Suntek HC-900M Trail Camera Triggering Photos Without Detecting Motion
trevor_philipsL 2544 2
  • #1 20918058
    trevor_philipsL
    Hello guys I have a suntek HC-900M which takes a lot of photos every time without movement. And when are movement don't do much photos. I changed the PIR sensor but still without work. What i can do. Thanks
  • #2 20919909
    gradek83
    Help: 930
    Rate: 2103
    Does the new camera work this badly?
    Have you checked the small internal battery - what voltage does it have - 3V?
    What version of the motherboard PCB do you have and what firmware version?
  • #3 20922028
    trevor_philipsL
    Hello. This camera uses AA batteries, but now it is connected to a 12V adapter.
    The firmware version is "910MPro_20230307 EC200UEUAAR02A05M08."
    The PCB is "H900_670_4G_V20" from 28/10/2022.
