last boot info: None
    [21:55:09.065] - sign is 0 encrypt is 0
    [21:55:09.065] - segcnt is 1
    [21:55:09.071] - segdata_len is 38464
    [21:55:09.164] - 4080/38464
    [21:55:09.256] - 8160/38464
    [21:55:09.348] - 12240/38464
    [21:55:09.441] - 16320/38464
    [21:55:09.533] - 20400/38464
    [21:55:09.625] - 24480/38464
    [21:55:09.718] - 28560/38464
    [21:55:09.810] - 32640/38464
    [21:55:09.902] - 36720/38464
    [21:55:09.942] - 38464/38464
    [21:55:09.943] - Run img
    [21:55:10.047] - Load helper bin time cost(ms): 3005.0126953125
    [21:55:10.154] - Flash load shake hand
    [21:55:10.282] - default set DTR high
    [21:55:10.385] - clean buf
    [21:55:10.508] - send sync
    [21:55:10.723] - ack is 4f4b
    [21:55:10.814] - Read mac addr
    [21:55:10.815] - macaddr: 75cb9a4cb97c
    [21:55:10.815] - flash set para
    [21:55:10.816] - ========= flash read jedec ID =========
    [21:55:10.817] - Read flash jedec ID
    [21:55:10.817] - flash jedec id: ef401580
    [21:55:10.817] - Finished
    [21:55:10.821] - get flash size: 0x00200000
    [21:55:10.821] - Program operation
    [21:55:10.822] - Dealing Index 0
    [21:55:10.822] - ========= programming chips\bl602\img_create_iot\whole_img_boot2.bin to 0x00000000
    [21:55:10.826] - ========= flash load =========
    [21:55:10.827] - ========= flash erase =========
    [21:55:10.827] - Erase flash from 0x0 to 0xb98f
    [21:55:10.896] - erase pending
    [21:55:11.046] - erase pending
    [21:55:11.079] - erase pending
    [21:55:11.111] - erase pending
    [21:55:11.142] - erase pending
    [21:55:11.259] - Erase time cost(ms): 432.0087890625
    [21:55:11.320] - decompress write rx timeout: 24.576
    [21:55:11.396] - decompress flash load 22128
    [21:55:11.444] - Load 2048/22128 {"progress":9}
    [21:55:11.492] - Load 4096/22128 {"progress":18}
    [21:55:11.540] - Load 6144/22128 {"progress":27}
    [21:55:11.587] - Load 8192/22128 {"progress":37}
    [21:55:11.635] - Load 10240/22128 {"progress":46}
    [21:55:11.682] - Load 12288/22128 {"progress":55}
    [21:55:11.729] - Load 14336/22128 {"progress":64}
    [21:55:11.777] - Load 16384/22128 {"progress":74}
    [21:55:11.824] - Load 18432/22128 {"progress":83}
    [21:55:11.871] - Load 20480/22128 {"progress":92}
    [21:55:11.909] - Load 22128/22128 {"progress":100}
    [21:55:11.910] - Load 22128/22128 {"progress":100}
    [21:55:11.911] - Write check
    [21:55:11.995] - Flash load time cost(ms): 674.236572265625
    [21:55:11.995] - Finished
    [21:55:11.997] - Sha caled by host: cf7321b7a337021dd92984959adb2b62dacb95ed7d9c991de87365af835249d0
    [21:55:11.997] - xip mode Verify
    [21:55:12.011] - Read Sha256/47504
    [21:55:12.012] - Flash xip readsha time cost(ms): 14.829345703125
    [21:55:12.012] - Finished
    [21:55:12.013] - Sha caled by dev: cf7321b7a337021dd92984959adb2b62dacb95ed7d9c991de87365af835249d0
    [21:55:12.013] - Verify success
    [21:55:12.072] - Dealing Index 1
    [21:55:12.072] - ========= programming chips\bl602\partition\partition.bin to 0x0000E000
    [21:55:12.076] - ========= flash load =========
    [21:55:12.077] - ========= flash erase =========
    [21:55:12.077] - Erase flash from 0xe000 to 0xe10f
    [21:55:12.133] - erase pending
    [21:55:12.254] - Erase time cost(ms): 177.3583984375
    [21:55:12.323] - Load 272/272 {"progress":100}
    [21:55:12.323] - Write check
    [21:55:12.377] - Flash load time cost(ms): 61.345703125
    [21:55:12.378] - Finished
    [21:55:12.379] - Sha caled by host: fd6af18fc4aaf2807277cac767ca19d12af7b55f5ecbb8902ef28bc2430524aa
    [21:55:12.379] - xip mode Verify
    [21:55:12.383] - Read Sha256/272
    [21:55:12.383] - Flash xip readsha time cost(ms): 2.97509765625
    [21:55:12.383] - Finished
    [21:55:12.384] - Sha caled by dev: fd6af18fc4aaf2807277cac767ca19d12af7b55f5ecbb8902ef28bc2430524aa
    [21:55:12.384] - Verify success
    [21:55:12.439] - Dealing Index 2
    [21:55:12.439] - ========= programming chips\bl602\partition\partition.bin to 0x0000F000
    [21:55:12.443] - ========= flash load =========
    [21:55:12.443] - ========= flash erase =========
    [21:55:12.443] - Erase flash from 0xf000 to 0xf10f
    [21:55:12.501] - erase pending
    [21:55:12.623] - Erase time cost(ms): 179.181640625
    [21:55:12.691] - Load 272/272 {"progress":100}
    [21:55:12.692] - Load 272/272 {"progress":100}
    [21:55:12.692] - Write check
    [21:55:12.745] - Flash load time cost(ms): 61.34765625
    [21:55:12.746] - Finished
    [21:55:12.746] - Sha caled by host: fd6af18fc4aaf2807277cac767ca19d12af7b55f5ecbb8902ef28bc2430524aa
    [21:55:12.747] - xip mode Verify
    [21:55:12.749] - Read Sha256/272
    [21:55:12.749] - Flash xip readsha time cost(ms): 1.98583984375
    [21:55:12.749] - Finished
    [21:55:12.750] - Sha caled by dev: fd6af18fc4aaf2807277cac767ca19d12af7b55f5ecbb8902ef28bc2430524aa
    [21:55:12.750] - Verify success
    [21:55:12.807] - Dealing Index 3
    [21:55:12.808] - ========= programming chips\bl602\img_create_iot\whole_img.bin to 0x00010000
    [21:55:12.812] - ========= flash load =========
    [21:55:12.814] - ========= flash erase =========
    [21:55:12.814] - Erase flash from 0x10000 to 0xc985f
    [21:55:12.873] - erase pending
    [21:55:13.104] - erase pending
    [21:55:13.309] - erase pending
    [21:55:13.530] - erase pending
    [21:55:13.742] - erase pending
    [21:55:13.946] - erase pending
    [21:55:14.176] - erase pending
    [21:55:14.400] - erase pending
    [21:55:14.620] - erase pending
    [21:55:14.839] - erase pending
    [21:55:15.061] - erase pending
    [21:55:15.281] - erase pending
    [21:55:15.428] - erase pending
    [21:55:15.458] - erase pending
    [21:55:15.582] - Erase time cost(ms): 2768.010986328125
    [21:55:15.644] - decompress write rx timeout: 24.576
    [21:55:16.014] - decompress flash load 404528
    [21:55:16.061] - Load 2048/404528 {"progress":0}
    [21:55:16.108] - Load 4096/404528 {"progress":1}
    [21:55:16.156] - Load 6144/404528 {"progress":1}
    [21:55:16.203] - Load 8192/404528 {"progress":2}
    [21:55:16.250] - Load 10240/404528 {"progress":2}
    [21:55:16.297] - Load 12288/404528 {"progress":3}
    [21:55:16.345] - Load 14336/404528 {"progress":3}
    [21:55:16.392] - Load 16384/404528 {"progress":4}
    [21:55:16.440] - Load 18432/404528 {"progress":4}
    [21:55:16.487] - Load 20480/404528 {"progress":5}
    [21:55:16.534] - Load 22528/404528 {"progress":5}
    [21:55:16.582] - Load 24576/404528 {"progress":6}
    [21:55:16.629] - Load 26624/404528 {"progress":6}
    [21:55:16.676] - Load 28672/404528 {"progress":7}
    [21:55:16.724] - Load 30720/404528 {"progress":7}
    [21:55:16.771] - Load 32768/404528 {"progress":8}
    [21:55:16.819] - Load 34816/404528 {"progress":8}
    [21:55:16.866] - Load 36864/404528 {"progress":9}
    [21:55:16.913] - Load 38912/404528 {"progress":9}
    [21:55:16.960] - Load 40960/404528 {"progress":10}
    [21:55:17.008] - Load 43008/404528 {"progress":10}
    [21:55:17.055] - Load 45056/404528 {"progress":11}
    [21:55:17.103] - Load 47104/404528 {"progress":11}
    [21:55:17.150] - Load 49152/404528 {"progress":12}
    [21:55:17.197] - Load 51200/404528 {"progress":12}
    [21:55:17.244] - Load 53248/404528 {"progress":13}
    [21:55:17.292] - Load 55296/404528 {"progress":13}
    [21:55:17.340] - Load 57344/404528 {"progress":14}
    [21:55:17.387] - Load 59392/404528 {"progress":14}
    [21:55:17.434] - Load 61440/404528 {"progress":15}
    [21:55:17.481] - Load 63488/404528 {"progress":15}
    [21:55:17.528] - Load 65536/404528 {"progress":16}
    [21:55:17.576] - Load 67584/404528 {"progress":16}
    [21:55:17.623] - Load 69632/404528 {"progress":17}
    [21:55:17.671] - Load 71680/404528 {"progress":17}
    [21:55:17.718] - Load 73728/404528 {"progress":18}
    [21:55:17.766] - Load 75776/404528 {"progress":18}
    [21:55:17.813] - Load 77824/404528 {"progress":19}
    [21:55:17.861] - Load 79872/404528 {"progress":19}
    [21:55:17.908] - Load 81920/404528 {"progress":20}
    [21:55:17.956] - Load 83968/404528 {"progress":20}
    [21:55:18.003] - Load 86016/404528 {"progress":21}
    [21:55:18.050] - Load 88064/404528 {"progress":21}
    [21:55:18.098] - Load 90112/404528 {"progress":22}
    [21:55:18.144] - Load 92160/404528 {"progress":22}
    [21:55:18.192] - Load 94208/404528 {"progress":23}
    [21:55:18.240] - Load 96256/404528 {"progress":23}
    [21:55:18.286] - Load 98304/404528 {"progress":24}
    [21:55:18.334] - Load 100352/404528 {"progress":24}
    [21:55:18.381] - Load 102400/404528 {"progress":25}
    [21:55:18.429] - Load 104448/404528 {"progress":25}
    [21:55:18.476] - Load 106496/404528 {"progress":26}
    [21:55:18.523] - Load 108544/404528 {"progress":26}
    [21:55:18.571] - Load 110592/404528 {"progress":27}
    [21:55:18.618] - Load 112640/404528 {"progress":27}
    [21:55:18.665] - Load 114688/404528 {"progress":28}
    [21:55:18.713] - Load 116736/404528 {"progress":28}
    [21:55:18.760] - Load 118784/404528 {"progress":29}
    [21:55:18.807] - Load 120832/404528 {"progress":29}
    [21:55:18.855] - Load 122880/404528 {"progress":30}
    [21:55:18.902] - Load 124928/404528 {"progress":30}
    [21:55:18.949] - Load 126976/404528 {"progress":31}
    [21:55:18.997] - Load 129024/404528 {"progress":31}
    [21:55:19.044] - Load 131072/404528 {"progress":32}
    [21:55:19.091] - Load 133120/404528 {"progress":32}
    [21:55:19.139] - Load 135168/404528 {"progress":33}
    [21:55:19.186] - Load 137216/404528 {"progress":33}
    [21:55:19.234] - Load 139264/404528 {"progress":34}
    [21:55:19.281] - Load 141312/404528 {"progress":34}
    [21:55:19.328] - Load 143360/404528 {"progress":35}
    [21:55:19.375] - Load 145408/404528 {"progress":35}
    [21:55:19.423] - Load 147456/404528 {"progress":36}
    [21:55:19.470] - Load 149504/404528 {"progress":36}
    [21:55:19.517] - Load 151552/404528 {"progress":37}
    [21:55:19.565] - Load 153600/404528 {"progress":37}
    [21:55:19.612] - Load 155648/404528 {"progress":38}
    [21:55:19.659] - Load 157696/404528 {"progress":38}
    [21:55:19.706] - Load 159744/404528 {"progress":39}
    [21:55:19.754] - Load 161792/404528 {"progress":39}
    [21:55:19.801] - Load 163840/404528 {"progress":40}
    [21:55:19.849] - Load 165888/404528 {"progress":41}
    [21:55:19.896] - Load 167936/404528 {"progress":41}
    [21:55:19.943] - Load 169984/404528 {"progress":42}
    [21:55:19.991] - Load 172032/404528 {"progress":42}
    [21:55:20.038] - Load 174080/404528 {"progress":43}
    [21:55:20.085] - Load 176128/404528 {"progress":43}
    [21:55:20.133] - Load 178176/404528 {"progress":44}
    [21:55:20.180] - Load 180224/404528 {"progress":44}
    [21:55:20.228] - Load 182272/404528 {"progress":45}
    [21:55:20.275] - Load 184320/404528 {"progress":45}
    [21:55:20.322] - Load 186368/404528 {"progress":46}
    [21:55:20.369] - Load 188416/404528 {"progress":46}
    [21:55:20.417] - Load 190464/404528 {"progress":47}
    [21:55:20.464] - Load 192512/404528 {"progress":47}
    [21:55:20.511] - Load 194560/404528 {"progress":48}
    [21:55:20.559] - Load 196608/404528 {"progress":48}
    [21:55:20.606] - Load 198656/404528 {"progress":49}
    [21:55:20.653] - Load 200704/404528 {"progress":49}
    [21:55:20.701] - Load 202752/404528 {"progress":50}
    [21:55:20.748] - Load 204800/404528 {"progress":50}
    [21:55:20.796] - Load 206848/404528 {"progress":51}
    [21:55:20.843] - Load 208896/404528 {"progress":51}
    [21:55:20.890] - Load 210944/404528 {"progress":52}
    [21:55:20.938] - Load 212992/404528 {"progress":52}
    [21:55:20.985] - Load 215040/404528 {"progress":53}
    [21:55:21.032] - Load 217088/404528 {"progress":53}
    [21:55:21.080] - Load 219136/404528 {"progress":54}
    [21:55:21.126] - Load 221184/404528 {"progress":54}
    [21:55:21.174] - Load 223232/404528 {"progress":55}
    [21:55:21.222] - Load 225280/404528 {"progress":55}
    [21:55:21.268] - Load 227328/404528 {"progress":56}
    [21:55:21.316] - Load 229376/404528 {"progress":56}
    [21:55:21.364] - Load 231424/404528 {"progress":57}
    [21:55:21.411] - Load 233472/404528 {"progress":57}
    [21:55:21.458] - Load 235520/404528 {"progress":58}
    [21:55:21.506] - Load 237568/404528 {"progress":58}
    [21:55:21.553] - Load 239616/404528 {"progress":59}
    [21:55:21.600] - Load 241664/404528 {"progress":59}
    [21:55:21.648] - Load 243712/404528 {"progress":60}
    [21:55:21.694] - Load 245760/404528 {"progress":60}
    [21:55:21.742] - Load 247808/404528 {"progress":61}
    [21:55:21.789] - Load 249856/404528 {"progress":61}
    [21:55:21.836] - Load 251904/404528 {"progress":62}
    [21:55:21.884] - Load 253952/404528 {"progress":62}
    [21:55:21.931] - Load 256000/404528 {"progress":63}
    [21:55:21.978] - Load 258048/404528 {"progress":63}
    [21:55:22.025] - Load 260096/404528 {"progress":64}
    [21:55:22.073] - Load 262144/404528 {"progress":64}
    [21:55:22.121] - Load 264192/404528 {"progress":65}
    [21:55:22.168] - Load 266240/404528 {"progress":65}
    [21:55:22.215] - Load 268288/404528 {"progress":66}
    [21:55:22.263] - Load 270336/404528 {"progress":66}
    [21:55:22.310] - Load 272384/404528 {"progress":67}
    [21:55:22.357] - Load 274432/404528 {"progress":67}
    [21:55:22.405] - Load 276480/404528 {"progress":68}
    [21:55:22.452] - Load 278528/404528 {"progress":68}
    [21:55:22.499] - Load 280576/404528 {"progress":69}
    [21:55:22.546] - Load 282624/404528 {"progress":69}
    [21:55:22.593] - Load 284672/404528 {"progress":70}
    [21:55:22.640] - Load 286720/404528 {"progress":70}
    [21:55:22.687] - Load 288768/404528 {"progress":71}
    [21:55:22.735] - Load 290816/404528 {"progress":71}
    [21:55:22.782] - Load 292864/404528 {"progress":72}
    [21:55:22.830] - Load 294912/404528 {"progress":72}
    [21:55:22.877] - Load 296960/404528 {"progress":73}
    [21:55:22.924] - Load 299008/404528 {"progress":73}
    [21:55:22.971] - Load 301056/404528 {"progress":74}
    [21:55:23.018] - Load 303104/404528 {"progress":74}
    [21:55:23.065] - Load 305152/404528 {"progress":75}
    [21:55:23.113] - Load 307200/404528 {"progress":75}
    [21:55:23.160] - Load 309248/404528 {"progress":76}
    [21:55:23.207] - Load 311296/404528 {"progress":76}
    [21:55:23.255] - Load 313344/404528 {"progress":77}
    [21:55:23.302] - Load 315392/404528 {"progress":77}
    [21:55:23.350] - Load 317440/404528 {"progress":78}
    [21:55:23.397] - Load 319488/404528 {"progress":78}
    [21:55:23.444] - Load 321536/404528 {"progress":79}
    [21:55:23.491] - Load 323584/404528 {"progress":79}
    [21:55:23.539] - Load 325632/404528 {"progress":80}
    [21:55:23.587] - Load 327680/404528 {"progress":81}
    [21:55:23.634] - Load 329728/404528 {"progress":81}
    [21:55:23.681] - Load 331776/404528 {"progress":82}
    [21:55:23.728] - Load 333824/404528 {"progress":82}
    [21:55:23.775] - Load 335872/404528 {"progress":83}
    [21:55:23.823] - Load 337920/404528 {"progress":83}
    [21:55:23.875] - Load 339968/404528 {"progress":84}
    [21:55:23.923] - Load 342016/404528 {"progress":84}
    [21:55:23.970] - Load 344064/404528 {"progress":85}
    [21:55:24.017] - Load 346112/404528 {"progress":85}
    [21:55:24.064] - Load 348160/404528 {"progress":86}
    [21:55:24.112] - Load 350208/404528 {"progress":86}
    [21:55:24.160] - Load 352256/404528 {"progress":87}
    [21:55:24.207] - Load 354304/404528 {"progress":87}
    [21:55:24.254] - Load 356352/404528 {"progress":88}
    [21:55:24.301] - Load 358400/404528 {"progress":88}
    [21:55:24.349] - Load 360448/404528 {"progress":89}
    [21:55:24.396] - Load 362496/404528 {"progress":89}
    [21:55:24.443] - Load 364544/404528 {"progress":90}
    [21:55:24.491] - Load 366592/404528 {"progress":90}
    [21:55:24.538] - Load 368640/404528 {"progress":91}
    [21:55:24.585] - Load 370688/404528 {"progress":91}
    [21:55:24.632] - Load 372736/404528 {"progress":92}
    [21:55:24.680] - Load 374784/404528 {"progress":92}
    [21:55:24.727] - Load 376832/404528 {"progress":93}
    [21:55:24.774] - Load 378880/404528 {"progress":93}
    [21:55:24.822] - Load 380928/404528 {"progress":94}
    [21:55:24.869] - Load 382976/404528 {"progress":94}
    [21:55:24.916] - Load 385024/404528 {"progress":95}
    [21:55:24.963] - Load 387072/404528 {"progress":95}
    [21:55:25.010] - Load 389120/404528 {"progress":96}
    [21:55:25.058] - Load 391168/404528 {"progress":96}
    [21:55:25.105] - Load 393216/404528 {"progress":97}
    [21:55:25.152] - Load 395264/404528 {"progress":97}
    [21:55:25.200] - Load 397312/404528 {"progress":98}
    [21:55:25.247] - Load 399360/404528 {"progress":98}
    [21:55:25.294] - Load 401408/404528 {"progress":99}
    [21:55:25.342] - Load 403456/404528 {"progress":99}
    [21:55:25.368] - Load 404528/404528 {"progress":100}
    [21:55:25.370] - Load 404528/404528 {"progress":100}
    [21:55:25.371] - Write check
    [21:55:25.450] - Flash load time cost(ms): 9805.93017578125
    [21:55:25.450] - Finished
    [21:55:25.455] - Sha caled by host: 24599529e7209425bfd2749bdc115ee209bf537a40bd65641be1312ac65a3b85
    [21:55:25.455] - xip mode Verify
    [21:55:25.663] - Read Sha256/759904
    [21:55:25.663] - Flash xip readsha time cost(ms): 207.3798828125
    [21:55:25.663] - Finished
    [21:55:25.665] - Sha caled by dev: 24599529e7209425bfd2749bdc115ee209bf537a40bd65641be1312ac65a3b85
    [21:55:25.665] - Verify success
    [21:55:25.727] - Dealing Index 4
    [21:55:25.727] - ========= programming chips\bl602\device_tree\ro_params.dtb to 0x001F8000
    [21:55:25.731] - ========= flash load =========
    [21:55:25.731] - ========= flash erase =========
    [21:55:25.732] - Erase flash from 0x1f8000 to 0x1f975d
    [21:55:25.788] - erase pending
    [21:55:25.817] - erase pending
    [21:55:25.940] - Erase time cost(ms): 208.176025390625
    [21:55:26.002] - decompress write rx timeout: 24.576
    [21:55:26.066] - decompress flash load 1584
    [21:55:26.103] - Load 1584/1584 {"progress":100}
    [21:55:26.104] - Load 1584/1584 {"progress":100}
    [21:55:26.104] - Write check
    [21:55:26.185] - Flash load time cost(ms): 183.519287109375
    [21:55:26.186] - Finished
    [21:55:26.187] - Sha caled by host: 2030ce2a98174d1e1bc02905472a5c55ff0df9d7274c49efd787982af2430e58
    [21:55:26.187] - xip mode Verify
    [21:55:26.192] - Read Sha256/5982
    [21:55:26.192] - Flash xip readsha time cost(ms): 3.63134765625
    [21:55:26.192] - Finished
    [21:55:26.193] - Sha caled by dev: 2030ce2a98174d1e1bc02905472a5c55ff0df9d7274c49efd787982af2430e58
    [21:55:26.193] - Verify success
    [21:55:26.248] - Program Finished
    [21:55:26.248] - All time cost(ms): 19213.0625
    [21:55:26.371] - close interface
    [21:55:26.372] - [All Success]
    BTW: Where is TX2 here?
