Seeking firmware/dump Hitachi 50HK25T74U (Vestel 17MB130S mainboard, VES500QNYC panel)
Joksy 4338 2
  • #1 20839168
    Joksy
    Trying to get this TV working and I am hoping recovery software might sort it out. The Hitachi splash screen flashes for a second after maybe 30 seconds and powers off then. The front led flashes about 20 times too. Reminds me of the Toshiba's I had before with similar problems. Would really appreciate any input. thanks
  • CH341A contact issue when reading SPI flash
    #2 20841906
    Joksy
    I got the USB recovery files for the TV. I tried with a few different USB sticks and it seems to read them fine and upgrade the software. But in my case, I cannot be sure as the screen just flashes once for a second and then off again. Does anyone know if you have to remove the SPI 25L1606E to read/write to it? I have a CH341A with a pogo pin type adapter to read the chip, but the CH341A LED goes out when I seem to have good contact with the chip pins.
    • mb130_en.bin (243.02 MB) You must be logged in to download this attachment.
    • mb130_RomBoot_AMZ.bin (2.14 MB) You must be logged in to download this attachment.
    • mb130_PM51_connected.bin (64 KB) You must be logged in to download this attachment.
    • usb_auto_update_G10.txt (3.2 KB) You must be logged in to download this attachment.
  • #3 20850464
    Joksy
    I replaced the two 92uF/100V capacitors beside the transformer on the power board and all is good. One was bad and the other was reading low.
