MySensors integration into HA - erroneous temperature display
ditomek 786 1
  • Home Assistant shows wrong temperature units after manual change
    #1 20934303
    ditomek
    Help: 24
    Rate: 230
    Some time ago I started my battles with programs like HA and domoticz. Domoticz was the first to go. I integrated my own automation system (I described it on the electrode) using mysensors Ethernet gateways (arduino mega +W5100). In total, it's two devices: one for temperature information and the other for lights and blinds.
    In domoticz it works as it is supposed to work. The data is presented correctly by the mysensors, the reading is problem-free. In a word, like in a book.
    Now I am starting to get to know HA and I have chosen my temperature gateway as the first element. First of all, the HA connects correctly, but only shows one entity instead of the eight temperatures I have defined in the presentation section.
    It is a battery which I have never defined, but never mind. The most important thing is that as soon as the gateway starts sending info about the temperatures (every second) they appear in the HA.
    But, instead of the actual temperature they are some imaginary numbers. When you go deeper into the entity, you can see the correct V_TEMP value and it changes on the fly. However, what is presented above does not. I should just add that when I added the entity, HA set the units to F which I then manually changed to C. Maybe I made a mistake here?
  • #2 20935891
    ditomek
    Help: 24
    Rate: 230
    I have checked and can now answer for myself. Changing the units F -> C has caused HA to start showing temperatures correctly. Does anyone know why the HA took F by default? I specified the correct location when I first started.
